    FUZZY TEXT LABELS
    19 Posts 2 Posters 3.3k Views 2 Watching
      Yes. It would because there are more pixels being used to display the strokes of the letters. That may be the best you're going to get without using vector text.
      • P
        pipingguy
        QUESTION - how can i get a temporary model plan view - but rotated 90 degrees from normal?
          Why temporary?
          You could use Eneroth Relative Top View (Extension Warehouse) or you could use LO and rotate the standard top view.
          • P
            pipingguy
            How can I release the text label arrow tips when dragging annotations? See attached image.
              It depends upon where you grab the label. Grab the text and only the text box moves. Grab the leader and the whole thing moves. With your two segment leaders, grab by the arrowhead end to move the whole thing.
              Why is all the important stuff outside the paper space?
              • P
                pipingguy
                why temporary? - because i need to capture the view for a scene
                eneroth gives me a plan view in various rotations- but does not keep the axes square
                remember - i don't want to rotate the model - i want to rotate the plan view camera instead - but in 90 degree increments
                • P
                  pipingguy
                  i want to drag the annotations from the viewport area off to the side then pick and choose items from that batch for new drawing. maybe smarter to use scrapbook. just wanted to know if there was a way to to break the grip of several text callouts in one move vs individually
                    What does this mean? The axes don't get moved by the extension.
                    I wasn't implying that you would rotate the model. There's no need to rotate the model to get the rotated plan view you asked for.
                    So did you try what I told you to do?
                      Standard Front View
                      Standard Top View
                      Standard Right Side View
                      Eneroth Relative Top View. The axes are still aligned as they were before using the extension.
                      • P
                        pipingguy
                        OK i get it now. the skewed axes in the animation were throwing me off. i should have just stuck with reading her narrative.
                        • P
                          pipingguy
                          ''So did you try what I told you to do?''
                          yes - eneroth RTV works
                          and i already know how to release text label arrows ONE AT A TIME
                          ps - maybe eneroth can add a relative bottom view someday
                            Then you already know how to release multiple label arrows.
                            Click on the picture.
                            • P
                              pipingguy
                              wow - pretty cool dave r.!
                              note to whomever is interested - dropbox is useful for retrieving previous versions of your models. a copy is automatically stored to the cloud every time a save is made - all the way back to the beginning of the model creation.
                                Thanks. It's just a basic move thing. There's a lot of subtle options with the various tools in LO.
