    House Builder
    24 Posts 9 Posters 4.7k Views 9 Watching
      paddyclown
      I reinstalled it via SU2014 after renaming the .zip to .rbz (clean reinstall)
      the version is "v1.2 metric" that I got here: ruby library depot
      http://rhin.crai.archi.fr/rld/plugin_details.php?id=186
      odd...
      • micioneM Offline
        micione
        For SU2014 : install this
        http://rhin.crai.archi.fr/rld/plugin_details.php?id=185
          The Imperial '/" version is already compatible BUT with the Metric version...
          It's like a lot of Didier's 'packed code' !
          It needs some simple editing to make it v2014 compliant.
          I see that micione beat me to it, with a link to an unpacked compatible version.
          Anyway here's how to fix the "packed" version...
          Open the HouseBuilder subfolder within Plugins, find the two files named HouseBuilder.rb and HouseBuilderTool.rb, open them using Notepad.exe
          At the end of the packed code it says:
          .unpack("m")**.to_s**
          change it to read:
          .unpack("m")**[0]**
          Save the changes to each file.
          Restart SketchUp.
          It should now be v2014 AND earlier compatible...
            paddyclown
            TIG, thanks for stepping in !
            I tried your edit to the two files you indicated & this is what popped up...
            Error Loading File HouseBuilder_extension.rb
            Error: #<Errno::ENOENT: No such file or directory - C:/Program Files/SketchUp/SketchUp 2014/Plugins\HouseBuilder\housebuilder_sections.txt>
            (eval):40:in readlines' (eval):40:in hb_read_sections_file'
            (eval):23:in exec_on_autoload' C:/Users/patrick/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/HouseBuilder_extension.rb:197:in <top (required)>'
            bit odd, no ?
              paddyclown
              micione, thanks for the linked...
              yes this does work, but it's an imperial version... but i work in France, so metric needed... how do I get it to point to the metric lumber size file that came with the metric version ?
              thanks
                Bum!
                Do you have this file in the subfolder ?
                If so the packed code might include further typos that need fixing - NAG DIDIER !
                  paddyclown
                  yes, but i noticed that the error message mentioned a filepath that shouldnt exist in SU2014
                  but I created it anyhow to see what happens & bingo it worked !
                  so, to recap for those who need to fix this
                  first you do TIG's fix in notepad (cf higher up)
                  then you create the filepath as if there were a plugins folder like in the previous versions of SU & it will work !
                  best,
                    Sounds like Didier has ill-advisedly hard-coded a filepath, rather than use the location of the RB to get its folder to get the TXT file 😒
                    BUT because he's obfuscated it by 'packing' it - then we can't readily fix it !!
                    • christophe49250C Offline
                      christophe49250
                      [/quote]On dirait que Didier a malencontreusement codé en dur un filepath, plutôt que d' utiliser l'emplacement du RB pour obtenir son dossier pour obtenir le fichier TXT , :roulent:
                      mais parce qu'il est obscurcie par «emballage» - alors nous ne pouvons pas facilement résoudre le problème! ![quote] by TIG » Fri Mar 21, 2014 7:44 pm
                      Salut à tous,
                      je viens de trouver des fichiers de Didier en TXT et plein d'autre dans le dossier compresser,ce qui pourrai relancer le développement de ce super script. 😎
                      la version est "V1.2 métrique" que je suis arrivé a traduire en français pour / SketchUp 8 / (ça fonctionne très bien chez moi)
                      mais j'aimerai la faire tourner sur / SketchUp 2016 / Le problème...
                      Erreur de chargement du fichier HouseBuilder_extension.rb
                      Error: #<Errno::ENOENT: No such file or directory - C:/Program Files/SketchUp/SketchUp 2016/Plugins\HouseBuilder\housebuilder_sections.txt>
                      C:/Users/charrier/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/HouseBuilder/HouseBuilder.rb:41:in readlines' C:/Users/charrier/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/HouseBuilder/HouseBuilder.rb:41:in hb_read_sections_file'
                      C:/Users/charrier/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/HouseBuilder/HouseBuilder.rb:24:in exec_on_autoload' C:/Users/charrier/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/HouseBuilder_extension.rb:219:in <top (required)>'
                      quelqu'un à t'il des idées ? je suis assez nul en programmation.... 🤣
                      Dans le dossier joint il y tout les fichiers retravailler par rapport au fichier d'origine par une société de construction bois je crois...!!! et un certain appelé "decodeb64.rb" qui pourrai vous servir pour décodé les autres.Je ne sais pas comment ça marche...(lire le fichier) 😕
                      Les fichiers que je me suis servi pour traduire sont tous décoder dans le dossier.
                      Merci de vôtre aide experte.
                      HouseBuilder_Traduit_FR et métrique pour SU8
                        christophe49250
                        mais parce qu'il est obscurcie par «emballage» - alors nous ne pouvons pas facilement résoudre le problème! ![quote][quote]
                        Salut à tous,
                        je viens de trouvé des fichiers de Didier en TXT et plein d'autre dans le dossier joint,ce qui pourrai relancer le développement de ce Super script.
