    Light at the end of the tunnel
    33 Posts 9 Posters 9.7k Views 9 Watching
    • LA_RR_ArchitectL Offline
      LA_RR_Architect
      Hello Guys, thanks for the encouragement.
      Last couple days I've started adding the final few systems... I'm down to brakes and the power reverse gear, then it's piping, handrails and finishing up. With luck another week has the modeling phase done then I can look at a bit of rendering. I'll post more in a day or so when the progress is enough to see the difference.
      Jim
        LA_RR_Architect
        With luck, the final update before completion. I'm still missing the brake system and a fair amount of plumbing but otherwise, all major systems (external only) are represented.
        I've added a fair amount of detail, but as the grain gets smaller, it is a bit hard to see.
        With luck the modeling portion of the effort will be done this week.
        So again, without further ado, the pictures...
        Elevation of the engineer's side
        ...and a perspective of the same side.
        Perspective from the fireman's side
        ...and a final elevation.
        Enjoy, and as usual comments and suggestions are appreciated.
        Jim
        • Bryan KB Offline
          I'm going to have to take your word that brakes and some piping are missing, because I would never notice in a million years.
          Excellent model. Astonishing detail. Are you going to render it?
            LA_RR_Architect
            That's the thing about these machines... a huge part of the detail is hanging on the outside. The challenge is figuring out how to represent the important bits and what can be left out (there is a lot that's been simplified or omitted) and to still get a realistic model in the end.
            Yes, I'll render it in a bit. I have a couple location models where it will fit nicely.
            Thanks for the encouragement.
            Jim
              LA_RR_Architect
              Fellow SU fans.
              It's my pleasure (or relief) to announce that the white phase of my locomotive is done.
              Perhaps more accurately, I've decided to stop embellishing the model as I can certainly find many additional features to add or refine.
              The craziness needs to end somewhere.
              Next will be a thin veneer of color and texture. Afterall, in the end, it's mostly black.
              Here's how she looks now...
              Fireman's side from the front...
              Engineer's (driver's) side from the front...
              Engineer's side from the rear...
              ...and again, fireman's side from beside the tender.
              Hope you all enjoy...
              Jim
              • tuna1957T Offline
                tuna1957
                Simply amazing work ! πŸ‘ πŸ‘
                  LA_RR_Architect
                  Hello Tuna... thanks for the comment. Been staring at the screen long enough... maybe I'll head to the beach.
                  Here she is in color.
                  These are generally the correct colors but not exactly what I want. The colors and textures assigned here will be used to set up renderings in a bit.
                  ...still, looks pretty much like a locomotive...
                  From Sketchup without textures.
                  More once the renders begin to come in.
                  Jim
                  • alvisA Offline
                    alvis
                    • DanielD Offline
                      Daniel
                      Incredible bit of modeling.
                      My avatar is an anachronism.
                        LA_RR_Architect
                        Hey everybody, thanks for looking and for the encouragement!
                        Here are a couple of my first rendering "rushes"
                        From the front
                        ...from the tender end, this time on tracks.
                        And here's how the B & M 4115 fits into my growing fleet of railroad rolling stock models...
                        The entire fleet
                        She's definitely the biggest and most complex to date.
                        I hope you enjoy
                        Jim
                        • deaneauD Offline
                          deaneau
                          Jim, really awesome work. next project the Big Boy? πŸ˜„
                            LA_RR_Architect
                            Thanks for the comments.
                            Next project? Too many choices.
                            I hadn't thought the Big Boy possible, but maybe...
                            And if that, well, I'm a bit of a Pennsylvania fan... perhaps if I can find drawings a T1 or even a GG1 - that would be a change. Then again perhaps an SP cab forward or a DMIR Yellowstone.
                            I'm also on the look out for plans for a refrigerator car and a flat car and as always, interesting railroad structures.
                            Too many choices, too little time.
                            I'll leave you with a final image for now. This is generally what I build these models for.
                            The 4115 joins its mates at the coal dock, taking on a load of fuel for the day's work.
                            Then again, I think my laptop is dying... maybe a new computer first.
                            Jim
                            • deaneauD Offline
                              deaneau
                              hi jim could be its the right what you are looking for.
                              about Big Boy. i was joking πŸ˜‰
                              what render engine youΒ΄re use?
                              (www.nwhs.org)
                              or this on
                              http://sarplans.steam4me.net/
                              on this site i have found only a 4 wheel refrigerator car
                              some times you can find anything on model rail road pages, too.
                              http://sarplans.steam4me.net/images/SAR_Rollingstock_70.gif
                              screenshot by yellowdoor_[0001] 2016_09_03_-_20_05_10.jpgscreenshot by yellowdoor_[0001] 2016_09_03_-_20_05_21.jpg
                                LA_RR_Architect
                                Hi, thanks for the suggestions...
                                • I understood that it was a joke, but then I got to thinking. Modeling a Big Boy would be only a bit more complicated than the B&M 4-8-2. Since the Big Boy is a 4-8-8-4, the two gangs of cylinders, rods and driving wheels are copies of each other. The model would be bigger but all I would really need to add is the extra pair of wheels in the trailing truck and a bit more piping. As an added bonus, the centipede tender used on the B&M locomotive is nearly identical to that used on the Big Boy.
                                A few years ago I bought AutoCAD and Revit licenses. 3D Max came with them... so that's what I use. Like all AutoDesk products it's too big and bulky but produces pretty good results.
                                *https://www.nwhs.org/archivesdb/selectd ... x=co&id=69
                                or this on
                                some times you can find anything on model rail road pages, too.*
                                Thanks for the pointers to on-line drawings... Right now my problem is getting on top of the failing graphics card in my lap top. Once that's beaten, I can look at more modeling.
                                ...and by the way, those were two pretty nice water colors!
                                • deaneauD Offline
                                  deaneau
                                  i think in generally, that is more complicate to design a steamloco.
                                  it must be very impressed to see an american steam loco in original.
                                  all engines and cars are a little bit bigger than in europe πŸ˜„
                                  good look for your next project and i hope you will find the right refrigerator and flate car you need.
                                  here the Big Boy (for all readers doesn't know the Big Boy)
                                  here a photo to see how big the boy is.
                                  http://i.dailymail.co.uk/i/pix/2014/05/05/article-2620530-1D932AB900000578-850_964x466.jpg
                                  • Bryan KB Offline
                                    Wow. Just wow, LA_RR_Architect.
                                      LA_RR_Architect
                                      Well good people, thanks for looking in and the comments.
                                      ...still no "Big Boy" yet or flatcar for that matter, but I did come up with plans for a "reefer" or iced refrigerator car. Here she is...
                                      My white Sketchup model...
                                      ...what she looks like in 3dMax...
                                      ...and 4115 pulling a pair of reefers across Gloucester drawbridge.
                                      That's it for now, enjoy.
                                      Jim
                                      • ntxdaveN Offline
                                        ntxdave
                                        Really nice!! πŸ‘ πŸ‘
                                        Wish I could do stuff like that.
                                        Press F1...thank me later
                                          LA_RR_Architect
                                          A couple more progress images...
                                          Still pushing the plumbing and operating hardware largely from front to back, I've also blocked out the cab and tender body.
                                          Beginning to get a feel for the bulk of this heavy weight.
                                          Full length perspective view
                                          ...and an orthographic side elevation.
                                          Still a long way to go but perhaps there really is light at the end of the tunnel. In any case, I'm really wanting to see a rendered view of this brute.
                                          As usual, more coming.
                                          Regards
                                          Jim
                                          • Bryan KB Offline
                                            Truly top notch modeling.
                                            • 2 / 2
