    Creating a set of templates with title blocks A4 - A0
    layout
    2 Posts 2 Posters 2.6k Views 2 Watching
    • Stef KittsS
      Stef Kitts
      I'm new to Sketchup Pro and am currently trying to set up standard layout templates with title blocks. I've created the A4 and A3 templates from the standard layouts which was straight forward. However, when I came to start on the A2 I realised there is no equivalent standard block for this or the larger sizes. I'm using the standard layout with the grid.
      How do I overcome this please?
      Stef
        You can select the desired paper size in File>Document Setup>Paper. A2 is list in the drop down near the top of the list. If you're modifying an existing template that shows the grid lines, the grid lines will still be displayed with the same spacing. You can go to the Grids page and make changes to the grid spacing, color and whether or not the grid will be printed.
        While you're in the Paper window, you can adjust margins and other details, too.
