    @#$%^&* edit SU model reference in LayOut
    Scheduled Pinned Locked Moved LayOut Feature Requests
    layout
    13 Posts 6 Posters 19.9k Views 6 Watching
    • pbacotP Offline
      Once again, please PLEASE just eliminate the double-click to edit SketchUp model reference in LayOut. Just bury that command somewhere. What a pain. Thank you.
      • Rich O BrienR Online
        The edit a component/group double click?
        • pbacotP Offline
          LayOut
            I really should pay attention to where topics are posted....
            • fouronethirtyF Offline
              fouronethirty
              its really painfull sir, . hopefully it goes away in the next ver. it does'nt help at all sir. only it changes is the view. but not a considerable aid in documents prep. i just hope it goes away in lo. its already good in scene selection to achieve the change in view of the model..
              may the bright minds realize that sir. thank you very much..
              • brettsichellodesignB Offline
                brettsichellodesign
                It is really annoying. I try and get round it by having all sketchup 'viewports' in a locked layer. This means you can't double click into them.
                • utilerU Offline
                  utiler
                  That's exactly what you should do. I import any Su reference on a layer called 'SketchUp Imports' and lock it unless I need to manipulate the viewport. That way working over the top of it is a breeze...
                  Just Curious...
                  • pbacotP Offline
                    Yes, that's what you need to do. It's still dumb.
                      brettsichellodesign
                      I have actually been using the click though viewport feature recently, here is why:
                      So I have a load of internal elevations of a building set up in parallel projection so I can dimension etc... However, I want to also have a 3D view of the elevations. I therefore, just make a copy of the viewport change it to ortho, and line it up as I want.
                      This means I don't have to go back to SU and make another scene. Saves time and scene space.
                      Just lock it after. The feature is still useful.
                      • pbacotP Offline
                        No problem having the command, but making it a double click option was not good.
                        • JQLJ Offline
                          JQL
                          That makes you loose link to sketchup scene. You get a model update, a camera update, but you have to manually update styles...I never do it as I also setup perspective scenes in su. I will try it again though as it has a lot of advantages.
                          That's what all of us MUST do, but locking a layer locks everything about a viewport. You can't scale it, rotate it, change scenes, not even reload it manually. It's not the solution.
                          Disabling the double click edit under preferences or specifically locking certain/all viewports edition, would be a fundamental change.
                          www.casca.pt
                          Visit us on facebook!
                            brettsichellodesign
                            Just have it in a right click menu would be a solution I think.
                            • JQLJ Offline
                              JQL
                              Agree!
                              www.casca.pt
