    3D Truss Models
    1.5k Posts 32 Posters 1.9m Views 31 Watching
    • medeekM
      medeek
      Version 1.6.6- 07.15.2016
      • Added roof battens option within the advanced options menu for common, scissor and vaulted trusses.
      • Battens can be offset from the fascia board.
      • Battens at peak option enabled.
      http://design.medeek.com/resources/images/truss_su148_800.jpg
      View model here:
      3D Warehouse
      (3dwarehouse.sketchup.com)
      Currently this feature is only available for truss roofs, I still need to add it to hip and gable rafter roofs.
      If sheathing is enabled with battens, the battens are placed on top of the sheathing.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • jujuJ
        juju
        thanks for the constant development!
        • medeekM
          medeek
          @Juju
          This latest update was per your request. You will have to tell me if I got it right or not. If you offset from the fascia this moves all the battens up the roof. I don't know if this is the correct behavior that you want or intended.
          The battens at the peak are butted together. Looking at the different details I see that a gap between the peak battens might be more typical.
          I run the battens from the outside of the rake to the outside of the rake, is this correct?
          I've never seen battens placed under the sheathing but I suppose I could also make that an option.
          Currently the battens are placed on top of the sheathing if the sheathing option is "YES".
          I can provide options/input for more user control over some of these details, I just need further feedback or corrections.
          design.medeek.com
          • medeekM
            medeek
            Battens with sheathing:
            https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=0533cf8a-07b1-4eb4-afbf-67a86bc2d251
            View model here:
            3D Warehouse
            design.medeek.com
            • medeekM
              medeek
              In some cases vertical counter-battens are used when sheathing is applied under the battens. It appears that the counter battens usually line up with the truss or rafters. I will need to include three more options in the batten menu:
              Counter Battens: YES/NO
              Counter Batten Height:
              Counter Batten Width:
              https://www.twistfix.co.uk/images/pictures/artwork/news/counterbattens-for-warm-roofing-(page-picture-large).jpg
              http://inspectapedia.com/BestPractices/Figure2-21.jpg
              design.medeek.com
              • medeekM
                medeek
                Version 1.6.7 - 07.21.2016
                • Added a counter battens option within the battens menu for common, scissor and vaulted trusses.
                http://design.medeek.com/resources/images/truss_su149_800.jpg
                View model here:
                3D Warehouse
                Counter battens can be applied with our without sheathing. The counter battens are centered on the trusses below therefore their spacing is not independently controlled.
                Based on my research it appears that counter battens are usually only applied when battens are laid on top of a sheathed roof. However I have left the option open to apply them without the sheathing in case one wanted to apply them directly to the truss top chords over a vapor barrier.
                design.medeek.com
                • jujuJ
                  juju
                  @medeek said:
                  @Juju
                  Hi Nathan,
                  I only had time now to test the battens / purlins for the first time. It works like a charm, thank you.
                  I would still like to be able to offset the topmost purlin / batten from the apex, as one can with the lowest one at the fascia. Also I wouldn't mind having an option to equally space the battens / purlins between these two points.
                  • medeekM
                    medeek
                    • Battens (at peak) can be offset from peak.
                    • Peak-to-Eave spacing option available when "battens at peak" option is selected.
                    This was a very small update so I just tucked it into the latest revision.
                    http://design.medeek.com/resources/images/truss_su151_800.jpg
                    View model here:
                    3D Warehouse
                    design.medeek.com
                    • medeekM
                      medeek
                      I can add another input field into the menu which will allow the offset from the peak:
                      Offset from Peak (mm):
                      I can also put in another option that will allow for the equal spacing between peak and eave battens with the spacing input serving as the max. batten spacing if this option is enabled:
                      Spacing Peak-to-Eave: YES/NO
                      I think this will then give you the flexibility you need to make this feature actually useful in real world applications.
                      Another thing to note is that the battens will work with the roof returns option but I currently have no logic in place to deal with the extension at the eave. I may need to give this some more thought:
                      http://design.medeek.com/resources/images/truss_su150_800.jpg
                      As I add more advanced options and features it is sometimes tricky to make sure they all play well together.
                      design.medeek.com
                      • medeekM
                        medeek
                        I've been working on a Trim and Extend tool that will allow one to trim or extend a member (ie. rafter) to a face of another member (the face will define the plane). Since I don't yet have advanced roofs figured out this feature would come in very handy where roof primitives are initially used to generate the roof geometry and then some manual intervention is necessary.
                        I'm still not quite there yet and there may be some insurmountable problems ahead but the goal is to have the tool recognize the cutting plane and then the selected (solid) group and automatically trim the group to the plane inserting new vertices and faces as required to close the solid back up and also delete the appropriate geometry.
                        If I delete the vertices of the group that are on the "clicked" side of the plane that will also eliminate any of the unwanted faces. The algorithm will involve some tricky applications with vectors and line/plane intersections to try and sort it all out. I am quite impressed with the API and its geometry functions.
                        design.medeek.com
                        • jujuJ
                          juju
                          I tested this, works as expected, thanks!
                          naughty naughty, revision history "paper trail", still thanks none-the-less
                          • medeekM
                            medeek
                            If a fix or correction is fairly minor and it is within the same 24 hour period as a new revision I like to bundle it into that revision otherwise it appears I am making leaps and strides with the development when I am not.
                            design.medeek.com
                            • G
                              Garry K
                              Sorry Nathaniel,
                              I'm with Julu on this.
                              In my 34 years of programming - this type of short circuiting general accepted practice more often than not gets programmers into trouble.
                              I know I've done it myself - and sometimes I've gotten away with it - and sometimes I've created problems for users. Even alienating a single user due to frustration is simply not worth it !!!
                              So naughty naughty it is !!!
                              • facerF
                                facer
                                Nathaniel,
                                I support the other posts but would not go as far as saying "naughty".
                                Within a 24 hr period a lot of downloads could have occurred.
                                Now you will have a group of users that may be out of step.
                                Not Good!
                                Best to keep to the rule of:
                                ANY CHANGE THAT IS ISSUED REQUIRES A NEW NUMBER DESIGNATION.
                                Having said that "Keep Going" you are on a roll.
                                I look forward to your "Manual" which could be released as a "Beta"
                                so you get feedback on how it is received.
                                • medeekM
                                  medeek
                                  Okay, you all have a point I will avoid this practice in the future. However I will note that the change log lists every modification to the plugin since I started.
                                  On a different note I just started a new job and I'm living out of a suitcase right now so I probably won't be able to work on anything for at least a week or two. I would really like to test the trim function I've created but it will have to wait. Once i get my workstation back I will hit it full force.
                                  design.medeek.com
                                  • jujuJ
                                    juju
                                    Congratulations on the new job! Uprooting/moving is always uncomfortable, so wishing you as little discomfort as possible.
                                    Looking forward to the future development of both the truss and slab/foundation plugins.
                                    • medeekM
                                      medeek
                                      I haven't had any time this week or even this weekend to dive back into it yet but the icons for the Medeek Tools Menu (trim and extend for now) will look like this:
                                      http://design.medeek.com/resources/images/truss_su_menu_with_tools.jpg
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        The trim function is a work in progress. I had some help with a developer on the other board but it has a ways to go yet.
                                        design.medeek.com
                                        • jujuJ
                                          juju
                                          How's the new job going? Have you settled in already?
                                          • medeekM
                                            medeek
                                            Starting to get my bearings with the new job. Still haven't found a place to live yet, Airbnb has been interesting.
                                            design.medeek.com
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 76
                                            • 77
                                            • 24 / 77
