    FlexWindow 2.1 - dynamic component
    62 Posts 14 Posters 48.4k Views 14 Watching
    • halroachH
      halroach
      @agrazdi said:
      I copied several times the window example and modified one of them and i was expecting that all of them would be modified. I am not familiar with dynamic components. Am i doing something wrong, or thats the way they work, and i need to modify each one sepertaly ?
      Dynamic components work a bit differently...
      Once you change one of the dynamic components (that you have copied), it becomes a new component. ("#1") is added to the end of the 'definition name' (see in the entity info window).
      If you wish to edit multiple dynamic components and wish that they all change in the same way, you must select all of them, and then make the changes. Note, that it won't always work like you'd expect it to - because it really depends how the dynamic component was written.
      In the case of FlexWindow, currently, if you select all of them, then make the changes in the 'component options window', they will all change to look the same! even if one of them wasn't in the same proportions to begin with...
      Also, editing multiple dynamic components in this way, may cause some unwanted side effects which I am currently looking into... some 'setting' can kinda stop working...
      I actually intend to introduce in the next update to Flexwindow, a sub-version where one will be able to change settings to multiple instances, without affecting their scale. (thanks to user feedback!)
      FlexTools - Super Quick Windows, Doors, Slats...
      • halroachH
        halroach
        And... To make things easy, you could simply insert the dynamic component into a 'regular' component, and copy the 'regular' one all over the place, and they will all be the same... even if you edit the one inside...
          agrazdi
          And... To make things easy, you could simply insert the dynamic component into a 'regular' component, and copy the 'regular' one all over the place, and they will all be the same... even if you edit the one inside...[/quote]
          Thanks, it worked perfect.
          Any date for Corner Window + Door + Slat realese ???
          • halroachH
            halroach
            Glad that worked!
            I have a few more fixes and updates I wish to add to the current FlexWindow.
            In the coming week or so, I hope to introduce FlexSlat! (it's almost done), and the rest will follow... and maybe even more than just those mentioned... 😉
            • halroachH
              halroach
              FlexWindow 1.3 released!
              What's new:
              • Inset guide - toggle on/off - for easy placement in existing openings.
              • Glass thickness control
              • "no-dims" version - without 'opening width & height' dimensions - Enables the ability to select and edit multiple FlexWindow components at once, and each will continue to maintain it's original dimensions.
                If you've already purchased FlexWindow, you may download this update as well. To access the download, use the same link you received in your original registration email.
              Enjoy! 😉
              guide for quick inset placement
                agrazdi
                Is there a way to change the default window's glass color and units to meters ??
                • halroachH
                  halroach
                  1. To change the glass color, like in any component in Sketchup, simply double-click your way in, until you reach the glass geometry and apply any color / material you wish...
                  If the glass has thickness, you might need to apply the material to the inside too, (hide one face, apply to all and unhide...)
                  1. The component is set to use which ever units the model is in. So if your model is defined to display in meters, the component options should be in meters too.
                  Hope that helps
                  • halroachH
                    halroach
                    I have just released FlexSlat 1.0 - The second member of the Flex-Family 😉
                    Check it out:
                    http://sketchucation.com/forums/viewtopic.php?f=40%26amp;t=64960
                    • halroachH
                      halroach
                      FlexWindow 2.0 is out and about!
                      I've been working hard to perfect FlexWindow to make it more useful and adaptable.
                      The major update in this release: You can now choose between 4 different 'profile distribution options'! From now on, every profile will be exactly where you want it to be!
                      Please note that the 'pillars' have been removed in this new edition. I intend to reintroduce them in a new Flex component in the future...
                      For more information on the new 'distribution options' and on other improvements and changes, please see the first post, and/or visit:
                      http://frandzel3d.com/flexwindow
                        rv1974
                        Is the price for fixed product or you practicing some free updates?
                        • halroachH
                          halroach
                          As I've done with version 1.x till now... same with version 2.x. Updates within version 2 will be free for who ever purchased 2.0.
                          Of course, for good updates, the more feedback the merrier! 😄
                          Sent from my iPhone using Tapatalk
                            rv1974
                            BTW I could never could understand it-
                            What's the point of using Tapatalk?
                            • halroachH
                              halroach
                              So one could answer quickly when not near his computer !? 😄
                                rv1974
                                So the main benefit is 'Subscribe to the thread' feature?
                                • halroachH
                                  halroach
                                  It's one. If you're really desperate to read threads in bed for instance 😉
                                  • halroachH
                                    halroach
                                    FlexWindow 2.0 now also in Traditional Chinese! - 含繁體中文版本
                                    Just a little update. FlexWindow 2.0 and FlexSlat 1.0 are now available in Chinese too!
                                    If you have purchased these, and wish to download the Chinese version, access the same link from the email you received upon purchase.
                                      shueda
                                      Is there a solution for double-hung windows?
                                      • halroachH
                                        halroach
                                        Not yet. But it's on my list.
                                        I'm currently working on a FlexDoor - which is in working condition (using it on a project of mine), but it's still missing a few important features so it's not in release state yet...).
                                        I've also started working on FlexCornerWindow...
                                        Actually, I would be very glad to hear which types of windows you all would like to see Flexed...
                                        • utilerU
                                          utiler
                                          Hi Yoni, purchased Flex Window and so far so good.
                                          I have a few suggestions that if implemented I would definitely buy FlexSlat and your upcoming FlexDoor.
                                          See attached images:
                                          The glazing component needs to be separate elements between mullions. Seeing them pass through the mullion in plan is not right.
                                          As you can see in this image it should stop and start at the edges of each mullion.
                                          Also, having the glazing on a seperate layer allows it to turned off at larger scales for clear presentation. [EG; at 1:100 scale a 50mm wide window unit with glazing within will be appear to 'heavy given the section cut setting for walls will be the same across the section cut....
                                          Just Curious...
                                          • halroachH
                                            halroach
                                            Yes, I understand the issue with section cuts. Juju also pointed it out earlier.
                                            A potential problem is that if applying separate windows in both vertical and horizontal directions, the dynamic component may become very slow... especially for large facades.
                                            For small windows - it should probably be OK. It may also take quite a while to 'program' it (but that's my problem). I'll consider doing it (adding it to my list of things).
                                            You can easily customize the FlexWindow component, select the 'window pane component' within, and put it on a layer of your choice, and save the file as your "default copy" for later use. You can also right click and 'save as' to have it as a drag-n-drop file.
                                            Just note that there are actually two separate window panes. 1 for thin windows (thickness = 0) and 1 for thick windows (thickness > 0)...
                                            • 2 / 4
