    Push-Pull face not on axis
    4 Posts 2 Posters 501 Views 2 Watching
    • jgillickJ Offline
      jgillick
      I an working on an arched cathedral window wall, pushing faces that represent mortar joints. The faces push as expected except when I get to those in the area of the arch. I have tried the normal push-pull, joint push-pull and follow-me but have failed to push the mortar joint faces in the attached model. Help!
      Arched Window Wall.skp
      • cottyC Offline
        cotty
        You won't be able to push those faces because of these angles...
        But you can joint push pull the bottom part:
        and erase the front faces, draw some connecting edges from top to bottom to fill the hole...
        Just out of interest: how did you create the arch to get that many hidden edges?
        my SketchUp gallery
        • cottyC Offline
          cotty
          Maybe this can be an alternative to construct those pushpulls?
          click to animate
          my SketchUp gallery
          • jgillickJ Offline
            jgillick
            cotty
            I used the scale tool
