    Single/twin occupancy dwelling 24' square.
    34 Posts 7 Posters 9.8k Views 7 Watching
    • GarethG Offline
      Gareth
      I agree, 8m x 8m is fairly generous. I have a suite of designs for a low cost housing project which are based on a footprint of 6m x 6m.
      The key is to carefully overlap spaces whilst trying to avoid unnecessary circulation conflicts. Generally, think in terms of "Zones" rather than "Rooms"
        Not getting myself across vey well there. sorry. The majority of drawings are based around a 15 square foot footprint. Not sure what to do with all the space so I tend to over emphasize the individual units also, I tend to have the dining table and chairs hide in a cupboard for the most part.
        15' pad
        • pbacotP Offline
          Do you have examples of built units, and how people are using them? But I'd agree with Richard, given your first plan. There's more room on the left for living space and the right would fit the dining OK.
            No I do not, simply because I am not an architect, not working in the business and use this as a hobby. Most of these spaces have dual use in -particular the dining area and traditional tables etc are not intended to be used in these spaces. The dining tables are meant to be tucked away out of sight allowing the area to be used as a coffee/lounge area.
              Just to explain, I do not mean to be rude or give offence, I am just explaining my status. I'm sorry for any offence.
                I have moved the goalpost's a bit to a 20 foot square footprint, I got a little lost with so much space. The render below is just playing with the use of a light sculpture/picture as a method of illumination. I don't like the room lights so will have to alter by trial and error.
                Light sculpture test 1
                  The 20' version from the kitchen towards the living area.
                  From kitchen to rear of property.
                  Living area to kitchen.
                    Better lights and more interesting too. This is rendered with Renditioner V3
                    Lights, camera etc.....
                      Evening shot from living to kitchen.
                      As above.
                      • JQLJ Offline
                        JQL
                        Don't you have windows except for the kitchen Mike?
                        www.casca.pt
                        Visit us on facebook!
                          There is a set of patio doors to the right of the dining table and there is a glass element to the front door, there is also a small window in the wet room which is behind the stairs but that, like the door, cannot be seen from this angle.
                            Another view, I have changed some of the lights.
                            Kitchen to front door and wet room/toilet.
                              Another reduction in size means that everything is reduced to what is NEEDED with no extraneous frills or frippery. No hob for example with cooking via a convection microwave oven. There does need to be a full size fridge freezer of course for all those instant meals and beverages for football/F1/films etc
                              16' of cramped up goodness, I hope.
                                I added detail to the exterior, no front door yet, no idea what type to use yet.
                                Same as above.
                                • Bryan KB Offline
                                  Looking good!
                                    Ta mate, not finishing much these days, must do better.
                                    • DanielD Offline
                                      Daniel
                                      Nice images, Mike. I would be careful of making that living room too small, though. I have a living room where the TV is only 5' from the sofa; I discovered I can only play the simplest, stationary games on my Wii without hitting the TV. It also means very few visitors.
                                      My avatar is an anachronism.
                                      • DanielD Offline
                                        Daniel
                                        Mike, looking at your original plans, I would swap the dining and living spaces, as Richard suggests. Also, I can't tell what the first floor space on the other side of the stairs is - can it be relocated upstairs, and can you slide the stair back? Seems like a lot of space upstairs for one bedroom (compared to the rest of the dwelling).
                                        I've seen others try there hand at these little cube houses. It's an interesting architectural problem.
                                          On the original plans as I laid them out, there is a small two person dining table and chairs, moving them across would place the tv against the wall and the sofa in the middle of the plan which would put it in the way of through traffic and clutter the plan. At least that is the way I see it. I do like to play with these spaces though.
                                            I know what you mean but I am not familiar with the sort of games you are talking about, too old probably. The interior is only 14' 8" BY 14' 8" and there is a 3' wide set of stairs too but that could be made narrower possibly. Could any setup allow for the games you mention? Without turning the television into a very expensive insurance policy. This place is only meant for a single person btw. Thanks for your points/comments, I will keep them in mind for the next one.
                                            • 2 / 2
