    3D Truss Models
    1.5k Posts 31 Posters 869.7k Views 30 Watching
    • medeekM Offline
      medeek
      @ JQL
      Thank-you for posting a number of well thought out and interesting questions. I will do my best to answer them:
      1. Other than plywood and OSB, I have not found it very beneficial to apply a texture to the wood of the trusses or rafters, part of this is probably due to the mapping problems I encounter with the alignment of the textures to the members. Pre UV mapping does sound interesting and useful, I have not given it much thought until now. I've mostly been concerned with just getting the basic geometry correct and that has been a challenge in and of itself. Lately I've been using a very basic color scheme when creating demonstration models with the plugin (see some previous) posts. One thing I would like to do for sure, is set up some global settings that allows one to optionally assign specific items to certain layers. I also need to do some more research into the pre UV mapping to see if it is something I can do, honestly I don't know enough about it to talk intelligently on the subject, I will do some further reading on pre UV mapping.
      2. My thinking on beveling and chamfering for realism is that usually these entities will be viewed at such a distance that even if the members were beveled for realism you would barely notice. I have tried rendering some of my models in Thea Renderer and they come out surprising well. I just don't think the extra complexity added to the model is warranted in this regard.
      3. I have give some thought to this. Typically the plates, joist hangers, hurricane ties etc... are a function of the loads and hence engineering. To correctly draw all of these would require a fully engineered design. You will notice that the Truss Designer (separate software integrated with the plugin) does actually compute the plate sizes for a fink truss. Given enough time and money (incentive/motivation) I could probably program the engineering portion of the plugin so that it sends the data back from the Truss Designer and then the plugin updates the truss assembly and draws in the the correct plates and even hurricane ties. The other issue with drawing all the plates is that the model will start to get rather heavy, but maybe this is a non-issue for certain applications.
      On the topic of joist and rafter hangers I've thought about using pre-configured components that can be brought into the model and automatically positioned (ie. Simpson Strong-Tie hangers). I haven't had the time to look into this just yet but I agree that it would be very cool and be a big plus for presentation. Again this is not something I have had a chance to really look into but my thinking is that one could select an appropriate hanger type from a drop down list and it would auto insert it into the model at all the correct locations and orientations.
      1. I work with this sort of thing every day, so unfortunately, I sometimes forget how overwhelming the interface probably looks to the casual user. To that end I have begun putting together a detailed user manual that tries to explain each term and how to use it. Overall I think the UI is fairly easy to use and straightforward. More can be done to make things more streamlined but I think I have at least got a fairly firm start. I strongly encourage you to at least try the plugin, unless you do you will not really understand it or the UI currently in place. Once your run its through its paces a bit then we should sit down and redo this discussion on the user interface. Also note there as some tutorial videos posted on YouTube that offer some basic instruction on how to use the plugin.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • JQLJ Offline
        JQL
        I know I know... I'm talking out of assumptions and I should try it out...
        I have had no time or need for trying it but I'm deeply interested in it in an "academic perspective".
        The interest derives from what I've seen from your work. I think you probably see it as I see my DC windows. I've grown them to a point where everything is covered, from technical aspects, to render details and textures, to 2D details for construction docs and to my office's useability...
        In my case they've become so much developed that they are actually a burden on new projects. They have so many aspects to pre-configure on them that I tend to use simple glued components and forget about them until my projects reach construction docs stage.
        It's a fact that Level of Detail should grow along with the project and be there only when you need it but it's also a fact that only if your plugin delivers something very hard to master or if it can do something everyone needs, will it interest everyone.
        I hope you nail it and I will try it as soon as I have free time to do so... I'd really like to discuss it with you as I find that to be a very interesting discussion. I simply derived to other things I found that I love doing and are much needed in my office and in my conceptual process...
        Thanks for your interest in my points of view, and best of luck, I'll keep following this until I have the time!
        www.casca.pt
        Visit us on facebook!
        • medeekM Offline
          medeek
          You make two very good points:
          1. The detail should only be there when you need it: This is why I have balked at adding in too much detail into the model such as plates, fasteners, clips, and hangers. I've also split up my menus to use a simple UI and then offer "advanced options", which turns on sheathing, sub-fascia, rake boards, outlookers and eventually bird blocking.
