    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    3D Truss Models
    1.5k Posts 31 Posters 977.8k Views 30 Watching
    • medeekM Offline
      medeek
      With the graphical menus you will notice a slight delay once the "submit" button is clicked. This is to allow for a quick display of a status message, however I'm finding this delay to be annoying and may eliminate it altogether to speed the use of the new GUI.
      Also note that with gambrel attic trusses the non-graphical geometry menu is still an option if you turn off the GUI flag in the global settings. For some people this may be easier but I think the new preview pane is a major design asset when it comes to this type of roof.
      I'm thinking it might be useful to implement this same type of preview/GUI for regular attic trusses so that one can preview the configuration before committing. Now that I've been down this road once it won't be such a struggle. Most of the other truss types are fairly simple and a preview image is probably not warranted unless the users say otherwise.
      I feel that the preview window goes a long way in helping explain what each term is in the input geometry menu but I may also add in some pop up windows (?) that display diagrams or other explanatory notes to help the less educated users.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.5.5 - 04.29.2016
        • Added Gambrel Attic truss type, configurations: (AUTO w/ piggyback trusses).
        • Added a graphical user interface (GUI) for gambrel attic geometry input.
        http://design.medeek.com/resources/images/truss_su121_800.jpg
        A reset button would be useful to return the GUI to the default values. There is still a lot of work to be done with the gambrel attic truss type:
        • Advanced Options
        • Gable Trusses
        • Default or Reset Button
        • Metric Input
        View models here:
        3D Warehouse
        (3dwarehouse.sketchup.com)
        3D Warehouse
        design.medeek.com
        • medeekM Offline
          medeek
          This is the level of detail I am aiming for with the advanced options for gambrel attic roofs (minus the truss plates):
          https://scontent-sea1-1.xx.fbcdn.net/t31.0-8/13131738_10208476408255049_4068722961615908164_o.jpg
          Notice the structural outlookers with gable end trusses and the prow roof (option). I've got my work cut out for me.
          design.medeek.com
          • medeekM Offline
            medeek
            The updated truss yard:
            Medeek Truss Yard 3
            Sixteen different truss profiles currently available within the Medeek Truss Plugin:
            • Common
            • Monopitch
            • Attic
            • Scissor
            • Tail Bearing
            • Dual Pitch
            • Bowstring
            • Bow Barrel
            • Polynesian
            • Cambered
            • Cathedral
            • Tray
            • Mono Scissor
            • Mono Cathedral
            • Gambrel Attic
            • Floor (System 42)
            View model here:
            3D Warehouse
            design.medeek.com
            • medeekM Offline
              medeek
              I am wondering how many of your designers/architects/contractors/builders out there have used Open Joist products?
              TRIFORCEĀ® Open Joist: Peace of Mind Underfoot
              The TRIFORCEĀ® open joist is a state-of-the-art product in the forefront of the construction industry.
              TRIFORCEĀ® Open Joist (www.openjoisttriforce.com)
              I was thinking I might add their product line to the Floor Joist/Truss module.
              http://www.openjoisttriforce.com/wp-content/uploads/2013/12/prod-caract-ajust-img3-eng1.jpg
              design.medeek.com
              • medeekM Offline
                medeek
                Version 1.5.6 - 05.11.2016
                • The plugin now automatically checks for updates.
                • Option added in Global Settings to adjust frequency of "check for updates" or to disable this feature entirely.
                I've also added in the Open Joist (TriForce) floor truss but it is not quite ready for release so I have disabled it until the next version release.
                design.medeek.com
                • JQLJ Offline
                  JQL
                  Hi again medeek,
                  I haven't used open joist yet but I will.
                  The only problem I see with it is that it's idea is very interesting but I think fire regulations don't allow for it to be visible.
                  I might be wrong in some cases though, so I'm waiting for them to show up in front of me.
                  Keep up your excellent work!
                  www.casca.pt
                  Visit us on facebook!
                  • medeekM Offline
                    medeek
                    @jql said:
                    Hi again medeek,
                    According to recent research Open Joist trusses seem to perform better in fires than both I-Joists and MPC wood floor trusses. However, there is plenty of debate on the matter.
                    http://www.brackenengineering.com/Portals/0/White%20Papers/White%20Paper%20-%20Fire-Load%20Performance.pdf
                    design.medeek.com
                    • JQLJ Offline
                      JQL
                      I'm recently dealing with a lot of heritage buildings where wood is used (I haven't found any truss similar to the ones in your impressive set yet though) and what our consultants do, so we can build with visible wood on new structures, is to over dimension them. However with such thin profiles I bet this can't be achieved.
                      Do you have any take on that?
                      www.casca.pt
                      • pbacotP Offline
                        @medeek said:
                        @jql said:
                        Hi again medeek,
                        How is this different from the floor trusses you are now doing --or are you talking about this specific manufacturer? They seem to use OSB on part of the trusses for some reason...(Oh, I guess so you can cut to fit in the field?).
