    Requesting idea for creating shapes with webdialog
    10 Posts 4 Posters 1.6k Views 4 Watching
    • H
      hanl000
      I am trying to create various shapes(2D, 3D both) with webdialog, not inputbox. Im already familiar with the way creates shapes with inputbox and It was a bit easy to learn. Determining variables(with @) -> drawing shape(with add_face, add_line etc.) -> coordinate(Geom::Transformation) are all steps i have done for creating shapes with inputbox.
      On the other hand, Webdialog,,,, looked unfamilir. To say exactly, Im not good at HTML and Javascript yet. Now, Im looking for the way how I can draw various shapes in Sketchup with Ruby API and Webdialog. Could you please give me advice or help? Your reply will encourage me to study Ruby API hard.
      Again, What I want to know is to make a webdialog can create shapes with variables for length(if the shape is box, and it would be radius or diameter if the shape is sphere), coordinate. Im sharing an example I tried. Id like to apply this code to Webdialog.
      toolbar = UI;;Toolbar.new "Box"
       cmd = UI;;Command.new("Create_Box") { box }
       cmd.small_icon = cmd.large_icon = "box.png"
       toolbar = toolbar.add_item cmd
       toolbar.show
      def box
      model = Sketchup.active_model
      entities = model.entities
      @Length = 0.mm unless @Length
      @Width = 0.mm unless @Width
      @Height = 0.mm unless @Height
      @X = 0.mm unless @X
      @Y = 0.mm unless @Y
      @Z = 0.mm unless @Z
      results = inputbox(['Length', 'Width', 'Height', 'X', 'Y', 'Z'], [@Length, @Width, @Height, @X, @Y, @Z], 'Box')
      return nil unless results
      @Length, @Width, @Height, @X, @Y, @Z = results
      #Points
      p1 = [0, 0, 0]
      p2 = [@Length, 0, 0]
      p3 = [@Length, @Width, 0]
      p4 = [0, @Width, 0]
      group=entities.add_group
      entities=group.entities
      face = entities.add_face(p1, p2, p3, p4)
      face.pushpull @Height
      pos = Geom;;Transformation.new([@X, @Y, @Z])
      group.transform! (pos)
      • sdmitchS
        sdmitch
        My solution
        module HANL000
        	module Create_Shape
        		unless file_loaded?(__FILE__)
        			cmd = UI;;Command.new("Create_Box") { self.box }
        			toolbar.show unless toolbar.get_last_state==0
        			file_loaded(__FILE__)
        		def self.box
        			@mod = Sketchup.active_model
        			@ent = @mod.active_entities
        			@Length = 100.mm unless @Length
        			@Width = 100.mm unless @Width
        			@Height = 100.mm unless @Height
        			@X = 0.mm unless @X
        			@Y = 0.mm unless @Y
        			@Z = 0.mm unless @Z
        			@dlg=UI;;WebDialog.new("Create Box", false,"WDID",200,300,10,10,true)
        			html = <<-HTML
        			<!DOCTYPE html>
        			<html lang="en-US">
        				<head>
        					<meta charset="utf-8" />
        					<meta content="IE=edge" http-equiv="X-UA-Compatible" />
        				</head>
        				<body>
        					<form action='skp;submit_form@'>
        						<fieldset>
        							<legend style='font-size;125%;color;red'><b> Dimensions </b></legend>
        							<table style='font-size;100%'>
        								<tr><td align='right'>Length;</td>
        								<td><input name='Length' type='text' value='#{@Length}' size=5/></td></tr>
        								<tr><td align='right'>Width;</td>
        								<td><input name='Width' type='text' value='#{@Width}' size=5/></td></tr>
        								<tr><td align='right'>Height;</td>
        								<td><input name='Height' type='text' value='#{@Height}' size=5/></td><tr>
        							</table>
        						</fieldset>
        						<fieldset>
        							<legend style='font-size;125%;color;red'><b> Box Origin </b></legend>
        								<tr><td align='right' width=50>X;</td>
        								<td><input name='X' type='text' value='#{@X}' size=5/></td></tr>
        								<tr><td align='right' width=50>Y;</td>
        								<td><input name='Y' type='text' value='#{@Y}' size=5/></td></tr>
        								<tr><td align='right' width=50>Z;</td>
        								<td><input name='Z' type='text' value='#{@Z}' size=5/></td></tr>
        							</table>
        						</fieldset><br>
        						<center><input type='submit' name='submit' value='Submit' /></center>
        					</form>
        				</body>
        			</html>
        			HTML
        			@dlg.set_html(html)
        			@dlg.add_action_callback("submit_form") {|d,p|
        				p.gsub!("?",""); tokens=p.split("&"); puts p
        				tokens.each{|t|
        					var,val = t.split("="); puts t
        					case var
        						when 'Length' then @Length = val.to_l
        						when 'Width' then @Width = val.to_l
        						when 'Height' then @Height = val.to_l
        						when 'X' then @X = val.to_l
        						when 'Y' then @Y = val.to_l
        						when 'Z' then @Z = val.to_l
        				@mod.start_operation "Create Box"
        				p1 = [@X, @Y, @Z]
        				p2 = [@X+@Length, @Y, @Z]
        				p3 = [@X+@Length, @Y+@Width, @Z]
        				p4 = [@X, @Y+@Width, @Z]
        				g = @ent.add_group; ge = g.entities
        				face = ge.add_face(p1, p2, p3, p4)
        				face.pushpull -@Height
        				@mod.commit_operation
        			RUBY_PLATFORM =~ /(darwin)/ ? @dlg.show_modal() ; @dlg.show();
        http://sdmitch.blogspot.com/
        • H
          hanl000
          Thank you for giving me clear solution!
