    3D Truss Models
    1.5k Posts 31 Posters 934.4k Views 30 Watching
    • medeekM Offline
      medeek
      A basic algorithm to convert a common gable truss into a transition truss should not be to much problem. However, to make it handle all cases would become difficult if you include raised energy heels, drop top chords and scissor trusses in the mix. Consider the two examples below:
      http://res.cloudinary.com/engineering-com/image/upload/v1458498005/tips/raisedheel_transition_ytifry.jpg
      http://res.cloudinary.com/engineering-com/image/upload/v1458502226/tips/scissor_transition_pbeuyj.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.4.3 - 03.20.2016
        • Added Scissor truss type, configuration: (6/6).
        • Added energy/raised heels for scissor trusses (2 variants: wedge and vertical w/ strut).
        • Addressed some minor usability issues with the scissor truss menu and options.
        http://design.medeek.com/resources/images/truss_su96_800.jpg
        View model here:
        3D Warehouse
        (3dwarehouse.sketchup.com)
        I forgot to add in an example of a 2/2 Scissor Truss but that configuration also has raised heels available.
        design.medeek.com
        • medeekM Offline
          medeek
          Polynesian 4/4 truss is working:
          http://design.medeek.com/resources/images/truss_su97_800.jpg
          However, I haven't released this latest update yet, I still need to enable gable end trusses and advanced options for this truss type before it is ready for prime time.
          The inputs are similar to all other truss types except you have two top chord pitches and a pitch break length measured from the left butt cut of the truss.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 1.4.4 - 03.21.2016
            • Added Polynesian truss type, configurations: (4/4).
            • Metric input enabled for polynesian truss type.
            • Added gable end trusses for polynesian truss type.
            http://design.medeek.com/resources/images/truss_su98_800.jpg
            I'm not sure where this type of truss is commonly used but whenever I see one I think of a bus stop or train station:
            http://design.medeek.com/resources/images/truss_su99_800.jpg
            View model here:
            3D Warehouse
            Advanced options are not yet enabled for this truss type yet, so sheathing, fascia, rake will have to come later.
            I haven't uploaded this latest version to the Sketchucation plugin store yet because I don't want to keep dominating the top spot so much. If you need the latest version it is always available on the web site. I will probably upload the current version of the plugin to the pluginstore about a week from today.
            design.medeek.com
            • jujuJ Offline
              juju
              wow, development just keeps on going, thanks!
              • medeekM Offline
                medeek
                After adding Bowstring and Bow Barrel trusses the only common other round truss type is the Barrel Vault. The problem with this type of truss is the webs get messy or at least hard to predicate because of the interplay between the vault and the pitched roof above it. In an effort to better understand this type of roof/ceiling configuration I've created the matrix below:
                http://design.medeek.com/resources/truss/BARREL_VAULT/BARRELVAULT_STUDY1.jpg
                High Res. PDF copy here:
                http://design.medeek.com/resources/truss/BARREL_VAULT/BARRELVAULT_STUDY1.pdf
                I am trying to predict the max. height of the vault given a specific roof pitch and and vault width to span ratio. Perhaps I am recreating the wheel and some architect or designer has devised a method to create the perfect barrel vault given a roof pitch and other criteria.
                I would be interested in what other opinions are on this matter.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Using a typical Barrel Vault 8/7+4 or 8/7+2 configuration I come up with the following triangulations. I'm sure there are other methods of configuring these webs but for the purposes of the plugin I think these solutions will suffice for now:
                  http://design.medeek.com/resources/truss/BARREL_VAULT/BARRELVAULT_STUDY1_REVA2.jpg
                  High Resolution PDF copy here:
                  http://design.medeek.com/resources/truss/BARREL_VAULT/BARRELVAULT_STUDY1_REVA2.pdf
                  Based on this matrix I've been able to come up with a simple algorithm for the triangulation of this truss type. I'll admit the barrel vault truss is one handsome devil.
                  design.medeek.com
                  • jujuJ Offline
                    juju
                    how's the manual coming along?
