    2016 Pro - Section Cut Problem - need advice
    6 Posts 2 Posters 514 Views 2 Watching
    • ntxdaveN Offline
      ntxdave
      OK, I am having a problem with section cuts in 2016. I have a model with car wash equipment inside a building. I am trying to add a section cut so that I can show the equipment inside the building. However I am having problems in that the section cut is showing up in all scenes. Here are the steps and the results:
      • Create Scene 1
      • Click on the + sign to add a new scene (Scene 2)
      • Click on the toolbar icon add a section cut.
      • Some times I get a two section planes as I am moving the mouse
      • Click on the section place to select it and the cursor changes to the Push/Pull icon
      • Hit the space bar to get control of the tool. Then click on the section plane again so I can move the plan to the correct exposure
      • Click on the Update button for Scene 2
      • Click on the Scene 1 tab and the section cut still shows
        This is the exact same procedure I have used with a cube model and that works fine.
      What the heck am I doing wrong or is there a bug in 2016 related to section cuts?
      Press F1...thank me later
      • ntxdaveN Offline
        ntxdave
        This is starting to drive me crazy. I know I must be doing something wrong but I cannot figure it out.
        1. I saved the model as a 2015 skp file and opened it in 2015
        2. Got everything working fine in 2015
        3. Opened the working 2015 file in 2016 and it does not work correctly. I wind up with the section either showing up in both scenes or neither scene
        4. Tried creating a simple cube with a section cut and 2 scenes and all worked correctly.
        5. Used the exact same process (and made sure I was using the same style) with my model and it still did not work
        6. I am also getting the Push/Pull cursor once in a while when I click on either the Display Section Plan or Display Section Cut icon in the toolbar.
        Any insight would be greatly appreciated.
        • JQLJ Offline
          JQL
          Yup I got insight:
          Click the Gif!
          1. Create Scene 1 and Scene 2;
          2. Create Layer 1 and Layer 2;
          3. Create Section 1 and Section 2;
          4. Assign Layer 1 to Section 1;
          5. Assign Layer 2 to Section 2;
          6. On Scene 1 double click Section 1 to activate it;
          7. Update Scene 1 making sure Sections is being updated (easier way is to use the Scene Inspector WINDOW > INSPECTOR | Activate Advanced Settings | Click on Scene 1 from the list | Uncheck and then Check "Active Section" property )
          8. On Scene 2 double click Section 2 to activate it;
          9. Update Scene 2 making sure Sections is being updated
          10. Go to Scene 1 and hide Layer 2 on Layers Inspector;
          11. Update Scene 1 making sure you're updating layer's properties (Best way is again using Scene Inspector to click on Scene 1 | Uncheck+Check Visible Layers Property);
          12. Go to Scene 2 and hide Layer 1 on Layers Inspector;
          13. Update Scene 2 making sure you're updating layer's properties;
          If you now want to add Section Cut Faces, it's super easy now that Tig updated it to v5.
          Simply add sections with these default values for Layer and Naming:
          www.casca.pt
          Visit us on facebook!
          • ntxdaveN Offline
            ntxdave
            Thanks - I will try later ( or in the morning) but I do not understand why what I did in 2015 and with the cube in 2016 does not work in my model in 2016. Has something changed in 2016?
            • JQLJ Offline
              JQL
              Nope, nothing's changed. But you might have been using a different style or there might be something you're not aware of and so you're not telling us.
              www.casca.pt
              • ntxdaveN Offline
                ntxdave
                Well interesting..........
                I just took the 2015 file and opened it again in 2016. I noticed that the style icon had the round arrows on it so I updated the style and WaaaLaaa, it worked. So it was a styles issue all along. Do not know why I did not see that yesterday.
                Now a couple more interesting things:
                1. I do not have any layers or section names associated with the section plane
                2. I added the SectionCutFace and was able to set the color of various portions of the section cut.One interesting showed up that I had not seen before when using the SectionCutFace. Of course it showed all of the cuts to the walls and applied a face which I was able to color to match the texture of the walls and floor. Then a new one showed up in that it applied a face with the default color to the entire rest of the building. I then colored that face white and set the opacity to 0.
                Now a couple of questions:
                1. When trying the SectionCutFace plugin before I had not seen that happen. I did do the update of the plugin yesterday. Is this a bug?
                2. Even though I got the section cut to work properly today, is this the wrong way to do it? I have seen several other examples and tutorials before where the author (and some of them very advanced authors) did not add a section name and put it on a layer to control the visibility. I suppose (and looking at the parameters of the SectionCutFace plugin) that the best organization is to name the section cut and put it on a layer and control the visibility via the layer.
                Just trying to understand the best/correct way because I will be using this for some later endeavors.
