    Twilight Render - Challenge
    extensions
    76 Posts 11 Posters 19.6k Views 11 Watching
    • tuna1957T
      tuna1957
      Dave, Don't hate me. Was a little distracted when I posted earlier. Your glass is still way to thick. Went back into model and looked again. The thickness needs to be reduced by easily 2/3 s it's current thickness. The reflections in glass are a result of good models good light set up and good materials. If you provide the "right stuff" Twilight will give you all the reflections you'll ever want. I've got a scene set up now that I've been pulling test shots off of. Have it about ready to let it run overnight. I'll post some images when I get it done. Regards, Chuck.
      • ntxdaveN
        ntxdave
        @tuna1957 - I certainly am not mad. I appreciate all of the tips and assistance you have given me. πŸ‘
        Something a little different.........
        Glass of wine on glass table
        Yes, glass is still a little big compared to the furniture but am getting the idea β˜€
        Press F1...thank me later
        • tuna1957T
          tuna1957
          Dave, Didn't think you were mad. Figure at some point you think " oh good gosh now what" when you see my post πŸ’š .Several of us have hammered at you about the thickness of the glass in your glass. I thought i show you a side by side comparison . Posting at pic of your glass ( left side of pic ) next to one I cleaned up a little. Want you to see just how much a difference the small stuff makes.
          I made the following changes to your glass - reduced thickness of glass by 2/3's. Used a 48 segment circle for follow me path. Added a small 3 sided radius to top edge of glass. Added radius to the square corners in the stem. Gave the bottom of of the foot a smoother curve. Probably took about 15 minutes.
          Render set up - Put both glasses on a "table" inside a room. The room is a half circle. Already had one set up for some other tests. Used a combination of point lights and one spotlight. Point lights given RGB value of 100 watt light bulb. Spotlight was set to front left of table to aimed to glasses. Gave it RGB of a halogen bulb.
          Spent maybe 15 minute doing quick tests to adjust power levels of lights. Rendered on 10 interior plus. Let it run 55 passes. I think the difference is pretty obvious. Check out how distorted the reflections in the thick glass are. Wouldn't matter how long it ran the result wouldn't be so good.
          The renders far from perfect even on the thin glass. I do think it shows that time spent on the small details will give good rewards.
          • ntxdaveN
            ntxdave
            Will keep working on it. My glass is only .1" thick (at least that is what I thought).
            At lest I liked the effect of my glass on the table. Sad part of all of this is that it is something I will probably never use. Just trying to learn how to use the tools.
            • tuna1957T
              tuna1957
              Dave , don't get discouraged. You are making progress. Heck I never need to do this sort of stuff for my job but learning new stuff is a good thing. You never know when it might come in handy. Just keep swinging at the pitches. chuck.
              • pbacotP
                In the world of western art paintings, the glass object was a form of showing off your skills. Nice job Tuna! I have the problem of the glass disappearing even when there seems to be nice reflections. Your stem and base show up nicely in these renders.
                • tuna1957T
                  tuna1957
                  Thanks pbacot , it's kind of fun trying new stuff even if your not getting the result you want. Totally understand your comment about artists painting glass objects. Have an art background. I have to tip my hat to the guys that write the render software. When I think about the way light bounces and bends going through bottles and such. I'm guessing calculating the light paths through curved glass is one of the toughest on the software. Makes my head hurt thinking about it.
                  • BoxB
                    Here's a very quick one, I thinned down your profile and SUbD'd it and very quick blobby bottle, also SUbd. Honeydew uneditted for the bottle, whitesmoke uneditted for the glass, both just the default settings for Glass common. Sun turned down to 1, Hemispherical sky, hdr 001 from the studio pack set at 4 for the rest of the light. No background just your glasses and a box to sit mine on.
                    With a little bit of tweaking
                      Very convincing!
                      That is magic beverage! 😎
                      • ntxdaveN
                        ntxdave
                        OK - Much closer to what I want to be able to accomplish.
                        Wing Glasses on table in room
                        For me, I think this is a big step forward. Still lots to learn but I think I am headed in the right direction. Very little tweaking to the settings for the various materials.
                        Now I need to add details to the walls, add a ceiling and then begin learning how to use the lighting tools. At some point I would also like to have a window with stuff showing in the background.
                        As always, suggestions on how to move forward and learn to use the tools greatly appreciated.
