    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin] GKWare Cabinet Maker
    625 Posts 67 Posters 439.5k Views 68 Watching
      Garry K
      Version 1.0.39 is now ready to download.
      Available from my web site or from Sketchucation.
        Garry K
        If you want to have a shared location for templates and library files there is a way. I created a shared location on a different drive and then set up a batch file to point to that location.
        One reason to do this is if you have several licensed computers and you want to have 1 set of templates. Another reason is you want to make sure your templates don't get over written during an update.
        From the command prompt
        subst x: e:\library\gkware_cabmaker
        Then copy the following files into the shared area
        Next from the main menu choose
        Extensions\GKWare_CabMaker\Cab Maker - Edit Config
        And set the library location to x:
        Finally restart sketchup for the changes to take effect.
          Garry K
          I spent another 2 days testing and found a few more errors in the tall cabinets.
          Now pretty happy with the test suite. The skp test file is 7 megs and contains 90 tall cabinets of various constructions and configurations.
          Version 1.0.40
          • some configurations for frame less overlay construction for tall cabinets had the doors in the bottom section incorrect heights. fixed
          • the auto drawer size feature was not properly updating the drawer height. fixed
          • when using auto drawer size the drawer box height was inconsistent. fixed
          • For Overlay doors only the top Gap can be now be eliminated by setting the value to negative door gap.
          Here are the 90 tall cabinets
            Garry K
            Version 1.0.40 now ready for download
              Garry K
              1.0.41 ready for download
              Version 1.0.41 - Mar 30, 2016
              • Side dado's incorrect for Base cabinets with Integrated Kick with a 0 notch and side dadoes. Fixed
              • Sink cabinets with side dado and rule to omit top had top dado. Top dado should be skipped. Fixed
              • Parts report sometimes missing a part. Fixed
              • Added new parts report for Gold. *_full_part_list.csv
              • Added configuration setting for 'Silent Permissions'
              • Update manual and added lines to translation files
                Garry K
                I am working on a new way to choose a cabinet from the library for those of you who want to work with libraries.
                The idea is to add a find button, then pop up a new window that contains pictures of your cabinets. There would be a bit of work on your part.
                What does everyone think?
                  abdalmalki
                  Garry,
                  I think it will consume a lot of your time without big advantage to the software.
                  That's my two cents.
                    Garry K
                    Version 1.0.42
                    • Added Confirm Save Configuration and a confirm popup to Web Dialog.
                    • Added context sensitive help for cabinet templates. If 320 X 240 png image exists in library folder
                    • Added version number to web dialog title
                    • Side by Side drawers now work for frameless construction and stretchers set to at least 1
                    • You now have option for edging upper cabinet ends of the sides if not skinning the top and or bottom
                    • Corner cabinet adjustable shelving had edging along the back where the shelf butts up against the corner brace. Fixed
                    • Sides, Top and Bottom front edges had edging with face frame construction. Fixed
                    • You can override shelf spacing for up to 3 shelves
                    • You can now set pullout spacing for up to 3 pullouts or use the default rule
                    • Cabinets with 1 door set to pullout now works with more than 1 pullout
                      Garry K
                      You can set the openings (space between shelves) and (space between pullouts) here
                      You can have different shelf width adjustments for Uppers and Base cabinets and have 2 widths for shelves for base cabinets. Also you can edge the ends of sides - bottom, top, none or both.
                      Set the new values to -1 to disable
                      Here is the change for multiple pullouts with a door.
                      Here are split sink shelves - you set the length - set to -1 to disable.
                        Garry K
                        Version 1.0.42 is now ready for download
                          Garry K
                          Added pigeon hole capability using vertical dividers and horizontal dividers. Works with frameless or face frame construction and for uppers or base cabinets.
                          This can work as a wine rack.
                          • utilerU Offline
                            utiler
                            Looks like my wine rack, Garry...
                            Always empty. šŸ˜•
                            Just Curious...
                              Garry K
                              Andrew - mine too. Someone suggested that I have to buy it faster than I drink it!
                              In actuality one of my hobbies is making wine. We live in wine country in British Columbia Canada. I do have a cool dark cellar and a metal wine rack that stores bottles 30 per shelf. Each shelf holds 8 bottles on the first row, 7 on the second row etc.
                              Wine ages best in a cool dark place. The advantage of having the bottles touch each other in this way is that it is suppose to reduce the effect of small temperature fluctuations.
                                Garry K
                                Version 1.0.43 will be ready today for download
                                • Added horizontal grid along with vertical dividers. Can use as a wine rack.
                                • Modified the web dialog materials tab. Colors now show on a empty label just to the left of the color pulldown.
                                • Modified web dialog. When Mac users use arrow keys in a closed drop down the graphics now update like it does for Windows users.
                                  Garry K
                                  Version 1.0.43 ready for download
                                  Next I am looking at adding a right and left angled cabinet. This style of cabinet is for finishing a run of cabinets.
                                    Garry K
                                    Version 1.0.44 fixes a number of bugs that where version specific
                                    Ready for download - those running sketchup 2016 do not need to upgrade.
                                    • Older versions of sketchup that used Ruby 1.8 and did not support round(decimals). fixed
                                    • Older versions of sketchup 7, 8 and 2013 do not support adding linear dimensions programatically. CabMaker now detects sketchup version and only attempts dimensions for version 14.0 and greater
                                    • The way I was grabbing images for cabinet templates only worked on recent versions of sketchup. Fixed
                                      Garry K
                                      You can now create your own extruded profile and create plain doors or embossed doors with extruded handles.
                                      Here is the profile that I've included.
                                      You can also create a top double drawer with a bank of drawers.
                                      • FrederikF Offline
                                        Frederik
                                        Awesome...! šŸ‘
                                        Cheers
                                        Kim Frederik
                                        • deaneauD Offline
                                          deaneau
                                          Hi i have seen that some models use IKEA.
                                          here is the IKEA Family-Color-Chart.
                                          the base of the Colors is the PDF-File in the Archive.
                                          This PDF was saved with " DIGITALFarbatlas"
                                          DIGITAL COLOUR ATLAS 5.0
                                          (dtpstudio.de)
                                          the download for the Version5 is only avaiable in German.
                                          IKEA Family.rar
                                            Garry K
                                            A user was asking how to have cabinets with plant on cabinet backs.
                                            Simple. Set the "Back Offset" to 0 mm and set the "Back Dado / Rabbet" to the same value as the thickness of the case material.
                                            In this case he uses a back thickness of 12 mm and a case thickness of 19 mm. His cabinet depth was set to 600 mm.
                                            Also please note that the parts listing takes care of itself.
                                            • 31
                                            • 32
                                            • 6 / 32