          The goal is to also make some global settings that can be configured so that even more control is given to the user regarding the level of detail and other configurable items. If the interface is too tedious to use the plugin is doomed.
          1. For a successful plugin it needs to do something everybody wants or do something that is difficult to do extremely well: In this case the plugin is all about saving the user time and effort by creating complex geometry in a matter of seconds.
          The plugin will only appeal to a very limited audience. Most people could care less about how rafters or trusses generate the overall geometry of their roof, even my wife thinks I'm quite crazy, she doesn't get the fascination I have with trusses.
          This plugin needs to make hard things simple, such as creating complex roof geometry that would otherwise take an experienced SU user many minutes or an hour or two to complete. Hopefully I can achieve this with what I am doing, and to some degree I think I already have. I don't think there is any SU user that can generate a rectangular hip roof fully framed out as fast as I can using the plugin, and the same goes for any of the trussed or rafter roofs.
          This is why I would really like to complete the dutch gable rafter roof. There is a lot going on there (again see previous post with images) but if the plugin can generate all of that instantly then there is definitely some value in that.
          design.medeek.com
          • medeekM Offline
            medeek
            @Juju
            Interesting. Right off the batt I'm going to say this is well outside the scope of what I'm trying to do, but I think we all know that.
            However, if someone was motivated enough I could see a progam that could generate all of the curves necessary to generate the hull shape/surface and framework given a specific set of inputs/parameters. It all boils down to mathematical model that is then translated into geometry. I wouldn't be surprised if there already isn't a plugin out there that is able to generate hull shapes.
            Not something I'm interested in or about to tackle at the moment. It would be challenging, much more so since you are dealing with splines and curved surfaces.
            design.medeek.com
            • JQLJ Offline
              JQL
              I'm not saying there's no value to the plugin at all. I'm just saying it has tremedous value for some, and it could have tremendous value for most if it was easy to do really hard stuff that people cannot.
              As you say, an experienced SU user wouldn't be able to do a truss as fast as you with your plugin, but it probably takes an experienced user to use a plugin and know he saves some time with it. Also it takes time to master a plugin that is fairly complex. An experienced user knows that he is finished in an hour and that might be less than the time it takes to explore the plugin. So, he must really need it for whatever reason or he will suspect that he'll waste more time with the plugin than in actually doing his stuff.
              I'm building trusses only marginally, the ones I build (or rebuild) on my refurbishments here in Lisbon are so twisted and out of standard, that I'm pretty sure I couldn't use your plugin even if I wanted.
              However, I'm if your plugin would provide a way to have all the metal details that I cannot generate easily, I'd be interested in it...
              Right now, it's really an interesting plugin but I'd probably only purchase it the day I'd build a new building with trusses. That, is already an interesting idea...
              My wife looses her nerve, when I look at materials in the floor, in walls and touch concrete, wood and stones everywhere... But then again, she's an architect too so she just laughs a bit. The kids haven't noticed much yet!
              Thanks for taking your time, I hope I find some more time to test your work...
              Congratulations and keep it up it is already brilliant and you'll make it epic!
              www.casca.pt
              • medeekM Offline
                medeek
                I could add in an advanced option to model in the plates but for now it would be non-engineered and simply for representational purposes. If I have requests from other users for this sort of thing I will consider it.
                design.medeek.com
                • jujuJ Offline
                  juju
                  Thanks for the update Nathaniel. Again version numbering is conflicting with a prior version, also date stamp on the site differs from the post above. Any chance you could have an unique version number to every version you release, even if the change/update is however minor?
                  • medeekM Offline
                    medeek
                    Version 1.3.1 - 02.17.2016
                    • New submenu item and toolbar icon added for global settings.
                    http://design.medeek.com/support/trusspluginmanual/images/truss_su_menu_active.jpg
                    I've also addressed a number of bugs for rafter roofs when metric units are being used. I highly recommend everyone download the latest version, especially if you are using metric units.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Yes, I should probably roll a new rev. even when I make minor changes. The new menu item is really a partial update since I haven't yet add all of the code behind it so I didn't think it worth a new revision number. However, the bug fixes I just made are significant. I will be more strict about this in the future.
