    [Plugin] Stair Maker
    110 Posts 37 Posters 126.2k Views 37 Watching
    • atelierpaarA Offline
      atelierpaar
      Hi there,
      after installing "StairMaker" the plugin shows up under "plugins"
      The Dialog box asks for "normal, spiral....." etc
      That was it, nothing else happens.
      Sorry - what has to be done next ?
      Thanks for your comments
      Uli
      • sdmitchS Offline
        sdmitch
        @atelierpaar said:
        Hi there,
        Uli
        This is what you should see
        If not, open the Ruby Console window(Windows>Ruby Console) and try the plugin again to see if there are any error messages.
        http://sdmitch.blogspot.com/
          atelierpaar
          thanks for your quick response
          Here is what i get from the Ruby Console
          Error: #<ArgumentError: Cannot convert "7.65748031496063" to Length>
          C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Stair Maker.rb:267:in to_l' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Stair Maker.rb:267:in get_defaults'
          C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Stair Maker.rb:77:in reset' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Stair Hello Maker.rb:68:in initialize'
          C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Stair Maker.rb:25:in new' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Stair Maker.rb:25:in block in <top (required)>'
          SketchUp:1:in `call'
          • sdmitchS Offline
            sdmitch
            Do you use ',' instead of '.' between number and fractional part?
              atelierpaar
              Well, I dont get to type in any value.
              the plugin quits right after the first Dialog box
              • sdmitchS Offline
                sdmitch
                That doesn't answer my question. If you could enter a number say 1234 mm as meters, would it be 1.234 or 1,234?
                p.s.
                Please check messages.
                • F Offline
                  filipebonito
                  hello,
                  i have the same problem, when i open the plugin, i see the dialogue to chose the stair type, but after that get no options...
                  i use "," in numbers, lile "12,50"
                  here is the ruby console:
                  "Error: #<ArgumentError: Cannot convert "4.921259842519685" to Length>
                  C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Stair Maker.rb:267:in to_l' C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Stair Maker.rb:267:in get_defaults'
                  C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Stair Maker.rb:77:in reset' C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Stair Maker.rb:68:in initialize'
                  C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Stair Maker.rb:25:in new' C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Stair Maker.rb:25:in block in <top (required)>'
                  SketchUp:1:in `call'"
                  what can i do?
                  thanks
                  filipe bonito
                  • sdmitchS Offline
                    sdmitch
                    I have sent by Personal Message a version that should work for you.
                      rabas
                      Could i have , please, the comma version?
                      • sdmitchS Offline
                        sdmitch
                        I have updated the plugin at the Plugin Store to work with comma or period. Delete the existing Stair Maker.txt file.
                          MattBram
                          I meet the same result as Filipe does in the console, and the same result in Sketchup, i.e. nothing appears after having completed the tables.
                          I tried using either "." and "," with the plugin download today, and I also tried working in inches as well as in mm without need of using decimals nor fraction.
                          What have I been doing wrong?
                          Thanks,
                          Matt
                          • sdmitchS Offline
                            sdmitch
                            Deleting the existing StairMaker.txt file and allow the plugin to recreate it.
                              johnwmcc
                              Thanks, SD Mitch, for this very useful plugin.
                              Just installed this on iMac El Capitan. The input box dialogue is truncating the field names.
                              This is a known bug in InputBox on Mac, and can be fixed by adding extra spaces in the Prompts line of the call to inputBox.
                              prompts=["Step Width: ","Tread Depth: ","Riser Height: ","Num of Steps: ","Step Depth:","Rail Height:", "Rail Offset:","Height of Stairs:"]
                              The text above displays only one extra space added but in reality there are several - HTML is collapsing multiple spaces into one.
                              Result
                              I've incorporated this change into my own copy. Could it be fixed for any future plugin updates?
                              • sdmitchS Offline
                                sdmitch
                                Since I don't have or have access to a Mac, there is no way for me to address this problem.
                                  Silentip
                                  Hello. I'm trying to launch the Stair Maker plugin in SketchUp 2017. I get this error
                                  Error: #<NameError: uninitialized class variable @@ss_height in SDM::Stair_Maker>
                                  C:/Users/Silent_ip/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/StairMaker/StairMaker.rb:287:in put_defaults' C:/Users/Silent_ip/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/StairMaker/StairMaker.rb:84:in reset'
                                  C:/Users/Silent_ip/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/StairMaker/StairMaker.rb:54:in initialize' C:/Users/Silent_ip/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/StairMaker/StairMaker.rb:9:in new'
                                  C:/Users/Silent_ip/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/StairMaker/StairMaker.rb:9:in block in <top (required)>' SketchUp:1:in call'
                                  Code
                                  • 6 / 6
