    Anyone know a plugin that can produce wavy lines?
    31 Posts 8 Posters 4.9k Views 8 Watching
      driven
      @ Dave you had the pre v6 mod, which was just a typo, but it also has the 'PC' png icon instead of the pdf mac one I started with...
      @Pete I updated the rbz...
        New version seems to be just fine for me and there's now a nice toolbar button icon. πŸ‘ πŸ‘
          driven
          cheers Dave, how did you make that?
          I did some with just this and moving grouped copies, exploding, but did you use a second plugin for the surfaces?
            John, I made two sine waves, connected them with lines and then used TIG's Extrude Edges by Rails to create a surface. Then Joint P/P for thickness.
              driven
              like this...
              the gifs a bit odd...
                That's definitely another way to do it. πŸ˜„
                • JQLJ
                  JQL
                  Sometimes, out of nowhere, you guys pull off this kind of stunts!
                  Amazing work on the plugin John, amazing simplicity of processes with the scale tool too. Nice simple idea from Dave. Congratulations on a very nice thread!
                  www.casca.pt
                  Visit us on facebook!
                    driven
                    thanks,
                    I'm in a lull from the 'other one' and thought I'd try making some geometry...
                    it was originally based on an old Jim Foltz script and then developed with advice from Jim Hamilton...
                    I'm considering doing a 'Pro' version, so this is the proof on concept...
                    maybe that one that should be subscription only in keeping with the current trends...
                    • pbacotP
                      @driven said:
                      thanks,
                      Yeah! πŸ’š with a dongle that self destructs explosively.
                        driven
                        I think any dongle needs an intermittent fault and an expensive service contract...
                          driven
                          updated the rbz after some v8 glitches were reported...
                          let me know if more are found...
                            Click the pic
                            Latest version works with SO2016 on PC. πŸ‘
                              driven
                              I made it into an Extension and if it doesn't break on PC's I'll add it to the store...
                              updated rbz moved...
                              edit: not tested on early SU versions or Windoze... [a little...]
                                driven
                                I updated again...
                                I hadn't spotted that the mac dialog was less descriptive then intended...
                                I thought I broke it when I added the language files, but looking at the gif above, show it was always broken...
                                • pbacotP
                                  Thanks to OP for bringing this up and provoking plugin inventiveness! (wherever you are)
                                    driven
                                    PC tested, new Icon and lang files...
                                    new icon...
                                    new thread with plugin is Sine Circle
                                      driven
                                        Better French Version! πŸ˜‰
                                        http://s6.postimg.org/sa0s5ecgh/sinus_circulaire.jpg
                                        • 2 / 2
