    Sketchup 2014 - Vray going crazy
    renderpluginsextensions
    2 Posts 2 Posters 1.2k Views 2 Watching
      axiaq95
      I am using sketchup 2014 with vray 2.0 and I have problems all the time. I am rendering a 14 mb file and crazy things happen when rendering . The following are some things that constantly happen:
      • vray renders the hdri sky only and the rest is rendered in all white
      • vray materials dissappear and become like glass.
      • vray renders all black
      • materials in the material editor lose the bump map and when I insert the bump map again and render .. the image renders the hdri sky only ( as mentioned in the first point)
      These things keep happening each second and I end up doing something and having to close it all without saving since it would not render correctly. Anyone can offer me some help please ?
      • niuanseN Offline
        niuanse
        Something is messed in V-Ray Options or Material Editor settings. Save your settings first, then go back to the V-Ray default settings and try to render with Override Materials checked and unchecked then. If there is a problem in both you will have to introduce your settings one by one to see which option causes the problem. There is no way around it, I guess.
