    How to cut from object
    47 Posts 4 Posters 7.7k Views 4 Watching
      ado130
      I am slightly confused now πŸ˜„ because before you said
      You don't need to add the edges to a new group.
      raw it directly over the face in the active_entities.
      edges = Sketchup.active_model.active_entities.add_circle(center, dir, radius, segs)
      So what should I do?
      If I understood Sam correctly, I need sth like
      group = Sketchup.active_model.active_entities.add_group() gents = group.entities active_faces = model.active_entities.grep(Sketchup::Face) edges = gents.add_circle(center, dir, radius) group.explode circle_face = model.active_entities.grep(Sketchup::Face) - active_faces
      .. and then?
      I'm not sure what is meant by "add a group inside the original group".
      By the way, thanks Sam, or, thanks to both.
      • sdmitchS
        sdmitch
        .. and then?
        ###group = Sketchup.active_model.active_entities.add_group();
        ### remove previous statement since you have already defined "group".
        active_faces = gents.grep(Sketchup;;Face);### modified
        circle_group = gents.add_group; cge = circle_group.entities;### new
        edges = cge.add_circle(center, dir, radius);### modified
        circle_group.explode;### new
        circle_face = (gents.grep(Sketchup;;Face) - active_faces)[0];### modified
        http://sdmitch.blogspot.com/
          ado130
          I had never defined the group in this method previous.
          This is what I have now:
          def notch(x, y, z, radiuses, depths, directions)
          	model = Sketchup.active_model
          	countOfNotch = x.length.to_i
          	countOfNotch.times do |i|
          		center = [x[i], y[i], z[i]].map(&;to_f)
          		radius = radiuses[i]
          		depth = depths[i]
          		direction = directions[i]
          		case direction
          			when "N"
          				dir = Geom;;Vector3d.new(0,0,1)
          			when "E"
          				dir = Geom;;Vector3d.new(-1,0,0)
          			when "S"
          				dir = Geom;;Vector3d.new(0,0,-1)
          			when "W"
          				dir = Geom;;Vector3d.new(1,0,0)
          			when "F"
          				dir = Geom;;Vector3d.new(0,-1,0)
          			when "B"
          				dir = Geom;;Vector3d.new(0,1,0)
          			else
          		circle_face.pushpull(-depth)
          Of cource, I define a group in method, where I draw a rectangel block, but it's independently. So first I call this method, it'll draw several blocks, and then, if is necessary (according to input file) I'll call a method for notch.
            ado130
            Hmm, I have one main method, one method for rectangle blocks and next method for cylinders, but in every of those methods I have
            group = Sketchup.active_model.active_entities.add_group() entities = group.entities
            so then i.e.
            circle = entities.add_circle(center, dir, radius)
            or
            entities.add_line(ptA, ptB) etc bottom = entities.add_face(ptA, ptB, ptC, ptD)
            So this is the wrong solution?
            If I understand correctly, I need have group = Sketchup.active_model.active_entities.add_group() only in main method and then passed as a variable to other methods?
            • sdmitchS
              sdmitch
              That being the case, group must be created as a module variable(@group) or defined in the same way it is in the other methods or passed as a variable to other methods. The previous code would have created an empty group.
              • sdmitchS
                sdmitch
                so then i.e.
                or
                You have a group containing a rectangular block that you you want to "drill" holes in. In order to do that, you have to add a group inside that group to contain the circle defining the drill hole. After exploding the group containing the circle, the original group will contain the block, the drill hole outline, and hopefully the face that is to be pushpulled to create the drill hole.
                  ado130
                  So there are 2 solutions for this (I think)
                  1. save somewhere the group where will be notch
                  2. find that group somehow
                    because, when I do a dril, I'm using this
                  		group = nil
                  		face = nil
                  		Sketchup.active_model.entities.each{|g|
                  			next unless g.is_a?(Sketchup;;Group)
                  			g.entities.each{|f|
                  				next unless f.is_a?(Sketchup;;Face)
                  				if f.classify_point(center) == Sketchup;;Face;;PointInside then
                  					group = g
                  					face = f
                  2.) Exist a way how to find "my" group, where is the rectangular block, when the center point is outside that block?
                  • sdmitchS
                    sdmitch
                    		group = nil
                    > 		face = nil
                    > 			g.entities.each{|f|
                    > 					group = g
                    > 					face = f
                    > 				end
                    Perhaps
                    if center.on_plane f.plane then
                    	group = g
                    	face = f
                      ado130
                      It almost works, but the result is
                      http://i.imgur.com/RMnKEB6.png
                      		depth = depths[i]
                      		case direction
                      			when "N"
                      			when "E"
                      			when "S"
                      			when "W"
                      			when "F"
                      			when "B"
                      			else
                      		group = nil
                      			g.entities.each{|f|
                      				if center.on_plane? f.plane then
                      					group = g
                      It works only if the cylinder's face is whole on the block.
