    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin] GKWare Cabinet Maker
    625 Posts 67 Posters 439.7k Views 68 Watching
      Garry K
      1. Toolbar is now restored to previous state for Mac. It is is also now shown on first install.
      2. Added a handle called 'No Handle' It is simply an invisible line - use where you do not want a handle to show up.
      3. Added Bottom Gap for Upper Doors. Changed Bottom Gap to Base Bottom Gap. Enter negative amount for door to extend beyond cabinet.
        Garry K
        1. Added a handle called 'No Handle' It is simply an invisible line - use where you do not want a handle to show up.
        2. Toolbar is now restored to previous state for Mac. Also Tool Bar now shows at first install.
        3. Angled Sink cabinets missing tilt out drawer front. Fixed
        4. For frame less construction and upper cabinets fillers extend below cabinet if doors extend below cabinet.
          Garry K
          1. You can now save templates using mixed case.
          2. The Defaults Tab now has a default Upper Handle and a default Base Handle.
          I've had a request to allow drawer banks with angled cabinets and with return cabinets. Anyone else interested. Any other feature requests?
            Garry K
            1. Added angled drawer bank.
              abdalmalki
              It would be nice if we could add DXF file export to the cabmaker so the CNC users could send it direct to their CAM software.
                Garry K
                I've alreday started adding dxf export to my cutmaster Gold.
                  abdalmalki
                  Great addition Garry
                  I can't wait to see the gold version of cutmaster.
                    Garry K
                    It'll be around a month before it comes out.
                      Garry K
                      1. Drawer auto height - Edit now shows actual height for last drawer in drawer bank.
                      2. 2D cabinet dimensioning on layer called "Dimensions"
                      Set Config if you want dimensioning. Also you can set a network path here.
                      New version available shortly.
                        abdalmalki
                        Garry,
                        I have tried to make a standard upper cabinet without drawers/doors with a 18mm thick back board, 0mm back offset and 0mm back dado:
                        But the problem now is the back board not placed in a correct position:
                        I have tried to solve it by making back offset in minus figure but it didn't work for me. Finally I changed the thickness of back board to minus figure which return the back board to the right place:
                        I do not know if this Ok especially with the reports also I could't use the back offset after this modification.
                          Garry K
                          This is a bug. I will fix this and include it in today's version 1.0.37
                            Garry K
                            The fix is now in version 1.0.37.
                            I've set:
                            Corner brace width = 0
                            back material thickness = 5/8"
                            Back offset = 0
                            Back dado = 0
                              abdalmalki
                              Thank you Garry for graet support. It works for me now.
                              But I have another issue. I have drawn the following cabinet:
                              The problem now is the width of the side panel in the parts list report is greater than the actual width by 10mm :
                                Garry K
                                Please check the 'Additional' section in the Rules 2 tab
                                Side Width Adj:
                                Top / Bottom Width Adj:
                                There are several adjustments that are required for cabinet makers who need to increase the size of various parts. That includes:
                                Sides, Tops, Bottoms, Drawer Box Fronts and Backs and Door parts (Stiles, Rails and Panels)
                                  abdalmalki
                                  You are right, I changed side width adj to 0mm. Now the parts list report give me 600mm instead of 610mm.
                                  I think if you change the title from Additional to Final Cut Adjustments it will become more clear.
                                    Garry K
                                    I see what you mean however these are actually 'Additional' since there are 5 items.
                                    only 2 of them are Part adjustments
                                    Then there is 1 part adjustment in the drawer box section and then each door template has 5 adjustments.
                                      Garry K
                                      Version 1.0.38 now ready for download.
                                      Fixed a network path issue.
                                        abdalmalki
                                        Hi Garry,
                                        The following wall cabinet is from IKEA website:
                                        I have tried to make a semillar cabinet with cabmaker but it allow for one door if I select hinge top in the door options:
                                        Is it possible to make a cabinet with two horizental door in cabmaker?
                                          Garry K
                                          I'm actually working on something that should work for you.
                                          The next version of cabmaker will give you more control over tall cabinets.
                                          And yes - you will be able to make a cabinet with up to 3 sections - each with single doors and each with hinge options.
                                            abdalmalki
                                            Garry,
                                            Today I tried to make a standard base cabinet with zero top gap:
                                            But when I zoomed in I found a small gap between door top and the top of the cabinet equal to 3mm:
                                            I notice when I change the door gap to zero the top gap also become equal to zero:
                                            Could you please help in this issue.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 31
                                            • 32
                                            • 12 / 32
