    Golf course animation - Unity3D
    17 Posts 10 Posters 5.8k Views 10 Watching
    • ToboboT Offline
      Tobobo
      I've started working with Unity here at work.
      How long did you spend on it?
      And if its not too cheeky...
      what was your work flow?
      Toby
      Philippians 4:13
        Rob D
        For texture baking straight from SketchUp, the easiest/cheapest workflow I've come across to use LightUp http://www.light-up.co.uk/ as you can see in this video http://vimeo.com/19204786
          miikka1978
          The workflow is not that complicated. I just create the terrain in Sketchup and use different paid tools for creating the scene in Unity, for example Terrain Composer, Relief Terrain Pack (RTP) shaders and Skyshop. It is just quite a lot of tweaking the settings (textures, lighting, etc.).
          Terrain Composer:
          http://www.terraincomposer.com/
          RTP:
          https://www.assetstore.unity3d.com/#/content/5664
          Skyshop:
          https://www.assetstore.unity3d.com/#/content/8880
          • ToboboT Offline
            Tobobo
            Terrain Composer:
            RTP:
            Skyshop:
            Thanks, i'll definitely check them out. πŸ˜„
            Toby
            Philippians 4:13
              miikka1978
              Thanks for the tip!
              I have been following LightUp for quite some time, but I have never considered to purchase it because I would most probably use only small part of its capabilities. I just downloaded the trial and it seems to work really well with exporting/importing into Unity. Also, LightUp seems to really easy to use. Maybe I have to think about it once again.
              I am using Thea Render for rendering and texture baking has been in their roadmap for long time but it has never happened. Also, I would assume that it will not be there for a while because they are concentrating more on other stuff and I totally understand them for doing that.
              Just a note, I also did a quick test with OBJ Exporter plugin and it seemed to work surprisingly well with Unity, see example below.
              http://i.imgur.com/CUQi7pr.jpg
              • AdamBA Offline
                AdamB
                Looks great! πŸ‘
                You might also want to consider exporting directly to LightUp standalone Player, WebPlayer or iPad Player. They support SketchUp Scenes, geo-located realtime shadows.. in fact all the features you can setup using LightUp.
                And its just a single button press to export to a .luca file without leaving SketchUp.
                Adam
                  Tim1965
                  Very nice! Was browsing online and came across your 3D video. I need something similar for a presentation. Miikka1978 email me if your interested.
                  tpd0518@aol.com
                    miikka1978
                    It has been a long time since I have been working with Golf Course animations. Anyway, here are some examples of different way of modeling fairways.
                    • ntxdaveN Offline
                      ntxdave
                      These are really neat..... πŸ‘
                      What tools/plugins did you use to produce the skp model?
                      Press F1...thank me later
                        miikka1978
                        I pretty much use Sketchup only creating the shape of the terrain and spaltmaps that I use for texturing the terrain Unity 3D. When modeling terrain I mainly use Topo Shaper plugin, which is great when working with contour lines.
