    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 646.8k Views 71 Watching
      RCD
      When I use the angled cabinet, it isn't rendering correctly? Only the sides render and those aren't correct. Help?
      • G
        Garry K
        What's happening is there is an error somewhere and the process is not completed.
        You can startup ruby console before you render the angled cabinet. It should show errors. Often this sort of thing happens when parameters have values that the plugin doesn't handle.
        Please email me the contents of the ruby console.
        http://cabmaker32.com/contact/
        • G
          Garry K
          Version 1.0.36 will be ready later today. French Translation is complete. Web Dialog is reorganized.
          Cabinets
          Cabinets 2
          Rules
          Rules 2
          Materials
          Doors
          Defaults
          • G
            Garry K
            The red borders identify rules. Notice that some rules and some cabinet parameters have been moved around. Hopefully this simplifies the work flow and reduces confusion.
              abdalmalki
              This reorganization reduce confusion a lot
              keep up the good work.
              • G
                Garry K
                Version 1.0.36 is now available for download from my website
                Login to my web site
                http://cabmaker32.com/login/
                Then go to download page (you need to be logged in to download.
                • medeekM
                  medeek
                  I don't know the first thing about cabinets but I will say your web dialogs and overall user interface with this plugin is fantastic stuff. I will be putting your plugin through its paces and perhaps I can learn a thing or two about how to create some exceptional user interfaces for my own plugin. You attention to detail is duly noted.
                  Nathaniel P. Wilkerson PE
                  Medeek Engineering Inc
                  design.medeek.com
                  • G
                    Garry K
                    Thank you Nathaniel for your kind words.
                    Here is the first tab in French.
                    • G
                      Garry K
                      Working on requested features and bug fixes.
                      1. Fillers now work with Face Frame Construction.
                      2. Fixed drawer handle position. Return cabinets had handles on drawer fronts and shouldn't have.
                      3. Embossed Shaker ignored edge profiles. Fixed.
                      4. Added library location so that your libraries can be on a server.
                      5. Added logic to check for other language pdfs. If language is fr then first look for the French help file named 'cabmaker_fr.pdf' and if not found then loads the English 'cabmaker.pdf'. The same for other languages.
                      • G
                        Garry K
                        1. Toolbar is now restored to previous state for Mac. It is is also now shown on first install.
                        2. Added a handle called 'No Handle' It is simply an invisible line - use where you do not want a handle to show up.
                        3. Added Bottom Gap for Upper Doors. Changed Bottom Gap to Base Bottom Gap. Enter negative amount for door to extend beyond cabinet.
                        • G
                          Garry K
                          1. Added a handle called 'No Handle' It is simply an invisible line - use where you do not want a handle to show up.
                          2. Toolbar is now restored to previous state for Mac. Also Tool Bar now shows at first install.
                          3. Angled Sink cabinets missing tilt out drawer front. Fixed
                          4. For frame less construction and upper cabinets fillers extend below cabinet if doors extend below cabinet.
                          • G
                            Garry K
                            1. You can now save templates using mixed case.
                            2. The Defaults Tab now has a default Upper Handle and a default Base Handle.
                            I've had a request to allow drawer banks with angled cabinets and with return cabinets. Anyone else interested. Any other feature requests?
                            • G
                              Garry K
                              1. Added angled drawer bank.
                                abdalmalki
                                It would be nice if we could add DXF file export to the cabmaker so the CNC users could send it direct to their CAM software.
                                • G
                                  Garry K
                                  I've alreday started adding dxf export to my cutmaster Gold.
                                    abdalmalki
                                    Great addition Garry
                                    I can't wait to see the gold version of cutmaster.
                                    • G
                                      Garry K
                                      It'll be around a month before it comes out.
                                      • G
                                        Garry K
                                        1. Drawer auto height - Edit now shows actual height for last drawer in drawer bank.
                                        2. 2D cabinet dimensioning on layer called "Dimensions"
                                        Set Config if you want dimensioning. Also you can set a network path here.
                                        New version available shortly.
                                          abdalmalki
                                          Garry,
                                          I have tried to make a standard upper cabinet without drawers/doors with a 18mm thick back board, 0mm back offset and 0mm back dado:
                                          But the problem now is the back board not placed in a correct position:
                                          I have tried to solve it by making back offset in minus figure but it didn't work for me. Finally I changed the thickness of back board to minus figure which return the back board to the right place:
                                          I do not know if this Ok especially with the reports also I could't use the back offset after this modification.
                                          • G
                                            Garry K
                                            This is a bug. I will fix this and include it in today's version 1.0.37
                                            With your input, this post could be even better šŸ’—
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 31
                                            • 32
                                            • 12 / 32
