    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 458.8k Views 70 Watching
      Garry K
      If you want to have a shared location for templates and library files there is a way. I created a shared location on a different drive and then set up a batch file to point to that location.
      One reason to do this is if you have several licensed computers and you want to have 1 set of templates. Another reason is you want to make sure your templates don't get over written during an update.
      From the command prompt
      subst x: e:\library\gkware_cabmaker
      Then copy the following files into the shared area
      Next from the main menu choose
      Extensions\GKWare_CabMaker\Cab Maker - Edit Config
      And set the library location to x:
      Finally restart sketchup for the changes to take effect.
        Garry K
        I spent another 2 days testing and found a few more errors in the tall cabinets.
        Now pretty happy with the test suite. The skp test file is 7 megs and contains 90 tall cabinets of various constructions and configurations.
        Version 1.0.40
        • some configurations for frame less overlay construction for tall cabinets had the doors in the bottom section incorrect heights. fixed
        • the auto drawer size feature was not properly updating the drawer height. fixed
        • when using auto drawer size the drawer box height was inconsistent. fixed
        • For Overlay doors only the top Gap can be now be eliminated by setting the value to negative door gap.
        Here are the 90 tall cabinets
          Garry K
          Version 1.0.40 now ready for download
            Garry K
            1.0.41 ready for download
            Version 1.0.41 - Mar 30, 2016
            • Side dado's incorrect for Base cabinets with Integrated Kick with a 0 notch and side dadoes. Fixed
            • Sink cabinets with side dado and rule to omit top had top dado. Top dado should be skipped. Fixed
            • Parts report sometimes missing a part. Fixed
            • Added new parts report for Gold. *_full_part_list.csv
            • Added configuration setting for 'Silent Permissions'
            • Update manual and added lines to translation files
              Garry K
              I am working on a new way to choose a cabinet from the library for those of you who want to work with libraries.
              The idea is to add a find button, then pop up a new window that contains pictures of your cabinets. There would be a bit of work on your part.
              What does everyone think?
                abdalmalki
                Garry,
                I think it will consume a lot of your time without big advantage to the software.
                That's my two cents.
                  Garry K
                  Version 1.0.42
                  • Added Confirm Save Configuration and a confirm popup to Web Dialog.
                  • Added context sensitive help for cabinet templates. If 320 X 240 png image exists in library folder
                  • Added version number to web dialog title
                  • Side by Side drawers now work for frameless construction and stretchers set to at least 1
                  • You now have option for edging upper cabinet ends of the sides if not skinning the top and or bottom
                  • Corner cabinet adjustable shelving had edging along the back where the shelf butts up against the corner brace. Fixed
                  • Sides, Top and Bottom front edges had edging with face frame construction. Fixed
                  • You can override shelf spacing for up to 3 shelves
                  • You can now set pullout spacing for up to 3 pullouts or use the default rule
                  • Cabinets with 1 door set to pullout now works with more than 1 pullout
                    Garry K
                    You can set the openings (space between shelves) and (space between pullouts) here
                    You can have different shelf width adjustments for Uppers and Base cabinets and have 2 widths for shelves for base cabinets. Also you can edge the ends of sides - bottom, top, none or both.
                    Set the new values to -1 to disable
                    Here is the change for multiple pullouts with a door.
                    Here are split sink shelves - you set the length - set to -1 to disable.
                      Garry K
                      Version 1.0.42 is now ready for download
                        Garry K
                        Added pigeon hole capability using vertical dividers and horizontal dividers. Works with frameless or face frame construction and for uppers or base cabinets.
                        This can work as a wine rack.
                        • utilerU Offline
                          utiler
                          Looks like my wine rack, Garry...
                          Always empty. šŸ˜•
                          Just Curious...
                            Garry K
                            Andrew - mine too. Someone suggested that I have to buy it faster than I drink it!
                            In actuality one of my hobbies is making wine. We live in wine country in British Columbia Canada. I do have a cool dark cellar and a metal wine rack that stores bottles 30 per shelf. Each shelf holds 8 bottles on the first row, 7 on the second row etc.
                            Wine ages best in a cool dark place. The advantage of having the bottles touch each other in this way is that it is suppose to reduce the effect of small temperature fluctuations.
                              Garry K
                              Version 1.0.43 will be ready today for download
                              • Added horizontal grid along with vertical dividers. Can use as a wine rack.
                              • Modified the web dialog materials tab. Colors now show on a empty label just to the left of the color pulldown.
                              • Modified web dialog. When Mac users use arrow keys in a closed drop down the graphics now update like it does for Windows users.
                                Garry K
                                Version 1.0.43 ready for download
                                Next I am looking at adding a right and left angled cabinet. This style of cabinet is for finishing a run of cabinets.
                                  Garry K
                                  Version 1.0.44 fixes a number of bugs that where version specific
                                  Ready for download - those running sketchup 2016 do not need to upgrade.
                                  • Older versions of sketchup that used Ruby 1.8 and did not support round(decimals). fixed
                                  • Older versions of sketchup 7, 8 and 2013 do not support adding linear dimensions programatically. CabMaker now detects sketchup version and only attempts dimensions for version 14.0 and greater
                                  • The way I was grabbing images for cabinet templates only worked on recent versions of sketchup. Fixed
                                    Garry K
                                    You can now create your own extruded profile and create plain doors or embossed doors with extruded handles.
                                    Here is the profile that I've included.
                                    You can also create a top double drawer with a bank of drawers.
                                    • FrederikF Offline
                                      Frederik
                                      Awesome...! šŸ‘
                                      Cheers
                                      Kim Frederik
                                      • deaneauD Offline
                                        deaneau
                                        Hi i have seen that some models use IKEA.
                                        here is the IKEA Family-Color-Chart.
                                        the base of the Colors is the PDF-File in the Archive.
                                        This PDF was saved with " DIGITALFarbatlas"
                                        DIGITAL COLOUR ATLAS 5.0
                                        (dtpstudio.de)
                                        the download for the Version5 is only avaiable in German.
                                        IKEA Family.rar
                                          Garry K
                                          A user was asking how to have cabinets with plant on cabinet backs.
                                          Simple. Set the "Back Offset" to 0 mm and set the "Back Dado / Rabbet" to the same value as the thickness of the case material.
                                          In this case he uses a back thickness of 12 mm and a case thickness of 19 mm. His cabinet depth was set to 600 mm.
                                          Also please note that the parts listing takes care of itself.
                                            Garry K
                                            Version 1.0.45 now available for download.
                                            Add a requested feature for face frame construction. You can now hide the left and or right outer edge of the stiles. This means you can set up your cabinets so that where 2 stiles meet they appear to be a single stile. This along with adjusting the width of the stiles will provide the effect of a single stile. Please note that you must have edge profiles turned off.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 31
                                            • 32
                                            • 13 / 32
