    Twilight Render - Challenge
    extensions
    76 Posts 11 Posters 16.1k Views 11 Watching
    • ntxdaveN Offline
      ntxdave
      @solo said:
      Dave, scale is important when trying to get accurate materials, the above is way too big, try reducing it to accurate size before rendering.
      I scaled the glass down to the correct size and rerendered using most of tuna1957's settings (not all).
      Still does not match what it seems like everyone else is able to do. Either I am expecting too much or I just do not get it. I am failing miserable at this challenge.
      I am open to suggestions or if someone who has done this successfully would like to share your SU file (with Twilight settings) for me to study, I would really appreciate it. 😑
      Press F1...thank me later
      • tuna1957T Offline
        tuna1957
        Dave, Take a deep breath and step away from the keyboard πŸ’š On a serious note try not to get to frustrated.
        I'm no expert at this either. I remember having days I wanted to jab pencils in my head sitting at my keyboard trying
        figure this stuff out. I've been messing about and tweaking settings and such. Posting another pic of a "rocks glass". Was going to tweak on your model but I'm still working in SU2015. If you'd like I'll post my rocks glass model so you can get in and check out how the materials and sun is set up.
        • olisheaO Offline
          olishea
          is your index of refraction too high Dave? It looks like extremely thick glass (even though we know it is not)
          keep going!! You'll nail it soon.
          oli
          • ntxdaveN Offline
            ntxdave
            @tuna1957 - Thanks for your reply. Yes, I would like for you to share your model. I think I am missing something very basic but I do not know what it is.
            @olishea - Yes, the IOR setting for the glass was too high. I set it lower but I am still doing something very basic wrong.
            I have another question for anyone looking at this that uses Twilight. When I use the template to set the texture of the liquid in the glass, SketchUp reverses the faces of the liquid group. Is that supposed to happen?
            • tuna1957T Offline
              tuna1957
              Dave, I'll post the model next day or so. Haven't had the "faces" change when working in TW. I will say SU can get a little crazy with face orientation sometimes while I'm modeling. Never an issue when setting textures in TW ?
              • alvisA Offline
                alvis
                You can be studied in a model
                ready for TWrender.zip
                • ntxdaveN Offline
                  ntxdave
                  @Alvis - I really like this. My favorite is #4 (counting from the right). I downloaded your model and will try to understand it. I got an error because it is missing the background image. The background in your images does not match what I am seeing in SU but that is probably related to the error in not finding the background image.
                  Now I would like to understand the differences in the settings between the 4 images you posted. The only way I got the wine to show up with any red in the glass (in my image - not yours) was to go to an external render and then I lost the wine color in the shadow.
                  Just to let everyone know I have not completely given up, here is my latest attempt.
                  OK - One big thing I learned in this was that I was not paying attention to the shadow settings in SU because I never use them in the work I do. That helped a lot. Still a lot of experimenting to get this far. What bothers me most is not necessarily that the image is not the greatest in the world but rather that I do not seem to be picking up on some of the elementary things needed to do good rendering.
                  In another thread I did try some building renders with section cuts and hiding some walls but doing something like this wine glass is totally throwing me off. http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=64285
                  • tuna1957T Offline
                    tuna1957
                    Dave , Posting the "rocks glass" model. You'll be able to check out materials and sun settings I used . It's a simple set up but gives a nice render on easy low through easy medium+ . Have one scene set up. Hope it's helpful.
                    rocks glass dave c.skp
                    • ntxdaveN Offline
                      ntxdave
                      @tuna1957 - Thanks for sharing. I think I have learned a couple of things in this but I am still doing something wrong. A couple of things I noticed though is that you have a custom preset and you have a template that I do not have. I saw Glass::Water. I do not have that in my settings......
                      I took my glass and pasted it into your skp file and then tried to set my glass like yours but there is still something wrong. I cannot see the color of the wine properly though my glass (I emulated your settings for my glass).
                      I am also attaching the SU file that has both of our glasses in it. Maybe you can figure out what the heck I am messing up.
                      rocks glass dave c dave.skp
                      • pbacotP Offline
                        Dave the stem looks nice. Not sure what is happening in the base. (also not sure what vessel you are working on / talking about). DL'd the file. Later.
                        • tuna1957T Offline
                          tuna1957
                          Dave , Here's your fixed model back. Most of your problems were in the model itself. Biggest issue was your glass and your wine were each in separate groups and the wine didn't line up with the inside surface of the glass. When you move the wine shape back inside the glass, once it's lined up proper you explode the group and then intersect the faces. What you ended up with was 3 layers of glass were you should only have 2. Also had stray geometry between
                          the glass layers that needed erased. Unsoftened the outside rim of the glass. It was causing weird artifacts in the render. I think if 2 faces get real close together it makes the render engine a little crazy. If you want a rounded rim draw it in when your making your template, don't try and get it just by soft & smooth. Redrew the top of the base, you were missing a bunch of faces were the stem and base meet.Last but not least you had a lot of back faces were you should have had front faces. I changed the color of the wine in both just cause I felt like it. Didn't change anything in Twilight. You should be able to plug and play and get a nice result. Also will post render. 05 - medium+ , took 49 seconds.
