    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
      Anton_S
      Announcing version 0.8.0!
      This version comes with many bug fixes and improvements. As well as with two new joints: CurvySlider and CurvyPiston. A demonstration of these two joints is available at 3DWarehouse: https://3dwarehouse.sketchup.com/model.html?id=d21984a9-477b-44d7-9eca-c191ae85afe4
      • F
        faust07
        The new Curvy Joints improve animation along paths fundamentally. The possibilities are not yet in sight. Great is that you can take curved sections and even edges with the joint in a group without to weld them, and therefore the curve in turn can be moved. Your examples show this excellent.
        Two questions:
        What are the rules for the orientation of the joints to an individual curve - exactly parallel?
        It seems that old Servo Joints with Oscillator as a controller are not functioning as in version 0.7.0? Tested for example, with birdy and orca.
          Ralphxyz
          Well I hopefully thought I'd try again.
          http://gettheworkdone.net/images/MSPhysics/6-13-2016_0.8.0.jpg
          the error at least looks a little different.
          Windows 10
            Anton_S
            Hello Faust,
            Curvy joint orientation has no effect on a curve or whatsoever. The curve may be parallel or not parallel to the actual joint - it doesn't affect the way joint behaves. The joint object just represents the origin of the joints. The edge closest to the origin of the joint is considered as the starting edge and all its connected edges are considered as the consequent edges. As long as the curve (or a set of connected edges/arcs) is created within the joint, with the angle between each edge set to a maximum of 45 degrees, the curvy joint will work fine. To my experience CurvyJoints operate better on iterative solver than on exact solver. So if you use curvy joints, setting a solver model to iterative 4+ passes will guarantee the optimal behavior.
            The servo joint was reworked in this version. Now instead of accel and damp, it uses angular rate, and the SP Mode was removed. If your joints relied on SP Mode, their controller values ranged from 0.0 to 1.0. Now that is changed. The controller values range from -min_angle to max_angle. So for your birdy the servo controllers should be changed to something like, oscillator(100)*30. The limits should be disabled or adjusted to -30,30.
            Ralph,
            Sometimes the zip file fails to extract all content. Try checking if Plugins/MSPhysics/win64/2.0/msp_lib_no_sdl.so exists.
              Anton_S
              Ralph, I reworked the main.rb to display more info about the loading errors.
              Place in .../Plugins/MSPhysics/ folder. Overwrite the original one.
                Ralphxyz
                Thanks Anton,
                http://gettheworkdone.net/images/MSPhysics/2016-06-13_18-25-06.jpg
                  Anton_S
                  Okay that's better. Based on the message, particular files are missing from the plugin's folder. As mentioned before this could be due to extraction issues, where the zip extractor fails to extract all the files. To ensure that its not the code error, go to C:/Users/Ralph/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/win64/
                  and check if all of the following files are there:
                  • libFLAC-8.dll
                  • libmikmod-2.dll
                  • libmodplug-1.dll
                  • libogg.dll
                  • libogg-0.dll
                  • libvorbis.dll
                  • libvorbis-0.dll
                  • libvorbisfile-3.dll
                  • SDL2.dll
                  • SDL2_mixer.dll
                  • smpeg2.dll
                  If that's not the case, try re-downloading MSPhysics and extracting using 7-zip, as it might a better alternative to the standard windows extractor. If you don't want to go through all that manual extracting and moving mess, you can instead use PluginStore plugin to download and install MSPhysics by a few clicks.
                    Ralphxyz
                    When I download from the PlugIn store all I get is a .rbz file not the zip file.
                    Does that go in the Plugins folder?
                      Ralphxyz
                      This is so irritating.
                      I cannot run 7-zip I have had it installed and have used it with Windows 8 but it does not run in Windows 10.
                      Win Zip apparently is not extracting all of the files specifically the win64 folder.
                      I can go to GitHub and see the win64 files but I do not know how to download the individual files.
                        Ralphxyz
                        Finally I got the win64 folder downloaded completely, I got 7-zip to work.
                        Now:
                        http://gettheworkdone.net/images/MSPhysics/x2016-06-14_12-18-54.jpg
                        I am so sorry to be such a bother, I do not even know if I will understand how to use MSPhysics once I get it working it seems kinda complicated, but really neat in what I have seen.
                        • F
                          faust07
                          I have tested the installation of MSP-Version 0.8.0 with the ExtensionStore and it does not work (Windows 8.1, SUp 16 Make). But downloading from Google Drive, unzip, delete the old MSPhysics SubDirectory and copy the new into the plugin directory works.
                            Anton_S
                            Ralph, Faust, that's bad. Installing MSPhysics via PluginStore (on SU2014 and SU2016) works just fine on mine. I think an automated installer would be the best way to for installing such plugin. I will create an installer and we'll see if it works then...
                              Anton_S
                              Ralph, I created the installer, which installs both MSPhysics and AMS Library. The link is available in first post. See if it will work after installing with the installer.
                              • F
                                faust07
                                How can I change the direction of objects on a CurvyPiston Joint? Currently, connected objects move in the negative Z-direction of the joint no matter what positive ore negative number I input in the Controller ore Power fields.
                                • F
                                  faust07
                                  I found the solution: a value less than the length of the curve in the Controller field makes the object follow the path backwards. What would be cool if there was some kind of infinite loop function ...
                                  • F
                                    faust07
                                    Birdy on the new CurvyPiston Joint. Very easy to do! πŸ‘
                                    But how can I make the object following the curve more flexible and grabs not so hard around the corners?
                                      Ralphxyz
                                      faust07, that is great, how much time did it take to do the bird flapping it's wings and following the path?
                                      • ntxdaveN
                                        ntxdave
                                        DITTO ❗
                                        Press F1...thank me later
                                        • F
                                          faust07
                                          Thank you Ralph and Dave! But MSPhysics is great. First and foremost, Anton, who raised it to life.
                                          With MS Physics and the new Curvy Joints path following objects can be modelled in minutes.
                                          And the two wings to hang with Servo Joints on the bird's body, does not take long too. Experimenting to adjust speed, stroke rate, angle, etc. then I really enjoy.
                                          • F
                                            faust07
                                            A small inconsistency emitter concerning: some emitted objects appear extremely far away on the X-axis, so the viewport is temporarily empty, as long as these objects exist. This also happens with older models that have worked before version 0.8.0.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 46
                                            • 47
                                            • 16 / 47
