    [REQ] Rope/wire plugin
    22 Posts 13 Posters 4.8k Views 13 Watching
      Helix along curve ?
      • bazB
        baz
        @tuna1957 said:
        I'll second solo on this. would cheerfully pay $$
        Yep, me too.
        • K
          KENTUCKY
          I was asked to help on a ropes course project a while back. I was trying for a 3 strand rope. I never did come up with a good method and they ultimately just used sketchup line work for their illustrations.
          I felt like I was getting close to a good workflow a few times.
          I think Helix around curve could be modified create multiple helix and then a line to tube ruby could be used. The problem I had was easily creating multiple helix for multiple strands that worked correctly with the diameter of the rope. The helix has to be adjusted based on the diameter of the rope
          I think I attached my test file? I tried anyway.
          Hope that helps someone.
          rope test
            Like in reality! 🤓
            File works fine!
            (next time save "as V6" for a more large audience! 😉
            • Bob JamesB
              Bob James
              @kentucky said:
              I attached a screen shot of a very quick try.
              • soloS
                @kentucky said:
                Would it be possible to use a slightly modified version of the ivy plugin for wrapping rope around an object? You can get a single strand by playing with the parameters.
                You forgot the screenshot.
                Ivy idea sounds good, maybe a little lack of control but still better than nothing.
                • K
                  KENTUCKY
                  • F
                    faust07
                    This could be a solution: LSS Arch 1.5.9. Demo https://youtu.be/5e6SXCSwQg0
                    • the second half of the video.
                    • JQLJ
                      JQL
                      Damn! That's an impressive plugin! Will try ASAP!
                      www.casca.pt
                      Visit us on facebook!
                      • cottyC
                        cotty
                        Maybe this plugin can be a start?
                        http://sketchucation.com/forums/viewtopic.php?f=80%26amp;t=64302#p589620
                        my SketchUp gallery
                        • PixeroP
                          Pixero
                          What! I never heard of this plugin. Looks fantastic! 😎
                          • PixeroP
                            Pixero
                            Here is perhaps a solution:
                            http://sketchucation.com/forums/viewtopic.php?f=80%26amp;t=64796
                            http://www.sketchrope.com/
                            • N
                              nektares
                              Maybe this, on first step just draw a rough aproximation of where you want the rope to go.
                              on step two adjust it and then convert it with bz toolbar to catmull spline
                              and then the final step just tube along path or follow me along the generated catmull spline.
                              rope
                                AcesHigh
                                Nektares, this seems quite complicated for more complex geometry, like the part where the rope goes around that tube. And it may not end up realistic. A more complex scene with a rope might be too complicated for this method to work.
                                @Solo: aside Ropefall, which is subscription based, have you thought of using some BLENDER? Export model to Blender, do the rope, re-import rope to Sketchup?
                                Not the best workflow, but maybe better than pay a subscription plugin, specially if you do not need ALL THE TIME to work with complex ropes.
                                here, a tutorial on ropes in Blender. With the added benefit of already creating realistic ropes with the strands twisting, etc
                                404 Not Found
                                (www.cgmeetup.net)
                                • jujuJ
                                  juju
                                  the plugin author has since changed to optional perpetual licence...
                                  • bazB
                                    baz
                                    [attachment=0:18pbu3s6]<!-- ia0 -->rope_test1.jpg<!-- ia0 -->[/attachment:18pbu3s6]
                                    That's a goer for me, I hadn't realized that BZ could convert straight lines. For my needs that works plenty good.
                                    Thanks.
                                      Seems Ivy can also make some interesting things! 😉
                                      Following a surface!
                                      http://sketchucation.com/forums/download/file.php?id=134892&t=1
                                      • JQLJ
                                        JQL
                                        [attachment=0:25tsseem]<!-- ia0 -->rope_test1.jpg<!-- ia0 -->[/attachment:25tsseem]
                                        The times I tried the same workflow tube along path worked better.
                                        www.casca.pt
