    How to cut from object
    47 Posts 4 Posters 6.9k Views 4 Watching
      ado130
      Thanks for comprehensive answer, I'll try it.
      In first point you describe, when the rectangular exist, is it good way?, or is better to do fillet while drawing?
      About notches
      		active_edges = model.active_entities.grep(Sketchup;;Edge)
      		edges = Sketchup.active_model.active_entities.add_circle(center, dir, radius)
      		new_edges = model.active_entities.grep(Sketchup;;Edge) - active_edges
      		togos = [] ### empty array
      		new_edges.each{|edge| togos << edge unless edge.faces[0] }
      		model.active_entities.erase_entities(togos) if togos[0]
      		fac = nil
      		new_edges[0].faces.each{|f|fac = f unless f.loops[1]}
      		fac.pushpull(-depth)
      It's not a whole code, but the rest is the same (see above).
      But still is there a problem.
        Do you run it with the Ruby Console open ?
        What are the error messages ?
        To see output at each stage add p in front of the operation...
        e.g.
        p active_edges = model.active_entities.grep(Sketchup::Edge) p edges = Sketchup.active_model.active_entities.add_circle(center, dir, radius) p new_edges = model.active_entities.grep(Sketchup::Edge) - active_edges ... p togos ... p fac
        To show how each has been set...
          ado130
          http://i.imgur.com/3ihSgfl.png
          237: new_edges[0].faces.each{|f|fac = f unless f.loops[1]}
          • sdmitchS
            sdmitch
            > 		fac = nil
            Problem
            1. .add_circle doesn't create a face only the bounding edges. new_edges=edges1. the circle is being added to the model context therefore there is no interaction with the entities in the group. add a group inside the original group. save the faces in original group. do the .add_circle inside the new group then explode it. this will cause the circle edges to merge with the original group and create the circle face. circle_face=current_faces-faces. delete new_edges that have no associated face.
            http://sdmitch.blogspot.com/
              Thanks Sam.
              Somewhere in the many iterations of this code... the circle in the group and its explosion got lost...
              After that it should work πŸ˜‰
                ado130
                I am slightly confused now πŸ˜„ because before you said
                You don't need to add the edges to a new group.
                raw it directly over the face in the active_entities.
                edges = Sketchup.active_model.active_entities.add_circle(center, dir, radius, segs)
                So what should I do?
                If I understood Sam correctly, I need sth like
                group = Sketchup.active_model.active_entities.add_group() gents = group.entities active_faces = model.active_entities.grep(Sketchup::Face) edges = gents.add_circle(center, dir, radius) group.explode circle_face = model.active_entities.grep(Sketchup::Face) - active_faces
                .. and then?
                I'm not sure what is meant by "add a group inside the original group".
                By the way, thanks Sam, or, thanks to both.
                • sdmitchS
                  sdmitch
                  .. and then?
                  ###group = Sketchup.active_model.active_entities.add_group();
                  ### remove previous statement since you have already defined "group".
                  active_faces = gents.grep(Sketchup;;Face);### modified
                  circle_group = gents.add_group; cge = circle_group.entities;### new
                  edges = cge.add_circle(center, dir, radius);### modified
                  circle_group.explode;### new
                  circle_face = (gents.grep(Sketchup;;Face) - active_faces)[0];### modified
                    ado130
                    I had never defined the group in this method previous.
                    This is what I have now:
                    def notch(x, y, z, radiuses, depths, directions)
                    	model = Sketchup.active_model
                    	countOfNotch = x.length.to_i
                    	countOfNotch.times do |i|
                    		center = [x[i], y[i], z[i]].map(&;to_f)
                    		radius = radiuses[i]
                    		depth = depths[i]
                    		direction = directions[i]
                    		case direction
                    			when "N"
                    				dir = Geom;;Vector3d.new(0,0,1)
                    			when "E"
                    				dir = Geom;;Vector3d.new(-1,0,0)
                    			when "S"
                    				dir = Geom;;Vector3d.new(0,0,-1)
                    			when "W"
                    				dir = Geom;;Vector3d.new(1,0,0)
                    			when "F"
                    				dir = Geom;;Vector3d.new(0,-1,0)
                    			when "B"
                    				dir = Geom;;Vector3d.new(0,1,0)
                    			else
                    		circle_face.pushpull(-depth)
                    Of cource, I define a group in method, where I draw a rectangel block, but it's independently. So first I call this method, it'll draw several blocks, and then, if is necessary (according to input file) I'll call a method for notch.
                      ado130
                      Hmm, I have one main method, one method for rectangle blocks and next method for cylinders, but in every of those methods I have
                      group = Sketchup.active_model.active_entities.add_group() entities = group.entities
                      so then i.e.
                      circle = entities.add_circle(center, dir, radius)
                      or
                      entities.add_line(ptA, ptB) etc bottom = entities.add_face(ptA, ptB, ptC, ptD)
                      So this is the wrong solution?
                      If I understand correctly, I need have group = Sketchup.active_model.active_entities.add_group() only in main method and then passed as a variable to other methods?
                      • sdmitchS
                        sdmitch
                        That being the case, group must be created as a module variable(@group) or defined in the same way it is in the other methods or passed as a variable to other methods. The previous code would have created an empty group.
                        • sdmitchS
                          sdmitch
                          so then i.e.