                        BTW: @Box, I really liked your posts too πŸ‘ πŸ‘
                        • tuna1957T
                          tuna1957
                          πŸ‘ , Each one of your shots gets better than the last. Keep it up πŸ‘
                          • ntxdaveN
                            ntxdave
                            @tuna1957 said:
                            :thumb: , Each one of your shots gets better than the last. Keep it up πŸ‘
                            Thanks - one thing I was just noticing thoug - is there a conflict in the reflection of the glasses on the table versus the shadow of the chairs?
                            • tuna1957T
                              tuna1957
                              Dave, What was your light set up ? You can get conflicting, multiple shadow effect if there is multiple light sources. Depends on light placement and power. Curious , what setting did you render at ? chuck.
                              • ntxdaveN
                                ntxdave
                                I did not have shadows turned on in SketchUp. Here is the environment setting in Twilight
                                Wine Serving Twilight Environment Settings
                                • tuna1957T
                                  tuna1957
                                  Dave, Not sure how you set up your room, guess I should have asked. Being as you use a Hemispherical Sky setting I guessed you used some kind of open box for your "room". Posting a pic of a quick shot to try an emulate what you were trying. Doing an interior this way is totally different than what I'm used to. 98% of the renders I'm doing for job are interior shots. The spaces are fully modeled and lit with light emitting panels. Works well for the crazy stuff I'm doing.
                                  That said I through together 2 walls and a floor , slammed chairs , table and booze in the corner. Used Hemispherical Sky setting. What I did do was turn on shadows in SU and adjust the settings until shadows had very little rake. Did test renders on low and played with sun TW sun settings until I got something reasonable.
                                  The posted pic had Brightness - 0.6 , Haze - 30 , Sun Strength - 2.0 . Also gave the sun the RGB value of a tungsten light bulb.
                                  For me I'd rather set up an enclosed room and use point lights , spot lights, emitters or a combo of the same for doing interiors. F.Y.I. setting up and running the test took maybe 15 - 20 minutes tops.
                                  • ntxdaveN
                                    ntxdave
                                    Agree with all of your points.......I just threw the render together because I finally got the glass thickness correct. Yes, it was a "room" with 3 walls and no ceiling.
                                    I do want do one with a full room, windows and some wall decorations. Then use interior lighting. I also want an HDRI background that you can see through the windows. Slowly I am learning this. When I thought I was creating the glass at .1" it was actually 1". Once I got past that stupidity, things started improving.
                                    BTW: I really like your wood floor. Wish I had a material like that one. And yes, the rest of the model was good too. Maybe a little dark but I liked it.
                                    • tuna1957T
                                      tuna1957
                                      Dave, You are going to get so sick of me πŸ’š ! The last pic I posted I new was pretty dark. It was on purpose. I was hoping you would pick up on how stark the shadows were. Shadows from sun settings are a lot stronger than shadows in most interior spaces. Posted two more quick tests, scene the same as the last.
                                      room test 09 - Fully enclosed room. Light emitter at ceiling, 2' smaller on all sides. Lowered 8" below actual ceiling. RGB of emitter 255/214/170. Rendered on 09 interior progressive. 10 passes, 14:20 minutes . Exposure set to 1200 in post pro before saving.
                                      room test 09 2 - Same room but added 6' sliding door in wall to left of scene. Set a light emitter outside of door. Left RGB at default 255/255/255. Power 200,000 . 4 point lights in room, two spaced out over chairs. Two at other end of room, behind camera view. Lights over chairs radius 4 , strength 0.6 . Lights behind camera radius 3 , strength 0.8 . All point lights RGB 255/214/170 . Rendered 09 interior progressive, 15 passes , 27:46 minutes. Saved at 1400 exposure.
                                      The first render could have run another 10 passes. My experience has been after 25 passes you really don't see improvement when your using low resolution textures.
                                      Second render would definitely benefit from some more passes . Image would sharpen up. Added the the door to pick up natural side light that would highlight stuff on table.
                                      You can have those wood textures ,floor and furniture. They are available as texture packs in the sketchUcation store. The fabric on the chair cushion is another texture pack same place . They are low res. NPR textures , but still look real good for the work I do.
                                      • ntxdaveN
                                        ntxdave
                                        Never get sick Chuck.........as I said before, I appreciate you taking the time with me. One of these days I might be able to help someone else. I am trying to learn from all of this and really appreciate you sharing your knowledge of Twilight with me.
                                        Hope you have a Happy Easter.
                                        • H
                                          hvanessen
                                          i did a quick test with a glass i made myself and a studio hdr. The only thing was the wine wich is not very good.
                                          test 1
                                          • H
                                            hvanessen
                                            also a test because i saw that de glass was not overal the same thickness and clear. Also made a better wine.
                                            test 2
                                            I think this is much better, improving
                                            • 4 / 4