                                  - HouseBuilder_Traduit_FR pour SU8
                        Le problème sur SU2016
                        Dans le dossier joint il y tout les fichiers retravailler par rapport au fichier d'origine par une société de construction bois je crois...!!! et un certain appelé "decodeb64.rb" qui pourrai vous servir pour décodé les autres.Lire ce fichier pour les instructions.
                                  - HouseBuilder_extension.rb (traduit en français)
                                  - HouseBuilderTool.rb       (traduit en français)
                          christophe49250
                          Salut à tous,
                          je viens de trouver des fichiers de Didier en TXT et plein d'autre dans le dossier,ce qui pourrai relancer le développement de ce super script.
                          Le problème...sur SU2016
                          Dans le dossier joint il y tout les fichiers retravailler par rapport au fichier d'origine par une societé de construction bois je crois...!!! et un certain appelé "decodeb64.rb" qui pourrai vous servir pour décodé les autres.Lire ce fichier pour les instructions.
                            Unfortunately Didier has obfuscated the file and hard-coded the path assuming that there is a Plugins folder inside the main SketchUp folder.
                            It has not been in there for many SketchUp versions - it was in v8 - but you have v2016 !
                            It is in your users AppData location.
                            You can see that in the error message -
                            C:/Users/charrier/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins**/Housebuilder**
                            That's where the required file is found - housebuilder_sections.txt
                            The error is because it's looking for that file in:
                            C:/Program Files/SketchUp/SketchUp 2016**/Plugins/Housebuilder** !
                            The folders and file do not exist !
                            Can I suggest you do the following...
                            Add a new empty folder into C:/Program Files/SketchUp/SketchUp 2016
                            named Plugins
                            inside that add an empty folder named Housebuilder
                            Now copy the file housebuilder_sections.txt from the 'AppData' subfolder, and paste it into this new folder.
                            When SketchUp restarts it should find the file.
                            It might well be that other file-paths are getting lost in the hard-coding - if you do get other errors then they should be named in the error message, so look to find and copy those into this duplicate Housebuilder folder in the same manner...
                              christophe49250
                              ça ne marche pas.toujours la même erreur.
                              Mais pourquoi ne pas changer le chemin dans le fichier => HouseBuilder.rb (décodé) dans le .rar
                              merci de ton aide ...
                              • Didier BurD Offline
                                Didier Bur
                                Wait guys, just a little patience 😄
                                HouseBuilder is about to become SUFramer soon with lot of features (including exporting quantities to Excel).
                                DB
                                  christophe49250
                                  Merci Didier pour cette incroyable plugin.Je suis très impatient de le découvrir.... 😛
                                  Mais je me pose quelques question :
                                  -Il y aura t'il un version en français ? 💚
                                  -Il y aura t'il les fichiers non codé pour une traduction ?
                                  -Il y aura t'il les mêmes fonctionnalité que la dernière version ?
                                  -Ou pourra t'on trouver SUFramer a ça sortie ?
                                  Encore merci Didier.
                                    Didier Bur
                                    Bonjour Christophe:
                                    • Oui une version française est incluse (encore heureux...)
                                    • Il y aura un fichier de traduction non-codé pour tout autre langage.
                                    • Il y aura beaucoup plus de fonctionnalités et de types de pièces de bois que dans HouseBuilder, en saisie manuelle ou en automatique (murs, planchers, toits)
                                    • Types de bois: poteau, solive, linteau, lisse, chevron, planche de rive, contreventement, panne faitière.
                                    • On trouvera l'extension sur la 3D WareHouse.
                                    • Barre d'outils, de gauche à droite:
                                      saisie manuelle de pièces de bois,
                                      saisie de plancher
                                      trémie dans plancher
                                      mur
                                      porte
                                      fenêtre
                                      entretoises
                                      revêtements contreplaqué
                                      toit en shed ou à 2 pans
                                      toit plat
                                      export quantitatif vers Excel
                                      aide
                                    Je pense rendre le plugin compatible avec Estimator (d'où le délai avant publication)
                                    A+
                                    J'ai pas encore de date de sortie, je prends du retard en ce moment...
                                    DB
                                      Un complement de Medeek Truss 😉
                                        christophe49250
                                        Merci Didier cette version à vraiment l'aire d'être très travaillé 👍
                                        Bon courage pour la finalisation du projet.
                                        • jujuJ Offline
                                          juju
                                          Si je me souviens bien Medeek travaille sur quelque chose de similaire à "housebuilder" pour compléter son module "truss".
                                          Si l'une des réponses ci-dessus n'a pas de sens, blâmez Google Translate ...
                                          • facerF Offline
                                            facer
                                            Please use "Google Translate" to English for postings
                                            which will make postings "more user friendly" for English speaking members.
                                            Posting above by juju - using Google Translate:
                                            *If I remember correctly Medeek is working on something similar to "housebuilder" to complete his "truss" module.
                                            If one of the above answers does not make sense, blame Google Translate*
