    [Request] Scene tween
    10 Posts 7 Posters 1.4k Views 7 Watching
    • soloS Offline
      Is there a plugin that can create scenes between camera's?
      I have a scene and I'd like to render frames between camera's, I'd like to be able to chose the amount of frames if possible.
      • Chris FullmerC Offline
        I swear I wrote this into a plugin once. Let me dig around and see if that's real or not.
        • soloS Offline
          Yeah, I have passed my trial period, I thought there was maybe a plugin that just did the tweens instead of purchasing the whole animation app.
          Chris, that sounds good.
            Hmm, I don't see anything I published that does that exactly. It would be fairly simple to write though.
            • cottyC Offline
              cotty
              @d12dozr said:
              I think [url=sketchucation.com/forums/viewtopic.php?f=323&t=33417]Keyframe animation[/url] will do that
              edit... the URL isn't clickable πŸ˜•
              I think the "http://" is missing after "url="...
              my SketchUp gallery
              • cottyC Offline
                cotty
                In SkIndigo (SketchUp Plugin for Indigo Renderer) there is an option for creating such an animation, maybe for your render engine there is a similar possibility like this?
                my SketchUp gallery
                  d12dozr
                  I think Keyframe animation will do that
                  edit... thanks Carsten πŸ˜„
                  http://goo.gl/f7ooYh
                    tomasz
                    Yes, there is:
                    • ppoublanP Offline
                      ppoublan
                      Dear all,
                      I used this little script. Very limited but it insert scenes with intermediate cameras.
                      Yours
                      require "sketchup.rb"
                      Add a menu item
                      plugins_menu = UI.menu "Plugins"
                      insert_scenes_menu = plugins_menu.add_item("Insert Scenes") {
                      # Access the Pages container
                      pages = Sketchup.active_model.pages
                      # check existing pages
                      if pages.count < 2
                      	UI.messagebox("Needs 2 scenes to be created first.")
                      	exit
                      eye1 = pages[0].camera.eye
                      target1 = pages[0].camera.target
                      up1 = pages[0].camera.up
                      fov1 = pages[0].camera.fov
                      eye2 = pages[1].camera.eye
                      target2 = pages[1].camera.target
                      up2 = pages[1].camera.up
                      fov2 = pages[1].camera.fov
                      # prompts for number of scenes
                      prompts = ["Number of scenes to add : "]
                      defaults = ["10"]
                      input = UI.inputbox prompts, defaults, "Insert Scenes"
                      if (input)
                      	insertcount = input[0].to_i + 1
                      else
                      	exit
                      for i in 1..insertcount - 1
                      	eyetmp = Geom::Point3d.new (eye1.x + (((eye2.x - eye1.x) / insertcount) * i),eye1.y + (((eye2.y - eye1.y) / insertcount) * i),eye1.z + (((eye2.z - eye1.z) / insertcount) * i))
                      	targettmp = Geom::Point3d.new (target1.x + (((target2.x - target1.x) / insertcount) * i),target1.y + (((target2.y - target1.y) / insertcount) * i),target1.z + (((target2.z - target1.z) / insertcount) * i))
                      	uptmp = Geom::Vector3d.new(up1.x + (((up2.x - up1.x) / insertcount) * i),up1.y + (((up2.y - up1.y) / insertcount) * i),up1.z + (((up2.z - up1.z) / insertcount) * i))
                      	fovtmp = fov1 + (((fov2 - fov1) / insertcount) * i)
                      	pagetmp = pages.add(i.to_s)
                      	pagetmp.camera.set eyetmp, targettmp, uptmp
                      	pagetmp.camera.fov = fovtmp
                        ternup
                        @ppoublan said:
                        Dear all,
                        Yours
                        Add a menu item
                        if pages.count < 2
                        exit
                        defaults = ["10"]
                        if (input)
                        else
                        exit
                        Thanks for the codes, but i dont understand how does it works.
                        It will be helpful if you can explain it.
                        What if i have about 26 scenes, & i want it to be 24fps?
