    FlexWindow 2.1 - dynamic component
    62 Posts 14 Posters 45.7k Views 14 Watching
    • halroachH Offline
      halroach
      @pilou said:
      Funny! 😎
      Nothing about circle or round forms? (Front or Top )
      Are the above images from a plugin or dc you've made? (they look familiar 😄)
      I started this dynamic component out of a need to quickly populate sketch models with all sorts of (straight! 😄) windows. And I mean, really quickly! I know there are many plugins that do windows out there... For me, most of them go into too much detail. Or they are too slow or inconvenient... I'm sure I may have missed a few that could be helpful.
      I can imagine how to make windows round in front... Would you need that? On top... that would probably be a bit more difficult.
      As for Gaudy! I think only he would know how to make a DC for his windows 😎
      FlexTools - Super Quick Windows, Doors, Slats...
        Alas I have no SU Pro version so DC creations are not for me! 😕
        But I can use them created by other genious creators! 😉
        (Maybe it's a chance for have possibilities to make other funny things! 💚
        Personnaly I have no need "curvated windows" but seems that will be useful for someone! 🤓
        • utilerU Offline
          utiler
          Simple and interesting..
          Just Curious...
          • jujuJ Offline
            juju
            what's the difference between the lite version and the full/pro version?
            • halroachH Offline
              halroach
              Basically everything above where it says "Additions in the full version:" is in the lite version. And everything below that is in the full version - including the latest addition of pillars in v1.1 .
              Maybe my description isn't clear, I'll try to rewrite it to make things clearer.
              • N Offline
                nickchun
                This looks good but I have had this error come up
                Followed by this one..
                • halroachH Offline
                  halroach
                  Try to explode the component once and see if it works...
                  Sent from my iPhone using Tapatalk
                  • N Offline
                    nickchun
                    Thanks. Yes that works now. I notice several of the parts overlap and do not automatically trim, such as the glass and horizontal profiles. Is that to make it quicker?
                    • halroachH Offline
                      halroach
                      Yep. I kept the glass as one component to keep things as speedy as possible. I'll mention that too in the description...
                      • jujuJ Offline
                        juju
                        That'll make it terrible to have a section run through...
                        • halroachH Offline
                          halroach
                          I guess it depends what you're using the section for. In the 2 section images above, I used the "section cut face" plugin, it worked perfectly.
                          The calculations for separate glass panels pretty much defeats the whole idea behind Flexwindow. Over a certain amount of divisions it just slows down to a crawl. I could try to make an option to toggle between one glass panel for speed, and separate panels for finalizing... I'll think about it.
                          • halroachH Offline
                            halroach
                            Flexwindow 1.1 is out! - [highlight=#ffff80:14yns36y]Dynamic pillars added![/highlight:14yns36y]
                            To make Flexwindow a 'little closer' to reality when creating large facades, there is now an option to add pillars. (vs. the earlier version in which I used the vertical profiles as pillars).
                            Pillar options:
                            • (a) pillars are centered with the vertical profiles.
                              (note: If pillars are larger than 2*framewidth, they are no longer centered exactly but distributed in an equal distance between the boundaries of the component.
                            • (b) freely specify number of pillar divisions between the frame.
                            • (c) pillars OFF.
                            Additional features:
                            • frame width can be set to 0 - and it disappears!
                              note: **1.**It will affect how pillars are centered in option (b). **2.**frame depth still affects component boundaries.
                            • Using the interact tool:
                              on profiles - adds divisions
                              on frame - subtracts divisions.
                              note: You can click as many times as you want on the frame to subtract and it will always stay with the minimum of 2 - don't worry about clicking too much.
                            note for those who have purchased flexwindow 1.0, you should be able to use the same links to download the updated flexwindow 1.1. If there are any problems, let me know.
                            I'll be glad to hear some feedback, opinions, suggestions for additional/better/easier/clearer features...
                            section of Flexwindow facade with pillars
                            • halroachH Offline
                              halroach
                              Flexwindow 1.2 is out! - [highlight=#ffff80:be77ejqe]Window sill added![/highlight:be77ejqe]
                              New in this version:
                              • window sill added
                              • specify sill width, depth, protrusion to the sides.
                              • set sill width to 0 makes it disappear.
                              • interact tool on sill - toggles side protrusions. note: protrusions should be toggled to off when scaling the component.
                              • improved pillar positioning in relation to frame width minimum - (option (a))
                              • restyled options window to take less real estate.
                              • rearranged options to make them more comfortable.
                              • totally rewritten to accommodate further development...!
                              Those who have purchased previous versions can now download this version as well.
                              Enjoy! 😄
                              [attachment=1:be77ejqe]<!-- ia1 -->flexwindow 1.2 component options window<!-- ia1 -->[/attachment:be77ejqe]
                              • erikBE Offline
                                erikB
                                Very handy dynamic component for quick and easy use. Especially with the new feature (window sill).
                                Concerning the glass. As far as I am concerned I do not mind it running trough the mullions BUT speaking for myself there even should not be double panes. It is hardly visible in a sketchup drawing (only with a close-up) and when rendering (p.e. thea) double panes are rarely used because it only creates extra time and no significant difference in the outcome.Come to think off it in sketchup the double panes also gives a extra thick line when using a section cut.
                                But all in all, congrats for this very useful component,
                                erikB
                                • pbacotP Offline
                                  By Double panes--is each glass component two surfaces or insulated panes that are two surfaces separated by 1" or more...or four surfaces?
                                  • erikBE Offline
                                    erikB
                                    No, I mean the glass is draw as 2 planes (representing the two panes I suppose, or perhaps giving the one pane some thickness? Either way for my the use a simple plane (1) (representing 2 separated glas panes or thickness if one pane was intended ) would have been enough. (cfr. windowizer here the glas is also only represented by a simple plane.
                                    erikB
                                    • halroachH Offline
                                      halroach
                                      erikB
                                      Hi Erik,
                                      Yes, the window is simply a 1cm wide box. You can easily convert it to a single plane by double clicking your way into it, selecting all the geometry and deleting the "thickness" - basically replacing it with a single face. Just make sure to place the face right on the axis of the component!
                                      Let me know if there is any problem with it... it should work just fine!
                                      • PixeroP Offline
                                        Pixero
                                        You could perhaps make a setting for glass thickness where 0 is just a single plane.
                                        • halroachH Offline
                                          halroach
                                          Yep, that could easily be done. I'm just afraid of having too many settings on the 'component options' window. And it will add yet more hidden geometry which I'd like to keep to a minimum.
                                          As it is now, I feel there are too many settings. The window barely fits on my screen (1200 pixels vertically), and I'm thinking of adding even more features and setting in future versions... Like beams between the pillars (they are kind of missing I think) I'm not sure where all the settings are going to fit...
                                          suggestions for real estate optimization methods are welcome! 😄
                                          How about, if I make the glass one surface to begin with. And if anyone wants it to be think, just to push pull it in the 'natural' direction and it will center itself (like it does now)? It's a small difference than how it is now, but easier for the end user I think.
                                          • PixeroP Offline
                                            Pixero
                                            For rendering it is better with glass who has thickness.
                                            • 1 / 4