                      Date stamp on revision is now 02.17.2016
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Started to code in the dual pitch truss, the top chords, king post and bottom chord are there just need to add some webs:
                        http://design.medeek.com/resources/images/truss_su73_800.jpg
                        Just an FYI, my previous post in Nov. had a sign switched in the last step of the derivation for Span 1, corrected in the plugin to a minus sign and everything is comes out perfect.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Here is a Dual Pitch 2/2 - 3/3 truss with a 12:12 pitch and a 4:12 pitch.
                          http://design.medeek.com/resources/images/truss_su74_800.jpg
                          Still working on the gable end trusses and the advanced options involving structural outlookers.
                          I will be looking at raised heel scissor trusses next, those sound challenging and interesting. Please post or send me examples of any raised heel scissor truss examples or shop drawings. The combined pitches of the top and bottom chord with a wedge, slider or vertical web and strut will require some serious calculations and ample logic.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.3.2 - 02.23.2016
                            • Added Dualpitch truss type, configurations: (2/2-3/3).
                            • Metric input enabled for dualpitch truss type.
                            • Advanced options enabled for dualpitch truss type.
                            http://design.medeek.com/resources/images/truss_su75_800.jpg
                            View model here:
                            3D Warehouse
                            (3dwarehouse.sketchup.com)
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Mono Cathedral trusses with heel wedge:
                              http://design.medeek.com/resources/images/truss_su76_800.jpg
                              View model here:
                              3D Warehouse
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                A quick study of the general shape and layout of a 6/6 bowstring truss with different radii:
                                http://design.medeek.com/images/MISC/BOWSTRING1.jpg
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.3.3 - 02.28.2016
                                  • Added Bowstring truss type, configurations: (6/6).
                                  • Metric input enabled for bowstring truss type.
                                  http://design.medeek.com/resources/images/truss_su77_800.jpg
                                  View model here:
                                  3D Warehouse
                                  I'm not sure how common place this truss type is anymore so I will add the advanced options at a later date if requested by a user. I can also add in other configurations with more panels if needed (ie. 8/8, 10/10).
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Added Bowstring truss type, configurations: (8/8).
                                    http://design.medeek.com/resources/images/truss_su78_800.jpg
                                    View model here:
                                    3D Warehouse
                                    Initially I wasn't really sure how to lay out this type of truss, especially the webs and panel distances. Then after some thought it occurred to me that the length of each top chord segment should be roughly equal to best approximate the circular shape of the truss. After some checking of existing shop drawings my theory tested correct. The length of each top chord segment is equal in length.
                                    The necessary math and algorithm was much simpler than I initially thought. Another sidenote, as the radius of the truss decreases the pitch breaks of the truss become more apparent and the circular shape of the roof becomes more angular.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      28' Bow Barrel Truss (8/8) study.
                                      http://design.medeek.com/resources/images/truss_su79_800.jpg
                                      View model here:
                                      3D Warehouse
                                      Gable end trusses for this type are a bit of a question right now. I can add this one into the plugin if there is some call for it, but I may hold off until a request is made since the code will be somewhat tedious with all the separate members that make up the top and bottom chords.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.3.4 - 03.02.2016
                                        • Corrected a bug in the metric unit template module.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 1.3.5 - 03.04.2016
                                          • Added Bow Barrel truss type, configurations: (8/8).
                                          • Metric input enabled for bow barrel truss type.
                                          • Corrected a bug with the webs of the bowstring truss type.
                                          http://design.medeek.com/resources/images/truss_su80_800.jpg
                                          View model here:
                                          3D Warehouse
                                          Gable end option is also available (not shown in image above for clarity) for this truss type.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            I find the bow barrel truss very interesting. Its very similar to a flat truss in a lot of respects but then you essentially create pitch breaks at all the panel points and add some camber to it.
                                            https://scontent-sea1-1.xx.fbcdn.net/hphotos-xaf1/t31.0-8/12828943_1277725908908068_139963240902266978_o.jpg
                                            View model here:
                                            3D Warehouse
                                            design.medeek.com
                                            • 71
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 75 / 75
