    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • pbacotP
      Nice trusses with the arc shapes.
      • medeekM
        medeek
        Version 1.4.6 - 03.26.2016
        • Added Cambered truss type, configurations: (6/X).
        • Metric input enabled for cambered truss type.
        • Added gable end trusses for cambered truss type.
        http://design.medeek.com/resources/images/truss_su101_800.jpg
        Six variants of the (6/X) configuration dependent on the ratio of the camber width to span. Notice that in all cases the top chord has six panels, the bottom chord varies from 4, 5 and 6 panels.
        View model here:
        3D Warehouse
        (3dwarehouse.sketchup.com)
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM
          medeek
          Second look at cathedral trusses (6/X) family:
          http://design.medeek.com/resources/truss/GEOMETRY/CATHEDRAL2_800.jpg
          The logic required to triangulate these type of trusses becomes tedious.
          design.medeek.com
          • medeekM
            medeek
            I've been meaning to add in cathedral trusses for quite some time and I finally had the chance last night. Configuration (3) shown below for a catheral 6/X truss:
            http://design.medeek.com/resources/images/truss_su102_800.jpg
            Now I only need to code in the other six configurations and its ready to release as a new update.
            View model here:
            3D Warehouse
            design.medeek.com
            • medeekM
              medeek
              A breakdown of the configurations for the Cathedral 4/X family:
              http://design.medeek.com/resources/truss/GEOMETRY/CATHEDRAL3_800.jpg
              design.medeek.com
              • medeekM
                medeek
                Version 1.4.7 - 03.28.2016
                • Added Cathedral truss type, configurations: (4/X, 6/X).
                • Metric input enabled for cathedral truss type.
                • Added gable end trusses for cathedral truss type.
                http://design.medeek.com/resources/images/truss_su103_800.jpg
                Note, that not all configurations have webs enabled however the top chords, bottom chords, gable end trusses and all advanced options are enabled.
                design.medeek.com
                • jujuJ
                  juju
                  Thanks for the continued development Nathaniel.
                  In case anyone missed it, the plugin price went up from $20 to $30.
                  Sorry for you if you've been holding out to get it... πŸ˜‰
                  • medeekM
                    medeek
                    Just as a word of warning this plugin is far from a polished or finished product. There are still a lot of loose ends that need tying up. Case in point I have not yet enabled gable end trusses for the attic truss type. The reason is the complication of dropping the top chord for structural outlookers where the attic truss has a spliced top chord. Below is an example of a attic truss with a dropped top chord that I have encountered in the past but I don't know if this is the best method of handling this situation.
                    http://design.medeek.com/images/slideshow/ROOF_STAIRWELL_ASSEMBLY_1024.jpg
                    I would like to enable structural outlookers for attic trusses in the next few days just to wrap this up. Any thoughts or suggestions or examples of similar configurations are very much appreciated.
                    Postscript: It may not be totally clear but the gable end truss is the one with all of the vertical members (nearest the viewer) in this isometric view. Note that the outlookers are oriented vertically in this particular case, partly due to an approx. 4' backspan over a stairwell. If the same top chord depth is maintained over the diagonal portion of the attic then the dropped top chord will be lower than the other common trusses in this segment of the attic. This will complicate the framing of the end wall slightly but should not prove to be an insurmountable problem.
                    design.medeek.com
                    • medeekM
                      medeek
                      To further clarify the framing details with regards to attic trusses and structural outlookers I've created a sample model with a proposed dropped top chord gable end attic truss:
                      http://design.medeek.com/resources/images/truss_su104_800.jpg
                      Please download and review the model here:
                      3D Warehouse
                      I've also included the infill wall framing to help put everything into reference (light green).
                      Is this the appropriate way to frame an attic truss (gable end) with structural outlookers?
                      design.medeek.com
                      • medeekM
                        medeek
                        The reason I provide the full attic opening at the gable end truss is so that the framed in wall can be the nominal ext. wall thickness of 5.5 inches and allow for R-21 insulation. I've had some truss plants provide the typical vert. webs for nailing off the sheathing over this space but then one has to fir it all out anyways to get the appropriate wall thickness for the insulation.
                        If the wall below the gable end truss is sufficient for bearing then the gable end truss really does not need to have any structural capability so all of the diagonal webs can go away. One could also get away with a 2x4 dropped top chord with the stacked top chord at the eaves as shown. It would make sense to have the same depth at the bottom chord though so that the floor sheathing has a convenient nailing surface right to the edge of the building.
