    Windowizer?
    15 Posts 10 Posters 7.9k Views 10 Watching
    • C
      CalypsoArt
      Over the years I sporadically used the Windowizer plugin by Didier Bur. I don't think it's been updated to the new .rbz install format. Is this correct? If not, is there a similar plugin for quick loose window generation?
      thanks
        You can get Windowizer 3 (free) and Windowizer 4 from Smustard.com. I just downloaded Windowizer 3 and installed it in SU2016. It worked as expected. It downloads as .zip. Just rename it to .rbz and use Install Extension to install it into SketchUp.
          Soon a cool Click-Windows like Click-Kitchen! ๐Ÿ˜‰
            db11
            Very cool. Any idea when it will be released / how much it will cost?
              There will be Pro and Lite versions : Prices are not yet public!
              Release will be soon!
              • soloS
                ๐Ÿ˜ฎ ๐Ÿ‘
                That looks brilliant.
                • jujuJ
                  juju
                  ๐Ÿ˜Ž excellent!
                  • PixeroP
                    Pixero
                    Wow. Another "must have".
                      Macker
                      This looks superb. Do you have a mailing list that I can sign up to so that I know when it's released?
                      Check out my blog @ http://macviz.blogspot.co.uk
                      • TNTDAVIDT
                        TNTDAVID
                        Pilou thank you!
                        There will be a Free trial version also with the "Sliding Window" in gift.
                        Output is expected in April 2016.
                        I would come post a topic dedicated to the official release of "Click-Window", the day he will be available.
                        Prices are still under investigation for a license to use For Life ๐Ÿ˜„
                        The main goal of "Click-Window" and allow the professional to Win precious time.
                        By providing the "Windows Hung" is "Window Crank" in addition to the traditional windows in Europe,
                        we wanted to thank the Americans and the Canadians for their unwavering support with Click-Kitchen.
                        At the same objetcif the "INCH" and "CM" will be available to meet the expectations of all the world.
                        Thank you all for your positive comment.
                        See you soon
                        David
                        [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Dรฉcouvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour crรฉer vos cuisines 3D !
                        • jujuJ
                          juju
                          at TNTDAVID:
                          Aaaah! Something to look forward to!
                          Thank goodness, I am one of the tribe that dislikes the subscription model.
                          Any chance you can code it to work with whatever the model environment was set up as? Most people that work in metric use MM and not CM.
                          slightly offtopic:
                          I purchased click-cuisine yesterday (I have not had an opportunity to play with it yet) and also see there is click-change (free, thanks) and then some library joinery packs with various finishes (for purchase). Do these library joinery packs help to expand click-cuisine as well or does quick-cuisine actually generate these joinery items?
                          • TNTDAVIDT
                            TNTDAVID
                            Sorry for my lack of precision!
                            When I mentioned the "CM" I wanted to refer to the metric units.
                            I can reassure you, Click-Window is set in "mm"
                            In any case thank you advice ๐Ÿ˜‰
                            Concerning Click-Kitchen :
                            Thank you for your interest in our products.
                            The collections 200 furniture in "SKP" file, were created with "Click-kitchen" !
                            Conclusion, these collections bring nothing new if you have our Plugins.
                            The goal is to offer files with all the furniture available in "Click-kitchen" for exporting to other 3D software.
                            Cordially
                            David Barros
                            • jujuJ
                              juju
                              Cordially
                              David Barros
                              thanks for the quick response! excellent news (to all questions) then!
                              • Y
                                yong_faith
                                Windowizer isn't working on SketchUp Pro 2018... error on loading... and it shows on Extension Manager but "Unsigned"... i need help... ๐Ÿ˜ž
                                  I don't believe Windowizer has been updated for a few years. You could try contacting the author at Smustard.com. As for being unsigned, that would only be an issue if you set extension loading permissions to the strictest setting.