          And I got two more questions from the solution.
          1. what codes do I have to use to rotate the shape instead of to_l of val.to_l in the solution?
            to_l is the method of numeric class which can convert inches to length and it's not related with rotation of shape. Maybe, another way is used next to val.. I tried to use just '.degrees', but it didn't work
          2. If I make more webdialogs create different shapes, how can I connect the webdialogs with each other? I'd like to try to make a webdialog which something in the webdialog takes me to another page which shows me another inputbox. It is like usual links in usual webpages and id like to add it.
          To start learning HTML alone is so difficult πŸ˜• it will be really great if you reply to my questions again.
          Happy Easter!
          • sdmitchS
            sdmitch
            1. Use a rotation transformation to rotate the group g following its creation, ie
              g.transform! Geom::Transformation.rotation(p1,Z_AXIS,some_angle.degrees)
            2. It would be far easier to create separate webdialogs for each shape and activate them from a single Toolbar.
            • K
              kaas
              Interesting ruby code Sdmitch. I never knew how to embed the html code in Ruby. I expected all code would be in embedded into 1 string or something like that. Can you explain the syntax of the beginning and end capitalized HTML tags? Or maybe do you have a link to the relevant Ruby-doc.org page?
              html = <<-HTML
              HTML
                driven
                @kaas, have a look for HEREDOC, the main gotcha is omitting the dash
                  puts <<HEREDOC
                  after newline and two spaces in
                this this will be left justified...
                HEREDOC # this MUST be left justified without the dash...
                  puts <<-HEREDOC
                  adding dash allows nicer looking code, but text will not be left justified...
                  HEREDOC
                  @var = 'no curly brackets needed'
                  var = 'curly brackets needed'
                  puts <<-HEREDOC
                  #@var
                  #{var}
                  HEREDOC
                • K
                  kaas
                  Thanks John,
                  HEREDOC - exactly what I was looking for.
                  Max
                  • sdmitchS
                    sdmitch
                    html = <<-HTML
                    HTML
                    I learned about this technique from code or a plugin that was posted sometime ago. Before then I was creating the html code in a separate file or as a quoted string inside the plugin. This was a major pain trying to keep the single and double quotes straight. This way is so much easier.
                    • H
                      hanl000
                      1. It would be far easier to create separate webdialogs for each shape and activate them from a single Toolbar.
                      Thank you for kind answer, sdmitch
                      Question brings new questions.
                      Now, I'm combining separated codes into one ruby file as you said and am looking around existing tools used webdialog.
                      https://github.com/joshaxey/Led-Staircase/blob/master/ledstaircase.rb showed me one good example which Id like to indicate(and I saw 'floorgenerator' you created as well!).
                      According to your tip, a single toolbar would be created for indicating one webdialog contains several basic tools which can be jump into each other clicking link on the webdialog. It sounded like I have to use like
                      ` #Add item
                      A = Module::Class.new
                      #Make toolbar
                      toolbar = toolbar.add_item A.ACommand
                      Show toolbar
                      toolbar.show`
                      Then, this is different with the way which excisting tool used(difference of code structure).
                      I have a few basic tools created based on your help. Maybe, it is better to share my works with other users and would like to make a bridge connects these individual tools on one webdialog by using
                      <option value='A' #{@B=='A' ? 'selected' : ''} >Option A</option>
                      or
                      <input type=radio name=rset value="B"> Option B <br>
                      or
                      <li class="selected"><a href="C" title="Tool1"><span>Tool1</span></a></li> <li><a href="D" title="Tool2"><span>Tool2</span></a></li>
                      Everything will be solved if this problem is solved. Please have a look at the attached two files and help me with this problem
                      box_webdialog.rb
                      sphere_webdialog.rb
                      • sdmitchS
                        sdmitch
                        Please check messages.