                        Alternatively one could do away with the gable end truss entirely and just balloon frame the wall from the ground floor up or from the attic floor up.
                        The question is which method should be employed within the plugin. I would prefer to use the most commonly employed solution.
                        design.medeek.com
                        • medeekM
                          medeek
                          The gable end truss as shown is structural, just to clarify. I will probably go with what I have shown as modeled unless there are any objections.
                          design.medeek.com
                          • medeekM
                            medeek
                            Six possible end details for a flat truss (Pratt 4 panels), there are probably others but these seem to be the most common:
                            http://design.medeek.com/resources/images/truss_su105_800.jpg
                            1.) Mansard w/ Parapet
                            2.) Parapet
                            3.) Mansard
                            4.) Overhang
                            5.) Cantilever
                            6.) None
                            Both Mansard configurations can also have an optional overhang as shown. The Parapet configuration should allow for customizing the thickness of the parapet wall.
                            View model here:
                            3D Warehouse
                            This truss type with its many end configurations would work well with an HTML UI, that is the direction I will be going with future user inputs and interfaces since the ability to customize is unlimited.
                            With the flat trusses I will initially offer both Howe and Pratt with the ability to utilize a low slope or zero slope.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 1.4.8 - 04.01.2016
                              • Added Mod Fan common truss type.
                              • Structural outlookers (vert. & horz.) enabled under advanced roof options for Common (Mod Fan) truss type.
                              http://design.medeek.com/resources/images/truss_su106_800.jpg
                              View model here:
                              3D Warehouse
                              With the addition of the Mod Fan (Triple Fan) the line up of common trusses is complete. I still need to add in raised heels and structural outlookers for some of the configurations.
                              Theoretically I could add in additional configurations of the Fink and Howe truss types for extremely large roofs but the largest I've ever seen is a raised heel Quad Fink (10/9). Large spans beyond 70'-80' are probably not practical as far as a single span common truss roof. At that point you pretty much go with large flat roofs with interior columns and girders and all steel construction (think Walmart or Cosco).
                              design.medeek.com
                              • medeekM
                                medeek
                                Tray truss algorithm:
                                http://design.medeek.com/resources/truss/GEOMETRY/TRAY1_800.jpg
                                A more complex algorithm would be required for a non-centered tray.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Tray Trusses working now I just need to enable gable ends and advanced options:
                                  http://design.medeek.com/resources/images/truss_su107_800.jpg
                                  Note the three large trusses are all 36' span with different tray widths and different web triangulations.
                                  View model here:
                                  3D Warehouse
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    More configurations:
                                    http://design.medeek.com/resources/images/truss_su108_800.jpg
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 1.4.9 - 04.04.2016
                                      • Added Tray truss type, configurations: (AUTO).
                                      • Metric input enabled for tray truss type.
                                      • Added gable end trusses for tray truss type.
                                      The next truss type I would like to add is the coffer truss but I don't have a lot of good examples or shop drawings of this truss type. Any examples of a coffer truss would be most welcome.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 1.5.0 - 04.11.2016
                                        • Added Mono Scissor truss type, configurations: (2/2, 3/3).
                                        • Metric input enabled for mono scissor truss type.
                                        • Added gable end trusses for mono scissor truss type.
                                        • Structural outlookers (vert. & horz.) enabled under advanced roof options for Mono Scissor (2/2, 3/3) truss types.
                                        http://design.medeek.com/resources/images/truss_su110_800.jpg
                                        When the raised heel option is selected the pitch of the bottom chord may equal the top chord creating a half vaulted parallel chord truss.
                                        View model here:
                                        3D Warehouse
                                        Raised heels are also enabled for this truss type, the combination of structural outlookers (vert & horz.) with the raised heel (wedge, slider, vert) makes for some interesting combinations and for some challenging logic/programming in order to get it all right.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Updating the hip roof module so that an appropriate wireframe is displayed while using the roof positioning tool:
                                          http://design.medeek.com/resources/images/truss_su111_800.jpg
                                          I will roll a revision once I've finished updating all of the rafter roof types with updated wireframes (preview graphics).
                                          design.medeek.com
                                          • jujuJ
                                            juju
                                            thanks!
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 76
                                            • 77
                                            • 18 / 77