                          or
                          You have a group containing a rectangular block that you you want to "drill" holes in. In order to do that, you have to add a group inside that group to contain the circle defining the drill hole. After exploding the group containing the circle, the original group will contain the block, the drill hole outline, and hopefully the face that is to be pushpulled to create the drill hole.
                            ado130
                            So there are 2 solutions for this (I think)
                            1. save somewhere the group where will be notch
                            2. find that group somehow
                              because, when I do a dril, I'm using this
                            		group = nil
                            		face = nil
                            		Sketchup.active_model.entities.each{|g|
                            			next unless g.is_a?(Sketchup;;Group)
                            			g.entities.each{|f|
                            				next unless f.is_a?(Sketchup;;Face)
                            				if f.classify_point(center) == Sketchup;;Face;;PointInside then
                            					group = g
                            					face = f
                            2.) Exist a way how to find "my" group, where is the rectangular block, when the center point is outside that block?
                            • sdmitchS
                              sdmitch
                              		group = nil
                              > 		face = nil
                              > 			g.entities.each{|f|
                              > 					group = g
                              > 					face = f
                              > 				end
                              Perhaps
                              if center.on_plane f.plane then
                              	group = g
                              	face = f
                                ado130
                                It almost works, but the result is
                                http://i.imgur.com/RMnKEB6.png
                                		depth = depths[i]
                                		case direction
                                			when "N"
                                			when "E"
                                			when "S"
                                			when "W"
                                			when "F"
                                			when "B"
                                			else
                                		group = nil
                                			g.entities.each{|f|
                                				if center.on_plane? f.plane then
                                					group = g
                                It works only if the cylinder's face is whole on the block.
                                It "works", if I have two blocks on each other
                                http://i.imgur.com/kAnKpQY.png
                                • sdmitchS
                                  sdmitch
                                  In the second image, are both blocks in the same group? If so two new faces will be created and only one is being pushpulled.
                                    ado130
                                    No, they aren't. I know it's a problem and if I will do drill into 2 blocks, they need to be in the same group. But for now, the problem is first image. It looks like, pushpull tools pushpull the block and not cylinder(drill/notch).
                                    It works!! I had a little bug in my input file.
                                    So final code is
                                    		group = nil
                                    			g.entities.each{|f|
                                    					group = g
                                    		togos = []
                                    Many many many thanks to both!
                                    Maybe a question about the second image, is it possible do it somehow?
                                    i.e.: Even if they are 4 blocks next to each (2x2 matrix) and create a hole in the middle.
                                    It occurred to me, try to apply this method twice (or more, if there will be more blocks next to each other).
                                    Or maybe 2nd solution, make a temporary group with all common groups/faces where will be a hole.
                                    Edit:
                                    So, I edited it
                                    		groups = []
                                    		i = 0
                                    			g.entities.each{|f|
                                    					groups.each {|x| next if g == x}
                                    					groups[i] = g
                                    					i += 1
                                    		groups = groups.uniq
                                    		countOfGroups = groups.length.to_i
                                    		countOfGroups.times do |i|
                                    			group = groups[i]
                                    			next if circle_face == nil
                                    			togos = []
                                    http://i.imgur.com/GDdGN4p.png
                                    It "works", but there is a problem, if I need do a drill over 3 (more) blocks.
                                    Or when I have 4 blocks, etc..
                                    http://i.imgur.com/o0xkiYw.png
                                    I found that after this circle_face = (gents.grep(Sketchup::Face) - active_faces), there are two faces, so I tried ".last", it helped, but still don't work at well.
                                    http://i.imgur.com/J8tQrBb.jpg
                                    Aby ideas?
                                      ado130
                                      It seems that it works. Is it correct way?
                                      Just one question, how can I delete the black lines?, or hide them.
                                      def drill(x, y, z, radiuses, depths, directions)
                                      	countOfDrills = x.length.to_i
                                      	countOfDrills.times do |i|
                                      		depth = depths[i]
                                      		case direction
                                      			when "N"
                                      			when "E"
                                      			when "S"
                                      			when "W"
                                      			when "F"
                                      			when "B"
                                      			else
                                      		groups = []
                                      		i = 0
                                      			g.entities.each{|f|
                                      					groups[i] = g
                                      					i += 1
                                      			group = groups[i]
                                      			activeFaces = gents.grep(Sketchup;;Face)
                                      			circleGroup = gents.add_group; cge = circleGroup.entities
                                      			circleGroup.explode
                                      			circleFace = (gents.grep(Sketchup;;Face) - activeFaces).last
                                      			next if circleFace == nil
                                      			normal = circleFace.normal
                                      			circleFace.pushpull(-depth)
                                      			deleteFace = (gents.grep(Sketchup;;Face) - activeFaces)[0]
                                      			if deleteFace.normal == normal then
                                      				deleteFace.erase!
                                      • sdmitchS
                                        sdmitch
                                        Try this
                                         group = groups[i]
                                         circleGroup.explode;
                                         (gents.grep(Sketchup;;Face) - activeFaces).each{|circleFace|
                                          next if center.distance(circleFace.bounds.center) > radius
                                         remove = gents.grep(Sketchup;;Edge).find_all{|e|e.faces.length<2}
                                         gents.erase_entities(remove.reverse)
                                          ado130
                                          It seems that it works too. Thanks!
                                          But black lines are still there.
                                          You have there "]", I think, it should be "}"?
                                          • sdmitchS
                                            sdmitch
                                            Yes, you are right. Sorry about that.
                                            The black vertical lines in the 'drill hole'?
                                            • 2 / 3