                        To clarify. Isn't "open" joist just referring to the product name (and the fact that the truss system is open as opposed to a solid joist. I don't think this necessarily means it's exposed. I doubt many would leave these trusses exposed, but the fire requirement depends on the type of building and/or the floor's rating.
                        • medeekM Offline
                          medeek
                          Sorry for all of the confusing terminology.
                          Open Joist refers to a specific product produced by Barrette in Quebec Canada.
                          There two main products are:
                          Open Joist 2000
                          Open Joist TriForce
                          The thing that makes these floor trusses different from your standard MPC wood floor truss is that they use finger jointed webs instead of metal plates. The floor trusses are made entirely of wood and glue with no metal connectors.
                          They come in standard sizes and lengths with a field trimmable end. They are installed similar to I-Joists using a rim board at the perimeter of the floor.
                          design.medeek.com
                          • JQLJ Offline
                            JQL
                            Pbacot,
                            I meant I like them exposed not that they should be exposed.
                            www.casca.pt
                            • medeekM Offline
                              medeek
                              Building code in the US usually requires some form of 1 hour rated covering (ie. 1/2" gypsum).
                              design.medeek.com
                              • JQLJ Offline
                                JQL
                                In here it's the same, however, if we can prove that the wooden structure will hold one hour more than needed, because of extra thickness, we don't need the covering. This can't be done with steel as heat makes it loose physical properties much faster than what happens with wood.
                                www.casca.pt
                                • medeekM Offline
                                  medeek
                                  For large agricultural buildings a double inverted truss can be employed to provide a large vaulted span for machinery:
                                  http://www.lakecountrytruss.ca/images/trusses/double_inverted_large.jpg
                                  I am wondering if this truss type is still commonly used by anyone for this type of application and whether it would be of interest, enough for me to add it into the growing list of trusses within the plugin.
                                  Also if anyone has any shop drawings they could send me that would be very helpful.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    A quick study of a double inverted truss by taking two 24' howe trusses and joining them to form a double truss. Note that the 4:12 pitch of the original trusses is maintained and the interior vault is exactly 8:12 pitch.
                                    http://design.medeek.com/resources/images/truss_su122_800.jpg
                                    View model here:
                                    3D Warehouse
                                    My question with this configuration is how the top and bottom chords at the peak should butt up? For example should the bottom chords at the peak have a double scarf cut or a single scarf cut? Some shop drawings would help in determining what is common practice.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 1.5.7 - 05.15.2016
                                      • Added Scissor truss type, configurations: (4/2, 6/4).
                                      • Structural outlookers (vert. & horz.) enabled under advanced roof options for Scissor (4/2, 6/4) truss types.
                                      http://design.medeek.com/resources/images/truss_su123_800.jpg
                                      View model here:
                                      3D Warehouse
                                      I also updated the pause in the truss selector GUI from 700 ms to 400 ms. Still more work to be done with raised heels and structural outlookers for some of these configurations but its getting close.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Coffer Truss Algorithm:
                                        http://design.medeek.com/resources/truss/GEOMETRY/COFFER1_800.jpg
                                        This is assuming that the coffer span is centered on the truss. A non-centered coffer algorithm could get significantly more interesting and difficult.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          In Oct. 7 last year I asked what is a bona fide extension in response to Juju's questions. That has led to about 57 releases and quite a large effort to put together a fairly decent plugin that can actually do what it purports to do which is create some accurate trusses and/or roof geometry.
                                          I'm currently at 145 registered users with about ten times that in actual installations of the trial plugin. The number of registered users seems to have plateaued for now with maybe one or two new registrations per week.
                                          I don't know if this is because the plugin exposure is fairly saturated or it simply is not quite good enough to entice an SU user to want to purchase the full version. The plugin is still missing a lot of features and there are quite a few more truss types and roof framing types that need to get added so my hope is that that is the reason for the plateau in the last few weeks.
                                          If you have downloaded the trial version and have decided that more is needed before you are ready to upgrade to the full version please send me an email or message me with details, comments or suggestions on how I can get there. At least 40% of the current plugin is the result of requests from users so feedback has heavily factored into the development and will continue to do so.
                                          I apologize that the manual is still not complete. Over the next month I am going to try and update the existing docs and start adding more content to bring it up to speed.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            This map shows where the Truss Plugin is being utilized:
                                            404 - File or directory not found.
                                            (design.medeek.com)
                                            Note, this is only registered users and not all installations of the trial version. Also note that addresses have been dumbed down to City, State, Country so that the privacy of registered users is upheld.
                                            design.medeek.com
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 75
                                            • 76
                                            • 41 / 76
