    Light at the end of the tunnel
    33 Posts 9 Posters 9.4k Views 9 Watching
    • LA_RR_ArchitectL Offline
      LA_RR_Architect
      Last couple days I've started to block out the boiler and several of the more curious lumps on top (from front to back they are: the feed water heater, the funnel, the sand dome and the steam dome). Lots more to come.
      Tuna, I'm working primarily from a set of quite detailed drawings summarizing the locomotive for model builders... about a dozen drawings, as well as many photographs and internet research on specific systems, e.g. the feed water heater.
      So without further ado progress...
      The huge boiler of a serious steamer...
      Beginning to have an interesting face as well...
      There are typically some interesting complex curvy bits to work out.
      ...and on we go...
      I'll post more as it develops.
      Thanks for looking
      Jim
        LA_RR_Architect
        Gradually working, largely from front to back adding various operational bits and a lot of plumbing...
        Still nothing behind the boiler, but getting there
        It's actually a bit addictive... but I need to take a break now.
        Jim
          A work of art, perhaps you could get this displayed at the museum of steam in York, Yorkshire. Or any other museum to steam. Definitely up there with anything pro or not.
          • tuna1957T Offline
            tuna1957
            just keeps getting better πŸ‘ πŸ‘
            • Bryan KB Offline
              Absolutely amazing, stunning detail.
              How many hours have put into this already?
                LA_RR_Architect
                Hello,
                Thanks one and all for looking and for your comments.
                These things have become something of a hobby for me. Originally intended as simple entourage or background for models of historic railway buildings, these railroad pieces have grown into a project on their own.
                I certainly put a fair amount of research into them but don't think they quite rise to the level of museum pieces yet.
                This is definitely my most complicated locomotive to date. I suspect the project will take a couple weeks of on and off effort.
                ...but thanks for looking and for the encouragement.
                Jim
                  LA_RR_Architect
                  I've made a bit more progress at the front and around the cab where the gap between cab and tender is gradually being filled. At the front we now have a bell and headlight to complement the whistle. Added a good sprinkling of bolts and rivets as well.
                  From the front with illuminated number boards on the head lamp and a cast number under the bell.
                  ...and a cab view.
                  Hope you enjoy... the process is fun but I'm afraid a bit slow.
                  Jim
                  • ely862meE Offline
                    ely862me
                    Gotta' love it !
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                    • Bryan KB Offline
                      Weeks? This would take me months! My most complicated projects take me an average of 180+ hours.
                      It's why I don't post a lot. 😎
                        LA_RR_Architect
                        Hello Guys, thanks for the encouragement.
                        Last couple days I've started adding the final few systems... I'm down to brakes and the power reverse gear, then it's piping, handrails and finishing up. With luck another week has the modeling phase done then I can look at a bit of rendering. I'll post more in a day or so when the progress is enough to see the difference.
                        Jim
                          LA_RR_Architect
                          With luck, the final update before completion. I'm still missing the brake system and a fair amount of plumbing but otherwise, all major systems (external only) are represented.
                          I've added a fair amount of detail, but as the grain gets smaller, it is a bit hard to see.
                          With luck the modeling portion of the effort will be done this week.
                          So again, without further ado, the pictures...
                          Elevation of the engineer's side
                          ...and a perspective of the same side.
                          Perspective from the fireman's side
                          ...and a final elevation.
                          Enjoy, and as usual comments and suggestions are appreciated.
                          Jim
                          • Bryan KB Offline
                            I'm going to have to take your word that brakes and some piping are missing, because I would never notice in a million years.
                            Excellent model. Astonishing detail. Are you going to render it?
                              LA_RR_Architect
                              That's the thing about these machines... a huge part of the detail is hanging on the outside. The challenge is figuring out how to represent the important bits and what can be left out (there is a lot that's been simplified or omitted) and to still get a realistic model in the end.
                              Yes, I'll render it in a bit. I have a couple location models where it will fit nicely.
                              Thanks for the encouragement.
                              Jim
                                LA_RR_Architect
                                Fellow SU fans.
                                It's my pleasure (or relief) to announce that the white phase of my locomotive is done.
                                Perhaps more accurately, I've decided to stop embellishing the model as I can certainly find many additional features to add or refine.
                                The craziness needs to end somewhere.
                                Next will be a thin veneer of color and texture. Afterall, in the end, it's mostly black.
                                Here's how she looks now...
                                Fireman's side from the front...
                                Engineer's (driver's) side from the front...
                                Engineer's side from the rear...
                                ...and again, fireman's side from beside the tender.
                                Hope you all enjoy...
                                Jim
                                • tuna1957T Offline
                                  tuna1957
                                  Simply amazing work ! πŸ‘ πŸ‘
                                    LA_RR_Architect
                                    Hello Tuna... thanks for the comment. Been staring at the screen long enough... maybe I'll head to the beach.
                                    Here she is in color.
                                    These are generally the correct colors but not exactly what I want. The colors and textures assigned here will be used to set up renderings in a bit.
                                    ...still, looks pretty much like a locomotive...
                                    From Sketchup without textures.
                                    More once the renders begin to come in.
                                    Jim
                                    • alvisA Offline
                                      alvis
                                      • DanielD Offline
                                        Daniel
                                        Incredible bit of modeling.
                                        My avatar is an anachronism.
                                          LA_RR_Architect
                                          Hey everybody, thanks for looking and for the encouragement!
                                          Here are a couple of my first rendering "rushes"
                                          From the front
                                          ...from the tender end, this time on tracks.
                                          And here's how the B & M 4115 fits into my growing fleet of railroad rolling stock models...
                                          The entire fleet
                                          She's definitely the biggest and most complex to date.
                                          I hope you enjoy
                                          Jim
                                          • deaneauD Offline
                                            deaneau
                                            Jim, really awesome work. next project the Big Boy? πŸ˜„
