    LayOut 2017 Wishlist
    Scheduled Pinned Locked Moved LayOut Feature Requests
    layout
    21 Posts 10 Posters 26.7k Views 10 Watching
    • JQLJ
      JQL
      @utiler said:
      ROTATE tool - its currently complex, Richard! Unless of course you just want to rotate it around it's centre. If not, as with the MOVE tool you have to move that damn snap/rotate thingy around the screen [and go forbid if the destination is outside your screen space.... ๐Ÿ˜  ๐Ÿ˜  ]
      Simplifying it to work [as most other programs on the market], especially to be able to rotate something to a specific angle.
      I'm still amazed at how this works! Such a simple thing made into such a complex operation!
      Move/rotate/copy by dongle position + mouse dragging and multiple keystrokes ๐Ÿ˜ฎ ๐Ÿ˜•
      www.casca.pt
      Visit us on facebook!
      • utilerU
        utiler
        I prefer not to think about it, JQL.
        It's like working with blunt tools at times!!!
        Just Curious...
        • JQLJ
          JQL
          There's no way not to think about it. You have to work with it...
          Two things good about Sketchup:
          • Basic tasks work intuitivelly and cohesivelly in a fast and simple fashion;
          • When a complex or tedious task arises, certainly a plugin to deal with it has been developed by some good willed soul.
          Two things bad about Layout:
          • You can do basic tasks;
          • When a complex or tedious task arises you have to keep banging against it until it's done.
          You are able to get things done with both, but I try to do the most I can in the Sketchup side of the pipeline...
          Layout is getting better each new release though... This layer managing new system is a bless!
          www.casca.pt
          • utilerU
            utiler
            it sure is a move in the right direction....
            Just Curious...
            • TommyKT
              TommyK
              API - just to clarify what the current API means to end users - it is a C API. This means that tools within LayOut cannot be developed using this. Instead, LayOut files can be created/manipulated from outside LayOut - from SketchUp for example. We would have to wait for a sketchUp Ruby style API in a future release.
              ROTATE - I do have frustrations with this, but I don't mind the principle of how it works. It needs to work with inferencing better, and have an ability to change the "start rotate" angle, if that makes sense. Then, I'd be happy.
              BETTER INFERENCING - LayOut inferencing should be as powerful as the Sketchup inferencing, and work in the same way. End of. Please get this done!
              • bazB
                baz
                I would like some more 'right click' options. EG:
                To enter a dim entity to change a measurement without getting RSI clicking 10 times on the damn thing.
                An option to reduce the bounding box on a model to the model extents, instead of grabbing several handles.
                • K
                  kiwi15
                  Hello folks,
                  I asked the guys at SketchUp (back in 2014) if they could add some metric scales to their vehicle-templates in LayOut, but alas they told me that I just had to make my own custom scrapbook templates for this purpose.
                  I have now made one 1:100 and a 1:200 metric templates that anyone is free to use. (...If SketchUp allows it)
                  ...to clean up/delete custom made LayOut scrapbooks (on Mac) follow this thread: http://sketchucation.com/forums/viewtopic.php?f=12%26amp;t=48602 )
                  Kiwi15 (NB: this is my first post at this forum)
                  1:100 vehicles, LayOut
                  1:200 vehicles, LayOut
                  • pbacotP
                    A place to designate pages to print, instead of having to choose the page range each time from the print dialog, which besides repetitive is so slow in response and only allows sequential picks. Similar to "include in presentations" which I don't use at all. It seems this might also speed-up the print dialog since it seems that LayOut "renders" each page when you go to print and you have to wait for this before proceeding. In fact I'd like to sidestep the dialog once it's all set up. Press a print button ("use last settings")--and the designated pages print--and not have to wait so long every time for the print dialog.
                    • JQLJ
                      JQL
                      Having an option for a model displayed in Raster/Hybrid but exported as Vector for CAD.
                      www.casca.pt
                      • C
                        caronte01
                        Yes please... this is really necessary.
                        • Option to assign not only lineweight, but linetype to vector viewports.
                        • Show the current layer someplace like the window title.
                        • Option to draw stuff using viewport units (draw stuff at 1:50 for example)
                        • Ordinate dimensions (for stuff like levels in elevations and coordinates)
                        • Spot elevation (for levels in plans)
                        • Better display of dashed lines so they display properly at polyline ends. (linetype generation in autocad world).
                        • PDF import support in windows
                        I had a chance to talk to some of the developers at 3dbc, but forgot to mention most of this stuff ๐Ÿ˜ณ .
                        • sfto1S
                          sfto1
                          I would like to see guidelines,similar to those in Sketchup.
                          More font options, as in width factors, kerning etc...
                          A line offset tool would be handy.
                          And I would like to +1 the idea for text to have insertion points relative to text, not text box.
                          • JQLJ
                            JQL
                            LAYERS:
                            Layout's:
                            • Have the ability to send objects to locked and hidden layers - I tend to lock layers not in use and when I find objects I want to send to those layers I'd like to be able to do it. Sending an object to a layer is not an accidental process it's really something precise you must do, so having this overriding a locked layer state isn't dangerous.
                            Sketchup's:
                            • Have Sketchup Layers visible in Layout's side;
                            • So they can be exported to CAD/PDF files;
                            • So we can control their color, line, fill styles and also visibility inside a viewport;
                            • It would be oh so cool if the above "visibility" would be replaced by "transparency"
                            www.casca.pt
                            • K
                              kiwi15
                              Having an option to set Display Resolution to "Low" & Output Resolution to "High" as default under Document Setup/Rendering Resolution would be neat.
                              • Inside "SketchUp Model window" under "View" add a "Section Display"-icon, so that I can toggle it on/off without having to go back to do this in my SketchUp model.
                              I would like to be able to import .svg files as well.
                              Ability to use "Fog" in Hybrid mode, not just in raster.
                              Dedicated "Update Model Reference" icon for the toolbar or perhaps better; inside the menu window for the "SketchUp Model" under "View".
                              I would like to have an optional dynamic info box linked to each scene in Layout for quick reference. In this optional dynamic info box it should be info about what scale is used, which style, line weight, date created, and name of the .skp file. Today I have to do this manually.
                              • pep75P
                                pep75
                                Layout needs to speed up! It is so laggy and sluggish (Core I7 3.5ghz/GTX 1080).
