    Introducing Viz - parametric modeling for SketchUp
    extensions
    85 Posts 21 Posters 38.3k Views 21 Watching
    • alexschreyerA
      alexschreyer Extension Creator
      Superb! Can't wait to try this out.
      Author of "Architectural Design with SketchUp":
      http://sketchupfordesign.com/
      • JQLJ
        JQL
        @pixero said:
        I have a feeling a Beta forum would be a good idea as there probably will be lots of questions and suggestions. Better to have several topics than just one.
        That would be my main suggestion and I think Rich could set you up here.
        Following on the slider's subject, I like them but they return huge values.
        I have a 1m cube and translation slider slides easily up to 14000m so values ranging 1m 10m or 0.5m are impossible to tune with the slider.
        I also agree on categorization, and I think it would be worth it to have some icons in the future as people doing graphic modelling, could probably relate nicelly with that.
        I'm using Substance Designer on a regular basis and visuals of their nodes work nicelly there.
        They have color separation by set of nodes.
        In this case I can't tell yet what categories there are, but some are geometry creators, some are modifiers some are functions, so there should be something to start with.
        Also, on the node workflow itself, something I feel it's lacking is a faster way to replace inputs. If I drag a vector into an input that is already used it does nothing and I would expect it to replace it.
        Also changing a big amount of output lines from one node to another node would be great.
        Here's a gif for clarifying what I'm talking about:
        www.casca.pt
        Visit us on facebook!
        • F
          fluid
          Thanks for all the feedback! Rolling up the sleeves for next version...
          There is a lot of new nodes to be added, and node categorization too.
          @Pixero:
          • What do you mean for "Any way of creating custom nodes apart from functions?"
          • Look at the Fx node for math for a list of math functions
          • Image inputs will be added soon
          • There are cases when you need multiple geometry sinks, and cases when you need none, for now probably it's a good idea to let the user choose
          @JQL: we'll add sliders so you can set the range/numeric type, as well as a way of quickly replacing connections
            Will be a free product ?
            • PixeroP
              Pixero
              Case A: A user conects some nodes and decides he wants to reuse them.
              A sort of "grouping" of nodes for later use.
              Case B: A user has some custom made node (like a cellular noise for example or something completele different).
              It would be great if the community had the possiblility to expand with "plugin" nodes.
              • jujuJ
                juju
                so this , in essence, rhino/grasshopper for SU?
                expected retail price?
                • PixeroP
                  Pixero
                  Is copy possible yet?
                  Are you planning ways to get reports from the plugin?
                  I think it would be great if you could combine some nodes and have a drop down menu to chose from something like this.
                  http://i.imgur.com/hhfy9Ls.png
                  • F
                    fluid
                    It will be a paid extension, but we don't have a retail price yet.
                    @Pixero:
                    • It will be possible to group nodes into a single node for reuse, and to share nodes created in that way with other Viz users.
                    • Copy is not implemented yet, but it will be available soon
                    • There will be ways to get reports from the plugin, as well as save files with data
                    • If I understand correctly the Add example you provided, there is a similar functionality in Viz with the node "Fx"
                    • PixeroP
                      Pixero
                      What I meant was that you could have several math functions (for example) in the same node and a drop down menu to chose (for example multiply or add or divide).
                      A great way of having less nodes and a quick way if you want to test the different available math functions instead of having to create a new node and connect it every time you want to try a different function.
                      I'm sure other stuff could be grouped together into one node as well, like all vectors in one, all arrays in one and so on.
                      Less nodes to keep track of.
                      Faster workflow.
                      • F
                        fluid
                        Something like this?
                        • PixeroP
                          Pixero
                          Yes but for more type of nodes. ๐Ÿ‘
                            db11
                            This looks super-cool, but I can't try it out as it's Windows only ๐Ÿ˜ž
                            Any plans for an eventual Mac-compatible version?
                            • F
                              fluid
                              Thanks! We'll soon release a Mac version. At the beginning we want to keep it Windows-only to speed up iteration times
                              • DareDevilD
                                DareDevil
                                Very cool idea !!!
                                I tested it and it's so nice... I'm frustrated, it's only a work in progress ๐Ÿ˜‰
                                Some notices :
                                • can't make an array (other than random one) ; I thing is an essential node to test this kind of tool
                                • nodes have different behavior with array input : if I put an array on the Radius input of MakeCircle node, it make multiple circles ; if I put an array on the Translation input of Traslate node, it make single translation... I think if I put an array in one input, I must have an array output.
                                I will test further...
                                • cottyC
                                  cotty
                                  Not tested yet, but already love it from the video too...
                                  my SketchUp gallery
                                  • JQLJ
                                    JQL
                                    What's really cool about it is the way it interacts with sketchup geometry.
                                    How can we control face normals on the output? Making it static?
                                    www.casca.pt
                                      db11
                                      Awesome โ€” that's great news!
                                      • F
                                        fluid
                                        We just added a Viz specific forum to add feature request and report bugs
                                        • PixeroP
                                          Pixero
                                          Thanks! ๐Ÿ‘
                                          • N
                                            numerobis
                                            WOW! Very cool! Finally... parametric modeling in SU.
                                            Concerning the feature requests... i would say simply add everything of RailClone's features and functionality ๐Ÿ˜‰
                                            • 2 / 5
