    How could I model this?
    4 Posts 2 Posters 508 Views 2 Watching
    • E Offline
      enesoz
      I've been scratching my head trying to figure out how I could model this effect on a sphere for a project with no success. Has anyone got any ideas on how I could go about it?
      the sphere
        The first step would be to find a wood grain material like that. And then apply it to the sphere.
        You might find that setting the material to be projected will work. I got the following from the ash texture on the plane.
        Or there are a number of texture related extensions that might be useful.
        How precisely do you need to show the annual rings of the wood?
        • E Offline
          enesoz
          Quite precisely because its to be 3d printed so the more detail the better
            Maybe you need to make a board the same way a tree would and then carve out a sphere. πŸ˜„
            Will a texture suffice or are you going to actually have to create the surface irregularities? If it's the latter, SketchUp is probably not the right tool for the job.
