    [REQ] Rope/wire plugin
    22 Posts 13 Posters 4.1k Views 13 Watching
    • soloS Offline
      I am looking for a plugin that I know does not exist, I need to drape, position ropes and wires around obstacles. Right now it's a painfully slow process using current tools.
      Here is something close to what I'd love. (turn down the volume and see around 40 seconds what I mean)
      Thoughts?
      • tuna1957T Offline
        tuna1957
        I'll second solo on this. would cheerfully pay $$
        • soloS Offline
          @pixero said:
          Isn't there a script called catenary curve or something?
          I believe it was made for hanging wires or such.
          Might be useful.
          Edit: I found this: https://extensions.sketchup.com/nl/content/wire-tool
          I have that, it just hangs wires, I need it to go around poles, walls, off ledges etc.
          • PixeroP Offline
            Pixero
            Might be useful.
            What would be really cool is a spline FFD that could deform geometry in realtime
              Helix along curve ?
              • bazB Offline
                baz
                Yep, me too.
                  KENTUCKY
                  I was asked to help on a ropes course project a while back. I was trying for a 3 strand rope. I never did come up with a good method and they ultimately just used sketchup line work for their illustrations.
                  I felt like I was getting close to a good workflow a few times.
                  I think Helix around curve could be modified create multiple helix and then a line to tube ruby could be used. The problem I had was easily creating multiple helix for multiple strands that worked correctly with the diameter of the rope. The helix has to be adjusted based on the diameter of the rope
                  I think I attached my test file? I tried anyway.
                  Hope that helps someone.
                  rope test
                    Like in reality! 🤓
                    File works fine!
                    (next time save "as V6" for a more large audience! 😉
                    • Bob JamesB Offline
                      Bob James
                      @kentucky said:
                      I attached a screen shot of a very quick try.
                      • soloS Offline
                        @kentucky said:
                        Would it be possible to use a slightly modified version of the ivy plugin for wrapping rope around an object? You can get a single strand by playing with the parameters.
                        You forgot the screenshot.
                        Ivy idea sounds good, maybe a little lack of control but still better than nothing.
                          KENTUCKY
                          • F Offline
                            faust07
                            This could be a solution: LSS Arch 1.5.9. Demo https://youtu.be/5e6SXCSwQg0
                            • the second half of the video.
                            • JQLJ Offline
                              JQL
                              Damn! That's an impressive plugin! Will try ASAP!
                              www.casca.pt
                              Visit us on facebook!
                              • cottyC Offline
                                cotty
                                Maybe this plugin can be a start?
                                http://sketchucation.com/forums/viewtopic.php?f=80%26amp;t=64302#p589620
                                my SketchUp gallery
                                • PixeroP Offline
                                  Pixero
                                  What! I never heard of this plugin. Looks fantastic! 😎
                                  • PixeroP Offline
                                    Pixero
                                    Here is perhaps a solution:
                                    http://sketchucation.com/forums/viewtopic.php?f=80%26amp;t=64796
                                    http://www.sketchrope.com/
                                    • N Offline
                                      nektares
                                      Maybe this, on first step just draw a rough aproximation of where you want the rope to go.
                                      on step two adjust it and then convert it with bz toolbar to catmull spline
                                      and then the final step just tube along path or follow me along the generated catmull spline.
                                      rope
                                        AcesHigh
                                        Nektares, this seems quite complicated for more complex geometry, like the part where the rope goes around that tube. And it may not end up realistic. A more complex scene with a rope might be too complicated for this method to work.
                                        @Solo: aside Ropefall, which is subscription based, have you thought of using some BLENDER? Export model to Blender, do the rope, re-import rope to Sketchup?
                                        Not the best workflow, but maybe better than pay a subscription plugin, specially if you do not need ALL THE TIME to work with complex ropes.
                                        here, a tutorial on ropes in Blender. With the added benefit of already creating realistic ropes with the strands twisting, etc
                                        404 Not Found
                                        (www.cgmeetup.net)
                                        • jujuJ Offline
                                          juju
                                          the plugin author has since changed to optional perpetual licence...
                                          • bazB Offline
                                            baz
                                            [attachment=0:18pbu3s6]<!-- ia0 -->rope_test1.jpg<!-- ia0 -->[/attachment:18pbu3s6]
                                            That's a goer for me, I hadn't realized that BZ could convert straight lines. For my needs that works plenty good.
                                            Thanks.
