    FlexWindow 2.1 - dynamic component
    62 Posts 14 Posters 45.7k Views 14 Watching
    • halroachH Offline
      halroach
      1. I just discovered this topic:
      "vray makes sketchup slow! (dynamic components)"
      http://sketchucation.com/forums/viewtopic.php?f=322%26amp;t=60187
      Yes, disabling Vray makes them (so much) faster! (highly recommended).
      2. If one wishes to fine tune a DC - to move parts that don't necessarily move where you want them to. Instead of exploding everything and losing the component definitions, you can 'strip them away from their dynamic attributes':
      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=42923
      and,
      http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=40538%26amp;p=592702#p592702
      • Added both of these to the 'notes' in the first post
      • I have also updated the download link.
      Good Day! 😎
      FlexTools - Super Quick Windows, Doors, Slats...
        agrazdi
        I copied several times the window example and modified one of them and i was expecting that all of them would be modified. I am not familiar with dynamic components. Am i doing something wrong, or thats the way they work, and i need to modify each one sepertaly ?
        • halroachH Offline
          halroach
          Dynamic components work a bit differently...
          Once you change one of the dynamic components (that you have copied), it becomes a new component. ("#1") is added to the end of the 'definition name' (see in the entity info window).
          If you wish to edit multiple dynamic components and wish that they all change in the same way, you must select all of them, and then make the changes. Note, that it won't always work like you'd expect it to - because it really depends how the dynamic component was written.
          In the case of FlexWindow, currently, if you select all of them, then make the changes in the 'component options window', they will all change to look the same! even if one of them wasn't in the same proportions to begin with...
          Also, editing multiple dynamic components in this way, may cause some unwanted side effects which I am currently looking into... some 'setting' can kinda stop working...
          I actually intend to introduce in the next update to Flexwindow, a sub-version where one will be able to change settings to multiple instances, without affecting their scale. (thanks to user feedback!)
          • halroachH Offline
            halroach
            And... To make things easy, you could simply insert the dynamic component into a 'regular' component, and copy the 'regular' one all over the place, and they will all be the same... even if you edit the one inside...
              agrazdi
              And... To make things easy, you could simply insert the dynamic component into a 'regular' component, and copy the 'regular' one all over the place, and they will all be the same... even if you edit the one inside...[/quote]
              Thanks, it worked perfect.
              Any date for Corner Window + Door + Slat realese ???
              • halroachH Offline
                halroach
                Glad that worked!
                I have a few more fixes and updates I wish to add to the current FlexWindow.
                In the coming week or so, I hope to introduce FlexSlat! (it's almost done), and the rest will follow... and maybe even more than just those mentioned... 😉
                • halroachH Offline
                  halroach
                  FlexWindow 1.3 released!
                  What's new:
                  • Inset guide - toggle on/off - for easy placement in existing openings.
                  • Glass thickness control
                  • "no-dims" version - without 'opening width & height' dimensions - Enables the ability to select and edit multiple FlexWindow components at once, and each will continue to maintain it's original dimensions.
                    If you've already purchased FlexWindow, you may download this update as well. To access the download, use the same link you received in your original registration email.
                  Enjoy! 😉
                  guide for quick inset placement
                    agrazdi
                    Is there a way to change the default window's glass color and units to meters ??
                    • halroachH Offline
                      halroach
                      1. To change the glass color, like in any component in Sketchup, simply double-click your way in, until you reach the glass geometry and apply any color / material you wish...
                      If the glass has thickness, you might need to apply the material to the inside too, (hide one face, apply to all and unhide...)
                      1. The component is set to use which ever units the model is in. So if your model is defined to display in meters, the component options should be in meters too.
                      Hope that helps
                      • halroachH Offline
                        halroach
                        I have just released FlexSlat 1.0 - The second member of the Flex-Family 😉
                        Check it out:
                        http://sketchucation.com/forums/viewtopic.php?f=40%26amp;t=64960
                        • halroachH Offline
                          halroach
                          FlexWindow 2.0 is out and about!
                          I've been working hard to perfect FlexWindow to make it more useful and adaptable.
                          The major update in this release: You can now choose between 4 different 'profile distribution options'! From now on, every profile will be exactly where you want it to be!
                          Please note that the 'pillars' have been removed in this new edition. I intend to reintroduce them in a new Flex component in the future...
                          For more information on the new 'distribution options' and on other improvements and changes, please see the first post, and/or visit:
                          http://frandzel3d.com/flexwindow
                            rv1974
                            Is the price for fixed product or you practicing some free updates?
                            • halroachH Offline
                              halroach
                              As I've done with version 1.x till now... same with version 2.x. Updates within version 2 will be free for who ever purchased 2.0.
                              Of course, for good updates, the more feedback the merrier! 😄
                              Sent from my iPhone using Tapatalk
                                rv1974
                                BTW I could never could understand it-
                                What's the point of using Tapatalk?
                                • halroachH Offline
                                  halroach
                                  So one could answer quickly when not near his computer !? 😄
                                    rv1974
                                    So the main benefit is 'Subscribe to the thread' feature?
                                    • halroachH Offline
                                      halroach
                                      It's one. If you're really desperate to read threads in bed for instance 😉
                                      • halroachH Offline
                                        halroach
                                        FlexWindow 2.0 now also in Traditional Chinese! - 含繁體中文版本
                                        Just a little update. FlexWindow 2.0 and FlexSlat 1.0 are now available in Chinese too!
                                        If you have purchased these, and wish to download the Chinese version, access the same link from the email you received upon purchase.
                                          shueda
                                          Is there a solution for double-hung windows?
                                          • halroachH Offline
                                            halroach
                                            Not yet. But it's on my list.
                                            I'm currently working on a FlexDoor - which is in working condition (using it on a project of mine), but it's still missing a few important features so it's not in release state yet...).
                                            I've also started working on FlexCornerWindow...
                                            Actually, I would be very glad to hear which types of windows you all would like to see Flexed...
                                            • 2 / 4
