    Rhino 3d to Sketchup
    19 Posts 3 Posters 4.8k Views 3 Watching
      My suggestion is to skip Rhino. Draw the model in SketchUp making each piece you'd cut out of wood (or MDF, plywood, etc.) a component. You can do all of the detailing in SketchUp and then use the resulting model for your sheet optimization. You can see the process of drawing a project made of sheet goods here.
      As I already wrote, I think you'll find your time better spent if you do that instead of trying to repair your Rhino model in SketchUp to make it usable.
      Most of the things I draw in SketchUp are woodworking projects and I know it's much easier to draw things correctly than to fix things that aren't right. It's exactly the same as building projects for real.
        ryanro
        Your logic is right,my only problem is time,time that i need to learn...create cabinets in SU,anyway u are a kind person who did try to help me,u make me courious with your cabinet and now i will watch it,thx.
          Maybe you can use the same trick than from MOi to Sketchup! πŸ˜‰
          If you have yet different group inside Rhino
          Export as 3DS format ! (if its existing)
          Import inside Sketchup
          Explode one time inside SKetchup : you have all your different groups! πŸ˜‰
            ryanro
            thx Pilou,i allready did that in rhino making every element a block,export it as skp,open it in SU exploded 1 time as u said and this is it,bot to many operations,and loosen time for an easy job like that i think.
              You could have drawn the model in SketchUp from nothing in the time you've spent screwing around trying to get it out of Rhino.
                ryanro
                Dave,right now i m watching this:https://www.youtube.com/watch?v=SnsEVVY9wU8
                πŸ˜„
                  No, no, no! πŸ˜„
                  You must export as format 3DS! (if Rhino has it )
                  Seems it has! πŸ€“
                    ryanro
                    Hi pilou,what is the difference?i did it bot i cant see any change
                      In MOi3D export as 3DS format permit to keep the "Group(s)" inside Sketchup! 😎
                      export as SKP don't permit that!
                      For Rhino I can't say i have not this beast! πŸ˜„
                        ryanro
                        MOi3D is very similar to rhino,in rhino if i make every elements as a block,i get the same sesult in Su,but i see,it is easyer as u said anyway ,thx
