    Remove duplicate entries material editor
    8 Posts 2 Posters 1.1k Views 2 Watching
      tspco
      Probably a simple fix, but it is bothering me, how the heck do I remove duplicate entries from the material browser? For example material, material<1> one of these may have no materials in them, that is the one I need to delete. They do not show up in the SketchUp materials folder under program files>SketchUp 2016 etc...
      Thanks in advance
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
        A quick search of SCF turned up TIG's Material Consolidator.
          tspco
          The materials themselves aren't the problem, it is the empty folders in the browser, but I will check the plug
            Sorry. I misunderstood.
            If they are empty folders, you should be able to delete them from Windows explorer.
              tspco
              But I need to find them, they are not in Sketchup>Materials, I will try now and again. Thanks Dave!
                Are you still using SketchUp 2013?
                  tspco
                  Nope 2016 make
                    Your profile shows SU2013, still.
                    So you can look under User/App Data/Roaming/SketchUp... for materials folders. Or you might just try running a search for all folders with "material" in the name.
