    Street Photo Match Work
    23 Posts 9 Posters 3.1k Views 9 Watching
      kenancakir
      Thank you..
      • HornOxxH Offline
        HornOxx
        ...I have never seen a simulation of a street itself so far!
        This is a perfect work and a great PhotoMatch example. Right up to
        your used lighting and it´s shadows, everything fits perfectly.
        (is this areal street project?)
        never trust a skinny cook
        • jo-keJ Offline
          jo-ke
          wow this matches perfectly
          http://www.zz7.de
          • RichardR Offline
            Richard
            Truly awesome work mate! I'm totally impressed.
            [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
              kenancakir
              Thanks.. This work contains ten street.. I finished five street..
                kenancakir
                Third..
                  kenancakir
                  Fourth..
                    kenancakir
                    Thank you all.. This a real street project of Malatya - Turkey.. Main project is done by city hall, i draw the roads with sketchup photo match and render with vray, clear the background original picture and match with ps.. This video is about stabilizing photo match camera view for render engines and match the resolution for photoshop touches..
                    • HornOxxH Offline
                      HornOxx
                      congratulations - all examples are excellent and it is fun to look at them!
                      A problem has, who drives too narrow around the curve in your City-Street Design 😉
                      A little I am pleased about this ever present white Opel Insignia with it´s GG license plate,
                      which means Groß Gerau, the "Opel" region near Frankfurt, where I worked for a couple of years...
                        kenancakir
                        Thank you, my second street is one way road and has parking area both side.. In fact, i don't like cars, i like motorcycles.. 💚
                        • oganocaliO Offline
                          oganocali
                          Nice work Kenan. If you want to increase photo-realism you might want to try fading out the colors smoothly (to a bluish tone you get at the horizon) as objects gets farther away from the camera. This would imitate atmospheric effects impacting the balcony view mostly.
                          congrats
                          Ogan
                            Nicely done, lots of consistency and I would have said they were perfect.
                              Ben Ritter
                              These look great.
                              In the video, what is the point of going from FOV 42.01 to 35 and back to 42.01? Doesn't that just get you back to the Photomatch view?
                              How did you photomatch the street, since there are very few perspective references?
                              Thanks.
                                kenancakir
                                The point of the changing and than giving old value of fov is breaking the photo match view and than get the same fov value of the photo match scene for render engine and workflow.. You know, it is hard to work on your model inside photo match scene when you add some heavy models.. Besides, when you render your photo match scene, vray render angle changes.. To fix theese, you have to have a scene that has the same angle and fov as the photo match scene..
                                I made a lot of test drawings, and thought about how i can draw photo match that has balcony view for three days, and i draw a ground plane, put a carlike shape on it, play with photo matchs general scale, pushing the far line of the ground plane up or down..
                                  kenancakir
                                  congrats
                                  Ogan
                                  Thank you, i know my lines/arcs need to be smooter, and all my works need more and detailed photoshop works..
                                  I will use your suggestions for my next works..
                                  • DanielD Offline
                                    Daniel
                                    Great work. Including the before shots perfectly illustrates how simples things can make a huge improvement to an environment.
                                    My avatar is an anachronism.
                                      Ben Ritter
                                      Thanks for your response, and again, nice work.
                                        kenancakir
                                        Fifth street..
                                          kenancakir
                                          Some more ps touches..
