Triangular Tessellation
Hi guys,
I am trying to model this shape.
Can you advise on an extension or method?
Any information is much appreciated.
Cheers,
E.
There are many ways to achieve this effect, I'd say try artisan and SketchyFFD together, then group and turn smoothness down to zero.
Quick test.
wow that was fast!
thanks. will check both out
much appreciated
can you give a few steps to how you got there?
also, I am guessing you push and pull on certain nodes once the general shape is there but that results in all different sized triangles.
Is there a more rigid approach to maintain uniform dimensions to skin?