                          Almost forgot , one more thing. You should increase your segment count when you draw your circles. Things will look a lot smoother. FYI the rocks glass was drawn with 64 segments.
                          fixed wineglass.skp
                          • tuna1957T Offline
                            tuna1957
                            ooops..... Forgot something. If your wondering why the saved renders look a little dark around the edges. I had been fooling about with the post pro settings in the rocks glass model and forgot to turn them off before posting the model.
                            If you want to see the raw render click on post pro ( lower right corner ) in Twilight window and deselect vignette and your renders will look more like the original post of the rocks glass image. sorry....... me bad..........
                            • ntxdaveN Offline
                              ntxdave
                              @tuna1957 - I greatly appreciate you taking the time to show me my mistakes. I am embarrassed at all of the mistakes you found. I knew I had not done the intersect but did not realize what the effect was. I am first going to concentrate on drawing the glass correctly then will get back to the rendering. I can see from the file that you sent me that my real problem was the drawing. Had it been correct from the beginning I probably would have done much better with the rendering. I was concentrating on the wrong thing.
                              Once I get the modeling correct, I want to play around and understand how to generate reflections (i.e. have a reflection of another object on the glass and etc.). I also would like to expand the model to include both a glass and a bottle.
                              Again, I really appreciate you taking the time to set me on the wright direction. There have been others who have posted some nice images in this thread that I have enjoyed as well but you taking the time to point out my silly mistakes have proved the most valuable to me. I am sure I will wind up with other questions once I get the basics down right.
                              • tuna1957T Offline
                                tuna1957
                                Dave, Glad I could be of some help. Don't be embarrassed at making mistakes, that's how you learn. If you could
                                see some of my early models you'd get a pretty good chuckle. Have been going back through my files recently and
                                cleaning up early stuff. When I go into monochrome some of them look like checkerboards ! We all started at the
                                same place so don't let it get you down. Going to give you a few more tips, hope it doesn't freak you out.
                                In your last image you posted, the reason the wine in your glass is black is the back face issue. If you have
                                reversed faces TW will render them black If you run a test render and you've got objects that look black go to
                                monochrome and check your face orientation.
                                The stepped red lines in the wine is where the wine group was misaligned and sticking through the side of the
                                glass. The heavy black effects around the rim of the glass where solved when I unsoftened the outer rim.
                                The comment about segment count in your circles is easily seen in the last render I posted. The segments are very
                                apparent in the foot of the glass. At least 48 segments would have looked smoother. Might have taken 64.
                                The foot of the glass will look better if it has an upward curve across it's bottom. Only a small part of the foot
                                actually rests on the table. The wine glass foot is pretty dead flat and is why it's so grey.
                                Make sure you model this kind of stuff BIG. The rocks glass was over 2' tall when i modeled it. Didn't scale down
                                until all modeling and texturing was finished.
                                Last thing i promise ! Hope you figured out the TW post pro settings I had made in the rocks glass model. Besides
                                "vignette" being turned on I think I had dialed the exposure down one click. Default is 1.0
                                Well that's it. Hope it's been some help. Glad to do it. Question's are always a good thing ! chuck.
                                • H Offline
                                  hvanessen
                                  my test with the glass from davefilled with bleuberry
                                  • ntxdaveN Offline
                                    ntxdave
                                    Part of my problem has been with correctly aligning the liquid in the glass before trying to intersect. That my be because I need to scale up and work from there. A few minutes ago (have not scaled up yet) when I applied the template to different materials, the faces reversed in the SU model. I am assuming that may have something to do with things being too small.
                                    Having company today so I might not get back to it until tomorrow. I AM going to figure this out ❗
                                    • pbacotP Offline
                                      Isn't the liquid made from a copy of the glass geometry (which never moves and so needs no alignment?) At what point do you "intersect"?
                                      • ntxdaveN Offline
                                        ntxdave
                                        See the post from Pilou on the previous page.
                                        Not exactly sure what you are saying.
                                        • pbacotP Offline
                                          I see. I guess I'd approach it differently. I don't know why the glass and liquid can't be done so that they are already aligned, but OK.
                                          • tuna1957T Offline
                                            tuna1957
                                            pbacot, I get what your driving at. There may be an easier way. I've tried different approaches. One thing I
                                            discovered. If the wine surface and inside of the glass aren't isolated by a group when you create the
                                            meniscus and run follow me you lose one row of geometry on the side of the glass. This is right
                                            below the line where the glass side and meniscus join. Then you have a repair job. At least that's what I
                                            had happen during my experiments.
                                            Dave , hvanessen , You guys need to check the rocks glass. Look at the difference in the appearance of the sides
                                            of the glass in my renders and yours. It looks like the vertical edges in your models aren't
                                            softened. Almost like their hidden but not softened/smooth. It's like something messed up
                                            passing the file. You need to check that out.
                                            good luck and keep experimenting and learning. chuck.
                                            • 2 / 4
