    Animator: Parametric Animation plugin - Discussion
    223 Posts 55 Posters 125.8k Views 55 Watching
    • duanekempD
      duanekemp
      I too am a Mac user as well as PC. I'd be more than willing to be your guinea pig for test on both.
      Duane Kemp
      Kemp Productions
      Puidoux, Switzerland
      Gallery:
      https://duanekemp.artstation.com/
      • EarthMoverE
        EarthMover
        Fredo, I see you've released 6 beta tutorial videos on your youtube channel. I hope that means something is coming soon. 😄
        Content Creator at Skapeup
          driven
          fredo,
          you can bundle 64-bit ffmpeg binary with your plugin for use on Snow Leopard, Lion, Mountain Lion, Mavericks, Yosemite and El Captain.
          it eliminates the need to download, instal, look for, etc...
          • fredo6F
            @driven said:
            fredo,
            John,
            Not sure it's a feasible idea:
            • I don't know if I have the right to distribute it.
            • The exe file is roughly 40 Mb, so not light
            • I would have 2 distributions, one for Windows (maybe 2 if 32bits is still around), one for Mac
            If there is a right to redistribute, the solution would be to put it on the PluginStore. But again, it's an Exe file on Windows (and similar on Mac), so it's never simple to download such files by program.
            • MALAISEM
              MALAISE
              And I missed that. What a tool for animated explanations. I can't wait..
              As Pilou said, Fredo President !
              • G
                gio
                [RV444.1442] Thea for SketchUp - NEW
                New: Support for Fredo's Animator plugin added
                Ciao,
                Gio
                • ntxdaveN
                  ntxdave
                  Ciao,
                  Gio
                  How about showing some examples......
                  Press F1...thank me later
                  • F
                    Falstaff
                    I'm trying to animate movements with both translation and rotation and am finding that they interfere with one another, the object gets additionally displaced while rotating, ending up in the wrong spot / pivot point. In that model the components are nested, is there something with how the plugin interprets nested components that would cause that weirdness?
                    Also how does the positioner option work on the back end? It seems like I have functions that gets locked into place which make it impossible to modify a beginning position, in other words, I want to have my object have a new starting point and even though I set a new position through Positioned Load the plugin queue's back in time and my object jumps back to where I originally had it. It would be helpful to be able to delete Positions or access the coordinates manually somehow to wipe that information.
                      RichardPMuller
                      Thanks for sharing this Beta version. First results: Animation double canal lock (school project daughter) Great plugin and lots off fun to work with. https://youtu.be/aO1PnfoDu2g
                      • ntxdaveN
                        ntxdave
                        Can you post an animation so we can see your problems?
                        • F
                          Falstaff
                          Attached are two videos of my biking guy. I've got this component organized so that his foot rotates with the pedal component, and now I am manipulating the rotation of his "leg" component and the rotation of his "calf" group within the leg.
                          I noticed the knee keeps shifting i.e. becoming unattached. The only clue that I have are in the videos below (which show the 360 rotation to emphasize). When I play in isolation mode the leg rotates the way I need it to with the knee intact. However, when I play the entire clip together the movement is wrong.
                          My guess is either its somehow being influenced by another recorded movement for some reason. Or the plugin is misinterpreting the axis.
                          3 pos left leg.mov
                          3 pos left leg2.mov
                          • ntxdaveN
                            ntxdave
                            Nice animation. I am curious about how you accomplished the water level changes. It comes across very smoothly. 👍
                            • duanekempD
                              duanekemp
                              Very well done. Bravo.
                              Duane Kemp
                              Kemp Productions
                              Gallery:
                              • ntxdaveN
                                ntxdave
                                First off, this is an animation that can better be done with a tool that supports "bones" which this version of Animator does not currently do. However, below you will see a very crude attempt to show you the steps that could currently need to be done (many more of them obviously). I did not animate the pedal, just the foot and lower leg. I also left a kind of reference (circle) to give you an idea. I also color coded the sequences to show you which one related to which object in the animation.
                                You mill notice that there are multiple animation sequences for each object. So what you are doing is rotating, spinning, and translating all at the same time.
                                Click to play........
                                For the foot, there are two sequences. One is a rotation based on the reference circle below it and the other is a spin to adjust the ending position of the foot.
                                Tor the lower leg, there are three sequences. One is a translation that moves the leg to the left and the second is a translation that moves the leg down to match the position of the foot. The third sequence for the leg is a spin that adjust the angle of the leg and would occur in the pedaling action.
                                To complete the full rotation of the pedaling motion, you would have to perform multiple sets like these.
                                I did not use the save position anyplace in my animation. I generally only use that tool when I think I am going to make a bunch of revisions and may need a clean starting point.
                                Hope this helps you...............
                                  RichardPMuller
                                  Thanks, simple, the water is just a flat face moving up and down. Move the water in the lock and the boat at the same time and duration up or down the Z-axis. You have to soften some outlines off the water face were they come together, so they look one peace when the doors slide away.
                                  Nice animation. I am curious about how you accomplished the water level changes. It comes across very smoothly. 👍[/quote]
                                  • F
                                    Falstaff
                                    Thank you for your thorough response. That is exactly how I had it set up as far as rotation, in my video you can see the circle behind the foot divided into 12 sections.
                                    My question is what could be the problem if nested components are not rotating around the indicated axis? It seemed to work well for me for the first few sections, and then somehow got bogged down or something.
                                      Just erase the "s" in "https" then use the balise
                                      http://sketchucation.com/forums/styles/abbcode/images/bbvideo.gif
                                      http://www.youtube.com/watch?v=Bs9x6pjaPLA
                                      Retro style! 😎
                                      • ntxdaveN
                                        ntxdave
                                        That is what I thought but wanted to make sure. Again nice work.....
                                        @falstaff said:
                                        I've managed to get my animation to work. I scrapped my last on entirely, I had so many animated sections that the plugin kept getting them jumbled. It doesn't like anything unpredicted.
                                        Glad you found my coments useful. Yes, I could/should have mentioned DIMS but you got it figured out anyway. I liked your video.
                                        Working with subgroups/subcomponents an be a little trick but also very valuable. If you saw any of my car wash animations, I have to work with them often.
                                        Look forward to future animations from you.
                                          RichardPMuller
                                          Maybe an idea. The possibility to add sounds to the animation ...
                                          • F
                                            Falstaff
                                            For each rotation section (I created 12, like a clock) I had 4 or 5 commands so as you can imagine that was quite a lot of movement between two legs. Also in the original I manipulated the movement through direct input of the degrees - so it was about 30 unique numbers. Really confusing to tell which was which.
                                            In this animation I created all my movements outright and instead of having unique numbers I rotated each component the maximum amount 360 degrees and then manipulated it through the DIMS control to get the degree I needed. In the tutorial you can see Fredo6 uses the DIMS as well. Somehow this is less confusing for the plugin. Also clicking save after each new move seems to help.
                                            So I had 8 New Movement controls:
                                            Left Calf 360
                                            Left Leg 360
                                            Left Pedal Stay Flat 360
                                            Left Crank 30
                                            Right Calf 360
                                            Right Leg 360
                                            Right Pedal Stay Flat 360
                                            Right Crank 30
                                            Then I repeated these 12 times and it didn't get hung up on anything. Getting my wheels to rotate the legs started flying around where they shouldn't be again. Also moving the biker messed everything up. Ideally I want him to bike down a bike path. Next time, Im pretty happy with this outcome.
                                            Check it out here : https://youtu.be/Bs9x6pjaPLA
                                            • 11
                                            • 12
                                            • 6 / 12