                    • medeekM Offline
                      medeek
                      The manual is lagging behind the development. However, I'm thinking HTML UI inputs would be desirable with the ability to have pop up help dialogs for each parameter (instant help). The manual is still needed but it will change the entire look and feel of the plugin and make it easier to use in my opinion and easy to understand for the layperson.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        A 9:12 barrel vault truss with a 16' wide barrel:
                        http://design.medeek.com/resources/truss/BARREL_VAULT/BARRELVAULT_STUDY1_REVA3.jpg
                        PDF:
                        http://design.medeek.com/resources/truss/BARREL_VAULT/BARRELVAULT_STUDY1_REVA3.pdf
                        The design of this type of truss is controlled by the following parameters:
                        1.) Out-to-out span
                        2.) Top chord pitch
                        3.) Barrel vault width
                        4.) Barrel vault radius
                        Assuming a typical web configuration as shown above the truss design is really only dependent on these four inputs. Minor details with regards to member depths, overhangs and ply thickness also factor in as well but don't really change much.
                        I can also see the possibility of running a raised heel variant but I don't know how common that would be.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Same truss as above but in SketchUp:
                          http://design.medeek.com/resources/images/truss_su100_800.jpg
                          View model here:
                          3D Warehouse
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.4.5 - 03.24.2016
                            • Structural outlookers (vert. & horz.) enabled under advanced roof options for Scissor (4/4) truss type.
                            I guess I somehow missed enabling structural outlookers for scissor trusses. Anyhow this issue was brought to my attention this evening so I've tried to rectify it as much as possible. After delving into the code I realized that the scissor truss module needs a major rewrite and cleanup so I was only able to get structural outlookers enabled for the 4/4 configuration. Later next week I will jump back into this module and work on the 2/2 and 6/6 configuration.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              I had someone ask me if it would be possible to create a small house or cabin based entirely on a raised heel attic truss profile, probably with some skylights for light. I've never seen this type of design before but I don't see why it might not work. Has anyone ever seen something like this done? Basically an attic truss with a raised heel (48') resting directly on a stem wall foundation with post and beams or something similar.
                              http://design.medeek.com/resources/images/TRUSS_HOUSE1_ISO1.jpg
                              http://design.medeek.com/resources/images/TRUSS_HOUSE1_ISO2.jpg
                              http://design.medeek.com/resources/images/TRUSS_HOUSE1_ISO3.jpg
                              The one issue I could see is if there were no windows for a bedroom (no egress) that was midway the length of the structure. The design shown is 36' wide, 42' long with a 21' wide attic room. 6"x24" stemwall foundation, with a 12"x6" footing.
                              Typically large attic trusses are quite expensive so it would seem that this would be an expensive way to build a house perhaps there is some other reason that makes this method of construction viable?
                              View model here:
                              3D Warehouse
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Another look at the cambered truss:
                                http://design.medeek.com/resources/truss/GEOMETRY/CAMBERED2_800.jpg
                                design.medeek.com
                                • pbacotP Offline
                                  Nice trusses with the arc shapes.
                                  • medeekM Offline
                                    medeek
                                    Version 1.4.6 - 03.26.2016
                                    • Added Cambered truss type, configurations: (6/X).
                                    • Metric input enabled for cambered truss type.
                                    • Added gable end trusses for cambered truss type.
                                    http://design.medeek.com/resources/images/truss_su101_800.jpg
                                    Six variants of the (6/X) configuration dependent on the ratio of the camber width to span. Notice that in all cases the top chord has six panels, the bottom chord varies from 4, 5 and 6 panels.
                                    View model here:
                                    3D Warehouse
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Second look at cathedral trusses (6/X) family:
                                      http://design.medeek.com/resources/truss/GEOMETRY/CATHEDRAL2_800.jpg
                                      The logic required to triangulate these type of trusses becomes tedious.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        I've been meaning to add in cathedral trusses for quite some time and I finally had the chance last night. Configuration (3) shown below for a catheral 6/X truss:
                                        http://design.medeek.com/resources/images/truss_su102_800.jpg
                                        Now I only need to code in the other six configurations and its ready to release as a new update.
                                        View model here:
                                        3D Warehouse
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          A breakdown of the configurations for the Cathedral 4/X family:
                                          http://design.medeek.com/resources/truss/GEOMETRY/CATHEDRAL3_800.jpg
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.4.7 - 03.28.2016
                                            • Added Cathedral truss type, configurations: (4/X, 6/X).
                                            • Metric input enabled for cathedral truss type.
                                            • Added gable end trusses for cathedral truss type.
                                            http://design.medeek.com/resources/images/truss_su103_800.jpg
                                            Note, that not all configurations have webs enabled however the top chords, bottom chords, gable end trusses and all advanced options are enabled.
                                            design.medeek.com
                                            • 75
                                            • 76
                                            • 8 / 76
