    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Smoothing advice? Updated
    23 Posts 6 Posters 4.6k Views 6 Watching
    • Bryan KB Offline
      Thanks Elesei. I'll try that and post the results in a few days. (I did not download the model, but I very much appreciate you making it available.)
      Also thanks to everyone else for their help and advice!
      • Bryan KB Offline
        Working almost prefect. Except... what the heck is that?
        • ely862meE Offline
          ely862me
          See the hidden geometry, most likely an edge snapped.
          Elisei (sketchupper)
          Come and See EliseiDesign
          • ely862meE Offline
            ely862me
            There is something. If I recall well, you have there a small segment that creates a small crease throughout the body. If you remove that segment I believe it will be alright.
            It doesn't matter how far the sections are it will create the same amount of segmentation.
            • Bryan KB Offline
              Thanks Elisei. I did look at the hidden the geometry but I did not see anything obvious.
              I think I may have the 2 vertical sections just slightly too far apart. I'm going to try moving them closer together and see what happens.
              • Bryan KB Offline
                Cool. I'll check that. It's supposed to be a smooth transition from a curve to straight line. If it's not, then the result would make sense.
                • Bryan KB Offline
                  After much playing around and thanks to everyone's advice, here's what I ended up and pretty much exactly what I wanted.
                    I think you will find the remaining 'lines' around the hull are bulkheads, they can be deleted to improve the shape further.
                    • Bryan KB Offline
                      Thanks, yes, that's exactly what they are. ๐Ÿ‘
                      • Bryan KB Offline
                        Here's how the shape is evolving.
                        • 2 / 2