                      It "works", if I have two blocks on each other
                      http://i.imgur.com/kAnKpQY.png
                      • sdmitchS
                        sdmitch
                        In the second image, are both blocks in the same group? If so two new faces will be created and only one is being pushpulled.
                          ado130
                          No, they aren't. I know it's a problem and if I will do drill into 2 blocks, they need to be in the same group. But for now, the problem is first image. It looks like, pushpull tools pushpull the block and not cylinder(drill/notch).
                          It works!! I had a little bug in my input file.
                          So final code is
                          		group = nil
                          			g.entities.each{|f|
                          					group = g
                          		togos = []
                          		edges.each{|edge| togos << edge unless edge.faces[0] }
                          		model.active_entities.erase_entities(togos) if togos[0]
                          Many many many thanks to both!
                          Maybe a question about the second image, is it possible do it somehow?
                          i.e.: Even if they are 4 blocks next to each (2x2 matrix) and create a hole in the middle.
                          It occurred to me, try to apply this method twice (or more, if there will be more blocks next to each other).
                          Or maybe 2nd solution, make a temporary group with all common groups/faces where will be a hole.
                          Edit:
                          So, I edited it
                          		groups = []
                          		i = 0
                          			g.entities.each{|f|
                          					groups.each {|x| next if g == x}
                          					groups[i] = g
                          					i += 1
                          		groups = groups.uniq
                          		countOfGroups = groups.length.to_i
                          		countOfGroups.times do |i|
                          			group = groups[i]
                          			next if circle_face == nil
                          			togos = []
                          http://i.imgur.com/GDdGN4p.png
                          It "works", but there is a problem, if I need do a drill over 3 (more) blocks.
                          Or when I have 4 blocks, etc..
                          http://i.imgur.com/o0xkiYw.png
                          I found that after this circle_face = (gents.grep(Sketchup::Face) - active_faces), there are two faces, so I tried ".last", it helped, but still don't work at well.
                          http://i.imgur.com/J8tQrBb.jpg
                          Aby ideas?
                            ado130
                            It seems that it works. Is it correct way?
                            Just one question, how can I delete the black lines?, or hide them.
                            def drill(x, y, z, radiuses, depths, directions)
                            	countOfDrills = x.length.to_i
                            	countOfDrills.times do |i|
                            		depth = depths[i]
                            		case direction
                            			when "N"
                            			when "E"
                            			when "S"
                            			when "W"
                            			when "F"
                            			when "B"
                            			else
                            		groups = []
                            		i = 0
                            			g.entities.each{|f|
                            					groups[i] = g
                            					i += 1
                            			group = groups[i]
                            			activeFaces = gents.grep(Sketchup;;Face)
                            			circleGroup = gents.add_group; cge = circleGroup.entities
                            			circleGroup.explode
                            			circleFace = (gents.grep(Sketchup;;Face) - activeFaces).last
                            			next if circleFace == nil
                            			normal = circleFace.normal
                            			circleFace.pushpull(-depth)
                            			deleteFace = (gents.grep(Sketchup;;Face) - activeFaces)[0]
                            			if deleteFace.normal == normal then
                            				deleteFace.erase!
                            • sdmitchS
                              sdmitch
                              Try this
                               group = groups[i]
                               circleGroup.explode;
                               (gents.grep(Sketchup;;Face) - activeFaces).each{|circleFace|
                                next if center.distance(circleFace.bounds.center) > radius
                               remove = gents.grep(Sketchup;;Edge).find_all{|e|e.faces.length<2}
                               gents.erase_entities(remove.reverse)
                                ado130
                                It seems that it works too. Thanks!
                                But black lines are still there.
                                You have there "]", I think, it should be "}"?
                                • sdmitchS
                                  sdmitch
                                  Yes, you are right. Sorry about that.
                                  The black vertical lines in the 'drill hole'?
                                    ado130
                                    Yeah, you're right, but I meant black lines in rectangular blocks (rather, all lines).
                                    • sdmitchS
                                      sdmitch
                                      @ado130 said:
                                      Yeah, you're right, but I meant black lines in rectangular blocks.
                                      Well, if you didn't want them, why did you create then in the first place.
                                      	group = groups[i]; group.make_unique
                                      	activeEdges = gents.grep(Sketchup;;Edge);#<-- save active edges
                                         #remove unused circle edges
                                      	# hide vertical edges in drill hole
                                      	soften = (gents.grep(Sketchup;;Edge)-activeEdges).find_all{|e|e.line[1].parallel?(dir) && !e.soft?}
                                      	soften.each{|e|e.soft=e.smooth=true}
                                      	# remove co-planar edges
                                      	remove = gents.grep(Sketchup;;Edge).find_all{|e|(e.faces.length>=2 && e.faces.find_all{|f|f.normal.parallel?(e.line[1].axes[1])}.length==2)}
                                        ado130
                                        Sorry for the delayed response. It looks fine, thanks again!
                                        http://i.imgur.com/TtoBovE.png
                                        • 2 / 3
