    Axes vectors in Sketchup 8
    6 Posts 3 Posters 938 Views 3 Watching
      Deanby7
      I want to offset points along the x, y and z axes and want to setup vector variables. The following doesn't work in Sketchup 8.
      xa, ya, za = Sketchup.active_model.axes.axes
      The Ruby API shows 2016+ in the reference document.
      Is there another way of doing this?
        SketchUp comes with several built in Constants
        ORIGIN X_AXIS Y_AXIS Z_AXIS
        which are, in effect...
        [0,0,0] [1,0,0] [0,1,0] [0,0,1]
        I think you are over thinking this...
          Deanby7
          Trying to follow your example from the holeinthewall!!
          I seem to get hung up on the simplest of things!! I am getting Error: #<ArgumentError: wrong number of values in array> between p "ok" and p "ok2" lines of code!! Grrrrrr
          module DeanBy7
          	module Stair_Builder
          		def self.main
          		    @tht = 2600.mm if(!@tht)
          			@wid = 900.mm if(!@wid)
          			@trd = 32.mm if(!@trd)
          			org = [0,0,0]
          			mod = Sketchup.active_model
          			xa = X_AXIS
          			ya = Y_AXIS
          			za = Z_AXIS
          			ents = mod.entities
          			str_grp = ents.add_group()
          			str_grp.name = "dbStairs"
          			sents = str_grp.entities
          			prompts = ["Stair Height Total", "Stair Width", "Tread Thickness"]
          			results = UI.inputbox prompts, [@tht,@wid,@trd], "db Stair Builder"
          				if results
          					@tht,@wid,@trd = results; mod.start_operation "db Window Opening"
          					p @tht
          					p @wid
          			        testrisers = @tht / 220.mm
          					risers = testrisers.ceil
                              p testrisers
                              p risers
                              riser = @tht / risers
          					p "Riser = " + riser.to_mm.to_s
          					tread = riser / Math.tan(42.degrees)
          					p "Tread = " + tread.to_mm.to_s
          					p0 = [org]
          					p "ok"
          					p1 = p0.offset(xa, @wid)
          					p "ok2"
          					p2 = p1.offset(ya, tread)
          					p3 = p0.offset(ya, tread)
          					step = sents.add_face(p0,p1,p2,p3)
          					step.pushpull @trd
          					mod.commit_operation
          unless file_loaded?("dbstairbuilder")
          	UI.menu("Plugins").add_item("db Stair Builder") { DeanBy7;;Stair_Builder.main }
          	file_loaded("dbstairbuilder")
            Deanby7
            Spotted my error.... p0 = [org] , should be p0 = org
            I had 0,0,0 in there before changing it to a variable. Apologies for wasting forum time!!!
              Of course you can use...
              org = ORIGIN
              BUT... if you want to change org later on, then use
              org = ORIGIN.clone
                To get the working model axes there is a hack for older versions of SU - if you only need the direction. You aren't able to obtain the origin though.
                Here's a snippet directly from Vertex Tools:
                    # SU7+ only - incorrect in older versions.
                    # A hack to get the current model axis.
                    # @return [Array<Vector3d,Vector3d,Vector3d>]
                    # @since 1.0.0
                    def get_local_axis
                      if FEATURE_MOVING_AXIS
                        # SketchUp 8+
                        tr = get_local_transformation
                      elsif @model.respond_to?( ;edit_transform )
                        # SketchUp 7
                        if @model.active_path
                          tr = @model.edit_transform
                        else
                      else
                        # SketchUp 6
                        tr = Geom;;Transformation.new
                      [ tr.xaxis, tr.yaxis, tr.zaxis ]
                    # @since 1.1.0
                    def get_local_transformation
                      @model.start_operation('Get Local Transformation (Hack)')
                      entities = @model.active_entities
                      tr = entities.add_group(entities.add_group).transformation
                      # (?) SketchUp bug?
                      #     The transformation returned has X, Y and Z set to 1.0e+030!
                      #     Why this high value? Overflow bug?
                      Geom;;Transformation.new( tr.xaxis, tr.yaxis, tr.zaxis, ORIGIN )
                    ensure
                      @model.abort_operation
                That FEATURE_MOVING_AXIS constant comes from a check if the SU version is 8 or higher.
