    Sections
    21 Posts 6 Posters 2.7k Views 6 Watching
      Maybe this will help.
      A circle with a radius of the ring.
      Extrude with Push/Pull to the required thickness.
      Use Offset first to delineate the radius of the post. Then draw a line for the flat.
      Push/Pull to get rid of the waste.
      Select the remainder of the offset edge and use Move/Copy to copy it to the opposite side. You could have used Offset on the other side as before but this is quick and easy, too.
      Push/Pull the inner faces on both sides to make the post.
