    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 646.7k Views 71 Watching
    • G
      Garry K
      I am doing a fairly thorough testing of the Tall Cabinets. So many permutations and combinations that it is taking longer than I originally anticipated.
      There are 7 section combinations Times 6 constructions Times 3 for uppers, base integrated and base non integrated.
      That's 142 combinations and doesn't even begin to deal with different types of interiors.
      Here is a model containing 24 different tall cabinets. The 3 rows on the right are uppers, integrated base, and non integrated base. The six columns on the right represent 6 constructions.
      The six cabainets on the left (2 rows of 3) represent 1 construction for base cabinets with integrated kick
      These tests have uncovered a few Face Frame bugs that you can visually see. The cabinets with 1 and with 2 sections show correct top gap but only the cabinets that have the bottom section have correct bottom gap. Additionally one cabinet has rendered incorrectly.
      So ... testing continues.
      • G
        Garry K
        Version 1.0.39 is now ready to download.
        Available from my web site or from Sketchucation.
        • G
          Garry K
          If you want to have a shared location for templates and library files there is a way. I created a shared location on a different drive and then set up a batch file to point to that location.
          One reason to do this is if you have several licensed computers and you want to have 1 set of templates. Another reason is you want to make sure your templates don't get over written during an update.
          From the command prompt
          subst x: e:\library\gkware_cabmaker
          Then copy the following files into the shared area
          Next from the main menu choose
          Extensions\GKWare_CabMaker\Cab Maker - Edit Config
          And set the library location to x:
          Finally restart sketchup for the changes to take effect.
          • G
            Garry K
            I spent another 2 days testing and found a few more errors in the tall cabinets.
            Now pretty happy with the test suite. The skp test file is 7 megs and contains 90 tall cabinets of various constructions and configurations.
            Version 1.0.40
            • some configurations for frame less overlay construction for tall cabinets had the doors in the bottom section incorrect heights. fixed
            • the auto drawer size feature was not properly updating the drawer height. fixed
            • when using auto drawer size the drawer box height was inconsistent. fixed
            • For Overlay doors only the top Gap can be now be eliminated by setting the value to negative door gap.
            Here are the 90 tall cabinets
            • G
              Garry K
              Version 1.0.40 now ready for download
              • G
                Garry K
                1.0.41 ready for download
                Version 1.0.41 - Mar 30, 2016
                • Side dado's incorrect for Base cabinets with Integrated Kick with a 0 notch and side dadoes. Fixed
                • Sink cabinets with side dado and rule to omit top had top dado. Top dado should be skipped. Fixed
                • Parts report sometimes missing a part. Fixed
                • Added new parts report for Gold. *_full_part_list.csv
                • Added configuration setting for 'Silent Permissions'
                • Update manual and added lines to translation files
                • G
                  Garry K
                  I am working on a new way to choose a cabinet from the library for those of you who want to work with libraries.
                  The idea is to add a find button, then pop up a new window that contains pictures of your cabinets. There would be a bit of work on your part.
                  What does everyone think?
                    abdalmalki
                    Garry,
                    I think it will consume a lot of your time without big advantage to the software.
                    That's my two cents.
                    • G
                      Garry K
                      Version 1.0.42
                      • Added Confirm Save Configuration and a confirm popup to Web Dialog.
                      • Added context sensitive help for cabinet templates. If 320 X 240 png image exists in library folder
                      • Added version number to web dialog title
                      • Side by Side drawers now work for frameless construction and stretchers set to at least 1
                      • You now have option for edging upper cabinet ends of the sides if not skinning the top and or bottom
                      • Corner cabinet adjustable shelving had edging along the back where the shelf butts up against the corner brace. Fixed
                      • Sides, Top and Bottom front edges had edging with face frame construction. Fixed
                      • You can override shelf spacing for up to 3 shelves
                      • You can now set pullout spacing for up to 3 pullouts or use the default rule
                      • Cabinets with 1 door set to pullout now works with more than 1 pullout
                      • G
                        Garry K
                        You can set the openings (space between shelves) and (space between pullouts) here
                        You can have different shelf width adjustments for Uppers and Base cabinets and have 2 widths for shelves for base cabinets. Also you can edge the ends of sides - bottom, top, none or both.
                        Set the new values to -1 to disable
                        Here is the change for multiple pullouts with a door.
                        Here are split sink shelves - you set the length - set to -1 to disable.
                        • G
                          Garry K
                          Version 1.0.42 is now ready for download
                          • G
                            Garry K
                            Added pigeon hole capability using vertical dividers and horizontal dividers. Works with frameless or face frame construction and for uppers or base cabinets.
                            This can work as a wine rack.
                            • utilerU
                              utiler
                              Looks like my wine rack, Garry...
                              Always empty. šŸ˜•
                              Just Curious...
                              • G
                                Garry K
                                Andrew - mine too. Someone suggested that I have to buy it faster than I drink it!
                                In actuality one of my hobbies is making wine. We live in wine country in British Columbia Canada. I do have a cool dark cellar and a metal wine rack that stores bottles 30 per shelf. Each shelf holds 8 bottles on the first row, 7 on the second row etc.
                                Wine ages best in a cool dark place. The advantage of having the bottles touch each other in this way is that it is suppose to reduce the effect of small temperature fluctuations.
                                • G
                                  Garry K
                                  Version 1.0.43 will be ready today for download
                                  • Added horizontal grid along with vertical dividers. Can use as a wine rack.
                                  • Modified the web dialog materials tab. Colors now show on a empty label just to the left of the color pulldown.
                                  • Modified web dialog. When Mac users use arrow keys in a closed drop down the graphics now update like it does for Windows users.
                                  • G
                                    Garry K
                                    Version 1.0.43 ready for download
                                    Next I am looking at adding a right and left angled cabinet. This style of cabinet is for finishing a run of cabinets.
                                    • G
                                      Garry K
                                      Version 1.0.44 fixes a number of bugs that where version specific
                                      Ready for download - those running sketchup 2016 do not need to upgrade.
                                      • Older versions of sketchup that used Ruby 1.8 and did not support round(decimals). fixed
                                      • Older versions of sketchup 7, 8 and 2013 do not support adding linear dimensions programatically. CabMaker now detects sketchup version and only attempts dimensions for version 14.0 and greater
                                      • The way I was grabbing images for cabinet templates only worked on recent versions of sketchup. Fixed
                                      • G
                                        Garry K
                                        You can now create your own extruded profile and create plain doors or embossed doors with extruded handles.
                                        Here is the profile that I've included.
                                        You can also create a top double drawer with a bank of drawers.
                                        • FrederikF
                                          Frederik
                                          Awesome...! šŸ‘
                                          Cheers
                                          Kim Frederik
                                          • deaneauD
                                            deaneau
                                            Hi i have seen that some models use IKEA.
                                            here is the IKEA Family-Color-Chart.
                                            the base of the Colors is the PDF-File in the Archive.
                                            This PDF was saved with " DIGITALFarbatlas"
                                            404 Not Found
                                            (dtpstudio.de)
                                            the download for the Version5 is only avaiable in German.
                                            IKEA Family.rar
                                            With your input, this post could be even better šŸ’—
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 31
                                            • 32
                                            • 13 / 32
