    [Plugin] GKWare Cabinet Maker
    625 Posts 67 Posters 438.4k Views 68 Watching
      Garry K
      You were asking about an Ikea cabinet a few postings back.
      On Cabinets Tab:
      Height = 40"
      Depth = 16"
      Cabinet Type = Upper
      Cabinet Style = Base
      Drawers = 0
      Doors = 1
      Hinge Top
      On Tall Cabinets Tab:
      Top Section:
      Height = 20"
      Doors = 1
      Hinge Top
      Shelf = 1
      Mid Section:
      Height = 0"
        Garry K
        I am doing a fairly thorough testing of the Tall Cabinets. So many permutations and combinations that it is taking longer than I originally anticipated.
        There are 7 section combinations Times 6 constructions Times 3 for uppers, base integrated and base non integrated.
        That's 142 combinations and doesn't even begin to deal with different types of interiors.
        Here is a model containing 24 different tall cabinets. The 3 rows on the right are uppers, integrated base, and non integrated base. The six columns on the right represent 6 constructions.
        The six cabainets on the left (2 rows of 3) represent 1 construction for base cabinets with integrated kick
        These tests have uncovered a few Face Frame bugs that you can visually see. The cabinets with 1 and with 2 sections show correct top gap but only the cabinets that have the bottom section have correct bottom gap. Additionally one cabinet has rendered incorrectly.
        So ... testing continues.
          Garry K
          Version 1.0.39 is now ready to download.
          Available from my web site or from Sketchucation.
            Garry K
            If you want to have a shared location for templates and library files there is a way. I created a shared location on a different drive and then set up a batch file to point to that location.
            One reason to do this is if you have several licensed computers and you want to have 1 set of templates. Another reason is you want to make sure your templates don't get over written during an update.
            From the command prompt
            subst x: e:\library\gkware_cabmaker
            Then copy the following files into the shared area
            Next from the main menu choose
            Extensions\GKWare_CabMaker\Cab Maker - Edit Config
            And set the library location to x:
            Finally restart sketchup for the changes to take effect.
              Garry K
              I spent another 2 days testing and found a few more errors in the tall cabinets.
              Now pretty happy with the test suite. The skp test file is 7 megs and contains 90 tall cabinets of various constructions and configurations.
              Version 1.0.40
              • some configurations for frame less overlay construction for tall cabinets had the doors in the bottom section incorrect heights. fixed
              • the auto drawer size feature was not properly updating the drawer height. fixed
              • when using auto drawer size the drawer box height was inconsistent. fixed
              • For Overlay doors only the top Gap can be now be eliminated by setting the value to negative door gap.
              Here are the 90 tall cabinets
                Garry K
                Version 1.0.40 now ready for download
                  Garry K
                  1.0.41 ready for download
                  Version 1.0.41 - Mar 30, 2016
                  • Side dado's incorrect for Base cabinets with Integrated Kick with a 0 notch and side dadoes. Fixed
                  • Sink cabinets with side dado and rule to omit top had top dado. Top dado should be skipped. Fixed
                  • Parts report sometimes missing a part. Fixed
                  • Added new parts report for Gold. *_full_part_list.csv
                  • Added configuration setting for 'Silent Permissions'
                  • Update manual and added lines to translation files
                    Garry K
                    I am working on a new way to choose a cabinet from the library for those of you who want to work with libraries.
                    The idea is to add a find button, then pop up a new window that contains pictures of your cabinets. There would be a bit of work on your part.
                    What does everyone think?
                      abdalmalki
                      Garry,
                      I think it will consume a lot of your time without big advantage to the software.
                      That's my two cents.
                        Garry K
                        Version 1.0.42
                        • Added Confirm Save Configuration and a confirm popup to Web Dialog.
                        • Added context sensitive help for cabinet templates. If 320 X 240 png image exists in library folder
                        • Added version number to web dialog title
                        • Side by Side drawers now work for frameless construction and stretchers set to at least 1
                        • You now have option for edging upper cabinet ends of the sides if not skinning the top and or bottom
                        • Corner cabinet adjustable shelving had edging along the back where the shelf butts up against the corner brace. Fixed
                        • Sides, Top and Bottom front edges had edging with face frame construction. Fixed
                        • You can override shelf spacing for up to 3 shelves
                        • You can now set pullout spacing for up to 3 pullouts or use the default rule
                        • Cabinets with 1 door set to pullout now works with more than 1 pullout
                          Garry K
                          You can set the openings (space between shelves) and (space between pullouts) here
                          You can have different shelf width adjustments for Uppers and Base cabinets and have 2 widths for shelves for base cabinets. Also you can edge the ends of sides - bottom, top, none or both.
                          Set the new values to -1 to disable
                          Here is the change for multiple pullouts with a door.
                          Here are split sink shelves - you set the length - set to -1 to disable.
                            Garry K
                            Version 1.0.42 is now ready for download
                              Garry K
                              Added pigeon hole capability using vertical dividers and horizontal dividers. Works with frameless or face frame construction and for uppers or base cabinets.
                              This can work as a wine rack.
                              • utilerU Offline
                                utiler
                                Looks like my wine rack, Garry...
                                Always empty. 😕
                                Just Curious...
                                  Garry K
                                  Andrew - mine too. Someone suggested that I have to buy it faster than I drink it!
                                  In actuality one of my hobbies is making wine. We live in wine country in British Columbia Canada. I do have a cool dark cellar and a metal wine rack that stores bottles 30 per shelf. Each shelf holds 8 bottles on the first row, 7 on the second row etc.
                                  Wine ages best in a cool dark place. The advantage of having the bottles touch each other in this way is that it is suppose to reduce the effect of small temperature fluctuations.
                                    Garry K
                                    Version 1.0.43 will be ready today for download
                                    • Added horizontal grid along with vertical dividers. Can use as a wine rack.
                                    • Modified the web dialog materials tab. Colors now show on a empty label just to the left of the color pulldown.
                                    • Modified web dialog. When Mac users use arrow keys in a closed drop down the graphics now update like it does for Windows users.
                                      Garry K
                                      Version 1.0.43 ready for download
                                      Next I am looking at adding a right and left angled cabinet. This style of cabinet is for finishing a run of cabinets.
                                        Garry K
                                        Version 1.0.44 fixes a number of bugs that where version specific
                                        Ready for download - those running sketchup 2016 do not need to upgrade.
                                        • Older versions of sketchup that used Ruby 1.8 and did not support round(decimals). fixed
                                        • Older versions of sketchup 7, 8 and 2013 do not support adding linear dimensions programatically. CabMaker now detects sketchup version and only attempts dimensions for version 14.0 and greater
                                        • The way I was grabbing images for cabinet templates only worked on recent versions of sketchup. Fixed
                                          Garry K
                                          You can now create your own extruded profile and create plain doors or embossed doors with extruded handles.
                                          Here is the profile that I've included.
                                          You can also create a top double drawer with a bank of drawers.
                                          • FrederikF Offline
                                            Frederik
                                            Awesome...! 👍
                                            Cheers
                                            Kim Frederik
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 31 / 32
