    List of entities and organisation ?
    4 Posts 4 Posters 1.1k Views 4 Watching
    • IltisI
      Iltis
      Hello,
      Do you know if there is a schematic/list of the SketchUp geometrical entities and of their relationships?
      For example : ArcCurve (arcs and circles) is a subclass of the Curve class, and an edge is a part of a random curve if edge.curve return a curve, and a part of an arccurve if edge.curve return an arccurve.
      Best regards,
      Renaud.
        http://www.sketchup.com/intl/en/developer/docs/classes.php
          The new docs (work in process) will make the class hierarchy clearer: http://ruby.sketchup.com/
          • Dan RathbunD
            Dan Rathbun
            And this diagram is a bit out of date. (There are some missing classes, and perhaps changes since it was drawn back in the v7 and v8 days.)
            http://www.sketchup.com/intl/en/developer/docs/diagram.php
            Also,...
            @iltis said:
            For example : ArcCurve (arcs and circles) is a subclass of the Curve class, and an edge is a part of a random curve ...
            Implies an incorrect assumption.
            The SKP document object hierarchy (ie, the model database tree) is a wholly separate construct than the Ruby class hierarchy and relationships.
            For example, the Sketchup::Edge class is not a sub-class of the Sketchup::Curve class. Both, are descendants of the Sketchup::Entity class. Sketchup::Curve and Sketchup::ArcCurve objects are special collection classes that connect edges together, but are not themselves an actual "model element". Sketchup::Edge objects are an actual model element, and so are a sub-class of Sketchup::Drawingelement.
            I'm not here much anymore.
