    Shadow studies - wrong lenght?
    10 Posts 4 Posters 935 Views 4 Watching
      Jorgensen
      i just wanted to test the shadows in sketchup.
      i placed a one meter stick on the ground measured the shadow lenght to 2.8 meters.
      i then created a 1cm x 1cm x 100cm object in sketchup, added my location sat the correct time and date - and used UTC -1 (denmark).
      the shawdow lenght was 5,14m in sketchup - almost the doubble lenght.
      does anyone know what i'm doing wrong?
      i did the same test in revit - and it was 2.82 meters.
      /jorgensen
      • jujuJ Offline
        juju
        my suggestions:
        1. complete your profile with sketchup information
        2. check that date / times are setup correctly
        3. check location and altitude is set correctly
        4. ditch revit
          Jorgensen
          hi juju
          thanks for your reply - and sorry - signature should be updated now.
          date and time was correct
          "i then created a 1cm x 1cm x 100cm object in sketchup, added my location sat the correct time and date - and used UTC -1 (denmark). " - and location checked.
          why should i ditch revit? revit did it correct - sketchup not.
          no need to demean revit - revit has it's pros and cons, and so do sketchup.
          jorgensen
            Have you the SKP file ?
              Jorgensen
              hi pilou
              yes i have... 😄
              jorgensen
              shadow.skp
              • Wo3DanW Offline
                Wo3Dan
                /jorgensen
                I looked at your model and on june 24 at 12:20 I get the shortest shadow, being about 73 cm.
                You didn't give a specific time to check the model for.
                  Or like the watches : 10 h 10 😉
                  Because at 12 h somewhere maybe shadows don't exist!
                  http://www.thebestofprc200.com/wp-content/uploads/2014/12/stylish-timex-watches-620x393.jpg
                    Jorgensen
                    Hi wo3dan
                    I thought the date and time was saved in the file - it was when I opened the file.
                    Date was 22.06, time 19:19.
                    Jorgensen
                    • Wo3DanW Offline
                      Wo3Dan
                      Your model shows UTC+1. Shouldn't it be UTC+2? It's summertime now!
                      Change it to UTC+2 and you'll get desired results.
                        Jorgensen
                        @Wo3Dan
                        oh my - that really was a simple, but stupid mistake.
                        thanks for clearing it out for me.
                        jorgensen
